* canonical-target-name.m4: Fix m4-quoting for autoconf-2.49f.
* aclocal/config-subdirs.m: Fix m4-quoting for autoconf-2.49f,
Add support for DOS-drive-letters.
* aclocal/prog-cc.m4: Add CPPFLAGS and CFLAGS handling to
RTEMS_PROG_CC_FOR_TARGET.
* aclocal/check-rdbg.m4: Added check to determine which PowerPC
BSPs support the new exception processing model and
consequently, librdbg.
* aclocal/config-subdirs.m4: Let CC default to $host_alias-gcc in
TARGET_CONFIG_SUBDIRS.
* aclocal/enable-bsp.m4: fix quoting.
* aclocal/check-bsps.m4, aclocal/bsp-alias.m4: Add pc386dx.
* aclocal/config-subdirs.m4: New file.
* aclocal/target.m4: Use macros from config-subdirs.m4.
* aclocal/env-rtemsbsp.m4, aclocal/env-rtemscpu.m4:
Add -B$(PROJECT_ROOT)/ to GCC_SPECS.
* configre.in: Fix AM_INIT_AUTOMAKE.
* aclocal/bsp-arg-enable.m4: Extend comments.
* aclocal/check-bsps.m4: Remove extraneous comments, add test -d in
the default clause.
* aclocal/enable-rtemsbsp.m4: Split out RTEMS_ENV_RTEMSBSP,
RTEMS_ENV_RTEMSCPU.
* aclocal/env-rtemsbsp.m4: New file for RTEMS_ENV_RTEMSBSP, add
special treatment for GCC_SPECS.
* aclocal/env-rtemscpu.m4: New file for RTEMS_ENV_RTEMSCPU, add
* aclocal/bsp-enable-arg.m4: New file, introduce RTEMS_BSP_ARG_ENABLE.
* aclocal/prog-cc.m4: Add AC_PROG_CPP, use build_os in GCCSED hack.
* automake/compile.am: New treatment of CPP, GCCSPECS, use `..`
instead of $(shell ..) for LIBC_LIB*.
* aclocal/bsp-alias.m4, aclocal/check-bsps.m4: Add simsh7032 and
simsh7045.
* aclocal/canonical-host.m4: Abandon changequotes (autoconf-2.49b).
* aclocal/check-newlib.m4: Let check message refer to RTEMS newlib.
* aclocal/rtems-debug.m4: Fix formating and contents of the check's
help string.
* aclocal/rtems-top.m4: Remove AC_ARG_WITH(target-subdir).
* README.configure, aclocal/bsp-alias.m4, aclocal/check-bsps.m4:
Modified to reflect addition of LEON BSPs as well as the
no-FP ERC32 variant.
* aclocal/gcc-pipe.m4: Use $GCC instead of ac_cv_prog_gcc (autoconf
standard).
* aclocal/gcc-specs.m4: Use $GCC instead of ac_cv_prog_gcc (autoconf
standard).
* aclocal/multilib.m4: Fix m4-quoting (BUG-FIX).
* aclocal/check-bsp-cache.m4: Fix m4-quoting (autoconf-2.49b).
* aclocal/prog-cc.m4: Use $GCC instead of ac_cv_prog_gcc (autoconf
standard), replace CC_FOR_TARGET with CC (BUG-FIX).
* aclocal/enable-itron.m4: Remove changequotes (autoconf-2.49b).
* aclocal/enable-posix.m4: Remove changequotes (autoconf-2.49b), use
$host instead of $target (BUG-FIX).
* configure.in: Use $target and $host instead of $target_alias and
$host_alias (autoconf-2.49b).
* aclocal/check-newlib.m4: Remove CC_FOR_TARGET (BUG-FIX)
* aclocal/sysv-ipc.m4: Move AC_DEFINE outside of AC_CACHE (BUG-FIX)
NOTES:
* autoconf-2.49b depredicates using changequotes.
* The changes to configure.in are due to cleanups in
autoconf-2.49b's implemention of canonicalization. With
autoconf-2.1x it wasn't always clear, when to use $xxx or
$xxx_alias. Now this is clear.
* aclocal/canonicalize-tools.m4, aclocal/check-tool.m4,
aclocal/prog-cc.m4, aclocal/prog-cxx.m4: Replace AC_CHECK_TOOL
with an RTEMS specific but more restrictive autoconf macro.
* aclocal/canonicalize-tools.m4: Remove RTEMS_PATH_TOOL, use
AC_CHECK_TOOL instead of RTEMS_PATH_TOOL in RTEMS_CANONICALIZE_TOOLS.
* aclocal/*: Replace with contents of macros/*.m4
* macros/: Remove.
* aclocal/ar-s.m4 aclocal/tool-prefix.m4: Remove.
* Makefile.am: Reflect changes to aclocal/ and macros/.
* macros/enable-hwapi.m4: Removed.
* aclocal/rtems-top.m4, automake/compile.am, automake/lib.am:
A small cleanup step towards gnu-canonicalization.
* aclocal/enable-hwapi.m4: Now longer used and removed.
* aclocal/rtems-top.m4: Add ENDIF-hack.
* automake/compile.am: Add include $(DEPENDS) + ENDIF-hack.
* aclocal/check-cxx.m4: Add AC_SUBST(CPLUS_LD_LIBS)
* aclocal/prog-cc.m4: Cleanup comments, require RTEMS_ENABLE_GCC28,
add automake conditionals RTEMS_USE_GCC, RTEMS_USE_GCC272.
* automake/compile.am: Replaced.
* automake/local.am: Remove building variant handling.
* aclocal/enable-rtemsbsp.m4: Add RTEMS_ENABLE_BARE,
AC_SUBST(BARE_CPU_MODEL),AC_SUBST(BARE_CPU_CFLAGS).
* aclocal/i386-gas-code16.m4: AC_DEFINE NEW_GAS.
* aclocal/target.m4: Cleanup comments
* Automake/compile.am: Add DEFS support to keep building happy.
* aclocal/project-root.m4: Introduce PROJECT_TOPdir, add comments.
* aclocal/check-bsps.m4: Fix c4* and sim68000 entries
* make/custom/pck6.cfg: New file
* make/custom/pc486.cfg: Use -m486
* make/custom/pc586.cfg: Use -mpentium
* make/custom/pc686.cfg: Use -mmpentiumpro
* make/custom/i386ex.cfg: Use -msoft-float
* aclocal/check-bsps.h:
- Add pck6-BSP
- Exclude ChangeLog from being picked up as BSP
* aclocal/bsp-alias.m4: Add pck6-BSP
alias simcpu32 that supports the CPU32 simulator in BSVC. At this
point, it is still under development.
that is an improvement in the version handling macro that compensates
for Joel's bug in the release script which broke the VERSION file format.
cpuopts.h.
exec/configure.in, only.
quoting bugs in autoconf).
formating changes :)
cpuopts.h.
to disabled.
problems at runtime.
that is another small step toward multilibs:
* Eliminate RTEMS_CHECK_CUSTOM_BSP from all configure.ins below exec/
* Add RTEMS_CHECK_CUSTOM_BSP to the multilib-disabled branch in
RTEMS_ENV_RTEMSCPU to preserve the old per-BSP building scheme
functional.
* --enable-multilibs is still non-functional
* This patch should not have any influence on the old building
scheme (--disable-multilib should silently fall back to the old
building scheme).
* running ./bootstrap is required after applying the patch
<corsepiu@faw.uni-ulm.de> that adds a piece of the
*-rc-20000705-? series that was not added to CVS accidentally.
that makes --disable-multilib the default.
that is a somewhat experimental, multilib-related patch:
* Use RTEMS_ENV_RTEMSCPU instead of RTEMS_ENV_RTEMSBSP in
configure.ins below exec/.
At the moment, RTEMS_ENV_RTEMSCPU is more or less an optical change
to emphasize that these subdirectories shall not depend on RTEMS_BSP
than a real behavioral change.
* Add AC_DEFINE_* to several aclocal/*.m4 macros to prepare
autoheader/autoconf generated targopts.h and similiar configuration
headers.
* c/src/configure.in: remove exec from cfg_subdirs if multilibs are
enabled (c/src is build per bsp, exec shall be build per cpu in c/
or from the toplevel in future, when multilibs are enabled.)
* This patch should not have any impact on the current building scheme.
* --enable-multilib still does not work.
* running bootstrap from the toplevel directory is required.
CVS:
CVS: Committing in .
CVS:
CVS: Modified Files:
Comments follow:
Building linux/posix fails due to including lib/include/sys/cdefs.h
instead of linux's sys/cdefs.h.
AFAIS, this sys/cdefs.h is specific to newlib and should probably
not be used on any unix host.
Therefore, I changed the relevant Makefile.am/configure.in to
condionally install sys/cdefs.h only if newlib is present.
This triggered another bug inside of the newlib-check for one of
RTEMS target's (Unfortunately I can't remember which - mips/i960 ?
... one of the more exotic ...), for which int func() isn't
identical to void func().
Note: This patch needs to be tested under Cygwin and Solaris. I am
particularily unsure about Cygwin/posix, as it applies a different
version newlib which must not trigger RTEMS newlib check (it is
supposed to fail) and if it may need RTEMS's sys/cdefs.h.
that is part of the multilib/gnu-canonicalization movement:
* New m4-macro: aclocal/multilib.am
* Suppress multiprocessing if --enable-multilib is given to
configure
For now this patch only suppresses multiprocessing if
--enable-multilib is given to configure and should not have any
other side-effects, ie. it works around a minor issue which prevents
introduction of multilibs in general.
The RTEMS_ENABLE_MULTILIB_MASTER macro is the core part to build
real multilibs, but can not be applied before other multilib related
issues with RTEMS have been solved. (e.g. sptables.h, bsp_specs,
Cygnus/Gnu canonicalization, _RTEMS_version, targopts.h, changing
the installation point/tooldir support, etc.).
build issues.
<corsepiu@faw.uni-ulm.de> that addresses a couple of
minor configuration issues which popped up when
experimenting with multilibs.
Note: The multigen generated make/custom/bare-*.cfg will still be
non-functional, even after having applied this patch.
significant things:
and PowerPC
same code base.
that contains:
* Removes MKLIB
handling)
<corsepiu@faw.uni-ulm.de>.
the mvme2307 and mcp750 BSPs. In addition, it can support many
Motorola PowerPC based VME and PCI boards.
which is described below:
break something.
SUBDIRS in a Makefile.am)
* An update to gensh2.cfg.
cd <srcdir>
which adds automake support to libbsp/bare.
to generalize librdbg for all i386 BSPs. His comments:
The patch below generalizes librdbg for all i386 bsps. It is not a
complete rewrite, but a minimal invasive attempt to generalization.
mv c/src/librdbg/src/i386/pc386 c/src/librdbg/src/i386/any
patch -p1 < patches-rc-19991203-1.diff
./bootstrap
<corsepiu@faw.uni-ulm.de>:
The patch below provides
before)
rtems-rc-19991123-rc-2.diff
Attention:
