path: root/aclocal (follow)
* 2001-11-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-12-031-0/+17
| | | | | * aclocal/bsp-configure.m4: New file. * Makefile.am: Add aclocal/bsp-configure.m4.
* 2001-11-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-11-213-3/+1
| | | | | | * aclocal/bsp-alias.m4: Remove score603e_g1. * aclocal/check-bsps.m4: Remove score603e_g1. * aclocal/prog-cc.m4: Apply m4_if.
* 2001-11-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-11-201-0/+111
| | | | | * automake/force-preinstall.am: New file. * aclocal/ppc.m4: New file.
* 2001-11-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-11-152-26/+20
| | | | | * aclocal/check-bsps.m4: Reworked. * aclocal/bsp-alias.m4: Add score603e_g1, apply m4sugar.
* 2001-11-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-11-141-0/+66
| | | | * aclocal/bspopts.m4: New file.
* 2001-10-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-171-6/+2
| | | | | * aclocal/check-rdbg.m4: Fix latent bug exposed by removal of config.cache's which prevented powerpc targets librdbg from building.
* 2001-10-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-172-20/+22
| | | | | | | | * aclocal/rtems-cpu-subdirs.m4: Add PREFIX arg to RTEMS_CPU_SUBDIRS, add 2nd arg to _RTEMS_CPU_SUBDIR. * aclocal/target.m4: Replace ac_configure_args with rtems_configure_args, add rtems_configure_args to INIT-CMDS. * Makefile.am: Require automake-1.5.
* 2001-10-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-101-0/+31
| | | | * aclocal/rtems-cpu-subdirs.m4: New file.
* 2001-09-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-143-34/+43
| | | | | | | | | | * aclocal/canonical-target-name.m4: Use AC_CANONICAL_TARGET instead of AC_CANONICAL_SYSTEM. * aclocal/config-subdirs.m4: Use AS_MKDIR_P instead of mkinstalldirs and mkdir. * aclocal/target.m4: Obsolete RTEMS_OUTPUT_BUILD_SUBDIRS, hack RTEMS_CONFIG_BUILD_SUBDIRS, introduce _RTEMS_OUTPUT_BUILD_SUBDIRS.
* 2001-07-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-1317-21/+25
| | | | | | | | | | | | | | | | | | | | | | | | * configure.in: autoupdate to autoconf-2.52. * bootstrap: Add handling for configure.ac, make autoheader verbose, fix auto*tool invocation order. * aclocal/rtems-test-no-pause.m4: Introduce AC_HELP_STRING. * aclocal/enable-bare.m4: Introduce AC_HELP_STRING. * aclocal/enable-cxx.m4: Introduce AC_HELP_STRING. * aclocal/enable-gcc28: Introduce AC_HELP_STRING. * aclocal/enable-inlines.m4: Introduce AC_HELP_STRING. * aclocal/enable-itron.m4: Introduce AC_HELP_STRING. * aclocal/enable-libcdir.m4: Introduce AC_HELP_STRING. * aclocal/enable-multiprocessing.m4: Introduce AC_HELP_STRING. * aclocal/enable-networking.m4: Introduce AC_HELP_STRING. * aclocal/enable-posix.m4: Introduce AC_HELP_STRING. * aclocal/enable-rdbg.m4: Introduce AC_HELP_STRING. * aclocal/enable-rtemsbsp.m4: Introduce AC_HELP_STRING. * aclocal/enable-tests.m4: Introduce AC_HELP_STRING. * aclocal/env-rtemsbsp.m4: Add AC_ARC_VAR(RTEMS_BSP), apply true in RTEMS_CONFIG_PER_BSP conditional. * aclocal/multilib.m4: Introduce AC_HELP_STRING. * aclocal/rtems-debug.m4: Introduce AC_HELP_STRING. * aclocal/rtems-top.m4: Add AC_PREFIX_DEFAULT(/opt/rtems).
* 2001-05-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-05-242-14/+10
| | | | | | * canonical-target-name.m4: Fix m4-quoting for autoconf-2.49f. * aclocal/config-subdirs.m: Fix m4-quoting for autoconf-2.49f, Add support for DOS-drive-letters.
* 2001-04-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-05-071-0/+6
| | | | | * aclocal/prog-cc.m4: Add CPPFLAGS and CFLAGS handling to RTEMS_PROG_CC_FOR_TARGET.
* 2001-04-20 Eric Valette <valette@crf.canon.fr>Joel Sherrill2001-04-201-0/+21
| | | | | | * aclocal/check-rdbg.m4: Added check to determine which PowerPC BSPs support the new exception processing model and consequently, librdbg.
* 2001-02-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-02-214-3/+4
| | | | | | | * aclocal/config-subdirs.m4: Let CC default to $host_alias-gcc in TARGET_CONFIG_SUBDIRS. * aclocal/enable-bsp.m4: fix quoting. * aclocal/check-bsps.m4, aclocal/bsp-alias.m4: Add pc386dx.
* 2001-02-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-02-052-45/+254
| | | | | | * aclocal/config-subdirs.m4: New file. * aclocal/target.m4: Use macros from config-subdirs.m4.
* 2001-02-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-02-022-2/+2
| | | | | * aclocal/env-rtemsbsp.m4, aclocal/env-rtemscpu.m4: Add -B$(PROJECT_ROOT)/ to GCC_SPECS.
* 2001-02-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-02-022-8/+8
| | | | | | | * configre.in: Fix AM_INIT_AUTOMAKE. * aclocal/bsp-arg-enable.m4: Extend comments. * aclocal/check-bsps.m4: Remove extraneous comments, add test -d in the default clause.
* 2001-01-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-01-295-45/+83
| | | | | | | | | | | | | * aclocal/enable-rtemsbsp.m4: Split out RTEMS_ENV_RTEMSBSP, RTEMS_ENV_RTEMSCPU. * aclocal/env-rtemsbsp.m4: New file for RTEMS_ENV_RTEMSBSP, add special treatment for GCC_SPECS. * aclocal/env-rtemscpu.m4: New file for RTEMS_ENV_RTEMSCPU, add special treatment for GCC_SPECS. * aclocal/bsp-enable-arg.m4: New file, introduce RTEMS_BSP_ARG_ENABLE. * aclocal/prog-cc.m4: Add AC_PROG_CPP, use build_os in GCCSED hack. * automake/compile.am: New treatment of CPP, GCCSPECS, use `..` instead of $(shell ..) for LIBC_LIB*.
* 2001-01-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-01-222-0/+3
| | | | | * aclocal/bsp-alias.m4, aclocal/check-bsps.m4: Add simsh7032 and simsh7045.
* 2000-11-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-154-19/+10
| | | | | | | | * aclocal/canonical-host.m4: Abandon changequotes (autoconf-2.49b). * aclocal/check-newlib.m4: Let check message refer to RTEMS newlib. * aclocal/rtems-debug.m4: Fix formating and contents of the check's help string. * aclocal/rtems-top.m4: Remove AC_ARG_WITH(target-subdir).
* 2000-11-13 Jiri Gaisler <jgais@ws.estec.esa.nl>Joel Sherrill2000-11-132-0/+5
| | | | | | * README.configure, aclocal/bsp-alias.m4, aclocal/check-bsps.m4: Modified to reflect addition of LEON BSPs as well as the no-FP ERC32 variant.
* 2000-11-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-095-10/+10
| | | | | | | | | | | * aclocal/gcc-pipe.m4: Use $GCC instead of ac_cv_prog_gcc (autoconf standard). * aclocal/gcc-specs.m4: Use $GCC instead of ac_cv_prog_gcc (autoconf standard). * aclocal/multilib.m4: Fix m4-quoting (BUG-FIX). * aclocal/check-bsp-cache.m4: Fix m4-quoting (autoconf-2.49b). * aclocal/prog-cc.m4: Use $GCC instead of ac_cv_prog_gcc (autoconf standard), replace CC_FOR_TARGET with CC (BUG-FIX).
* 2000-11-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-094-16/+9
| | | | | | | | | | | | | | | | | * aclocal/enable-itron.m4: Remove changequotes (autoconf-2.49b). * aclocal/enable-posix.m4: Remove changequotes (autoconf-2.49b), use $host instead of $target (BUG-FIX). * configure.in: Use $target and $host instead of $target_alias and $host_alias (autoconf-2.49b). * aclocal/check-newlib.m4: Remove CC_FOR_TARGET (BUG-FIX) * aclocal/sysv-ipc.m4: Move AC_DEFINE outside of AC_CACHE (BUG-FIX) NOTES: * autoconf-2.49b depredicates using changequotes. * The changes to configure.in are due to cleanups in autoconf-2.49b's implemention of canonicalization. With autoconf-2.1x it wasn't always clear, when to use $xxx or $xxx_alias. Now this is clear.
* 2000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-031-0/+10
| | | | | | * aclocal/canonicalize-tools.m4, aclocal/check-tool.m4, aclocal/prog-cc.m4, aclocal/prog-cxx.m4: Replace AC_CHECK_TOOL with an RTEMS specific but more restrictive autoconf macro.
* 2000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-023-16/+12
* 2000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-021-44/+3
| | | | | * aclocal/canonicalize-tools.m4: Remove RTEMS_PATH_TOOL, use AC_CHECK_TOOL instead of RTEMS_PATH_TOOL in RTEMS_CANONICALIZE_TOOLS.
* 2000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-0215-263/+99
| | | | | | | * aclocal/*: Replace with contents of macros/*.m4 * macros/: Remove. * aclocal/ar-s.m4 aclocal/tool-prefix.m4: Remove. * Makefile.am: Reflect changes to aclocal/ and macros/.
* 2000-10-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-241-0/+3
| | | | | | * macros/enable-hwapi.m4: Removed. * aclocal/rtems-top.m4, automake/compile.am, automake/lib.am: A small cleanup step towards gnu-canonicalization.
* 2000-09-14 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-141-15/+0
| | | | * aclocal/enable-hwapi.m4: Now longer used and removed.
* 2000-09-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-131-0/+4
| | | | | * aclocal/rtems-top.m4: Add ENDIF-hack. * automake/compile.am: Add include $(DEPENDS) + ENDIF-hack.
* 2000-09-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-122-2/+13
| | | | | | | | * aclocal/check-cxx.m4: Add AC_SUBST(CPLUS_LD_LIBS) * aclocal/prog-cc.m4: Cleanup comments, require RTEMS_ENABLE_GCC28, add automake conditionals RTEMS_USE_GCC, RTEMS_USE_GCC272. * automake/compile.am: Replaced. * automake/local.am: Remove building variant handling.
* 2000-09-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-123-3/+7
| | | | | | | | * aclocal/enable-rtemsbsp.m4: Add RTEMS_ENABLE_BARE, AC_SUBST(BARE_CPU_MODEL),AC_SUBST(BARE_CPU_CFLAGS). * aclocal/i386-gas-code16.m4: AC_DEFINE NEW_GAS. * aclocal/target.m4: Cleanup comments * Automake/compile.am: Add DEFS support to keep building happy.
* 2000-09-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-061-3/+23
| | | | * aclocal/project-root.m4: Introduce PROJECT_TOPdir, add comments.
* 2000-08-31 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-011-2/+2
| | | | * aclocal/check-bsps.m4: Fix c4* and sim68000 entries
* 2000-08-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-08-252-1/+3
| | | | | | | | | | | | * make/custom/pck6.cfg: New file * make/custom/pc486.cfg: Use -m486 * make/custom/pc586.cfg: Use -mpentium * make/custom/pc686.cfg: Use -mmpentiumpro * make/custom/i386ex.cfg: Use -msoft-float * aclocal/check-bsps.h: - Add pck6-BSP - Exclude ChangeLog from being picked up as BSP * aclocal/bsp-alias.m4: Add pck6-BSP
* Added sim68000 BSP for the BSVC simulator. This BSP includes theJoel Sherrill2000-08-012-0/+2
| | | | | alias simcpu32 that supports the CPU32 simulator in BSVC. At this point, it is still under development.
* Patch rtems-rc-20000725-1-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-07-251-1/+1
| | | | | that is an improvement in the version handling macro that compensates for Joel's bug in the release script which broke the VERSION file format.
* Added c3xsim as alias of c4xsim.Joel Sherrill2000-07-252-0/+2
* Changed default value to "pause".Joel Sherrill2000-07-171-1/+1
* Patch rtems-rc-20000713-1-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-07-135-2/+30
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | that is yet another multilib-related structual cleanup patch: Changes: * Make RTEMS_TEST_NO_PAUSE a tests/ subpackage specific option. - Remove RTEMS_TEST_NO_PAUSE from custom/*.cfg, targopts.h and cpuopts.h. - Add autoconf macros RTEMS_*_RTEMS_TEST_NO_PAUSE (aclocal/rtems-test-no-pause.m4). - Add RTEMS_*_RTEMS_TEST_NO_PAUSE support to sptests/configure.ins and tmtests/configure.in. These are the only subdirectories which currently apply RTEMS_TEST_NO_PAUSE. - Add autoconf-DEFS support to all test subpackages' configure.ins below tests/. I.e. AC_DEFINES now get explicitly propagated as preprocessor defines into Makefiles, cf. AM_CPPFLAGS in tests/*/*.am, instead of using a global config-files. - Remove NDEBUG from custom/*.cfg. * AC_DEFINE POSIX_API, ITRON_API and MULTIPROCESSING in exec/configure.in, only. - All other sources now should relay on the values from cpuopts.h and should not define them themselves. - Several related changes to many configure.ins * Bug-fixes to RTEMS_*_RTEMS_DEBUG macros (Actually workarounds to quoting bugs in autoconf). Notes: * This patch is rather immature and only tested for a small subset of BSPs (requires the tests to be enabled and therefore takes an tremendous amount of disc space and time.) * The patches to *cfg were generated by a script. Expect file formating changes :)
* Patch rtems-rc-20000712-1-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-07-121-0/+19
| | | | | | | | | | | | | | | | | | | | | | | | that is yet another multilib-related structual cleanup patch: Changes: * Make RTEMS_DEBUG a global per-cpu configuration option * Remove RTEMS_DEBUG from targopts.h * Add a global --enable-rtems-debug option disabled by default. * Add RTEMS_DEBUG to cpuopts.h * Remove all references to RTEMS_DEBUG from custom/*.cfg Notes: * RTEMS_DEBUG is set in c/src/exec/configure.in only (RTEMS_CHECK_RTEMS_DEBUG) and should be defined in cpuopts.h only. BSPs should not redefine it, but use the value being provided by cpuopts.h. => With multilibs, users have to choose: Either enable RTEMS_DEBUG for all BSPs and CPU_MODELs of a cpu or not. * Only few BSPs had RTEMS_DEBUG enabled, therefore I set the default to disabled. * This patch influences the per-BSP building scheme. Existing BSPs which set RTEMS_DEBUG in their make-target-options rule might have problems at runtime.
* Patch rtems-rc-20000708-1.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-07-101-0/+1
| | | | | | | | | | | | | | | | | that is another small step toward multilibs: Changes: * Eliminate RTEMS_CHECK_CUSTOM_BSP from all configure.ins below exec/ * Add RTEMS_CHECK_CUSTOM_BSP to the multilib-disabled branch in RTEMS_ENV_RTEMSCPU to preserve the old per-BSP building scheme functional. Notes: * --enable-multilibs is still non-functional * This patch should not have any influence on the old building scheme (--disable-multilib should silently fall back to the old building scheme). * running ./bootstrap is required after applying the patch
* Patch rtems-rc-20000707-1-cvs.diff from Ralf CorsepiusJoel Sherrill2000-07-071-0/+6
| | | | | <corsepiu@faw.uni-ulm.de> that adds a piece of the *-rc-20000705-? series that was not added to CVS accidentally.
* Patch rtems-rc-20000704-1.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-07-061-1/+1
| | | | that makes --disable-multilib the default.
* Patch rtems-rc-20000705-3.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-07-065-2/+43
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | that is a somewhat experimental, multilib-related patch: Changes: * Use RTEMS_ENV_RTEMSCPU instead of RTEMS_ENV_RTEMSBSP in configure.ins below exec/. At the moment, RTEMS_ENV_RTEMSCPU is more or less an optical change to emphasize that these subdirectories shall not depend on RTEMS_BSP than a real behavioral change. * Add AC_DEFINE_* to several aclocal/*.m4 macros to prepare autoheader/autoconf generated targopts.h and similiar configuration headers. * c/src/configure.in: remove exec from cfg_subdirs if multilibs are enabled (c/src is build per bsp, exec shall be build per cpu in c/ or from the toplevel in future, when multilibs are enabled.) Notes: * This patch should not have any impact on the current building scheme. * --enable-multilib still does not work. * running bootstrap from the toplevel directory is required. CVS: ---------------------------------------------------------------------- CVS: Enter Log. Lines beginning with `CVS:' are removed automatically CVS: CVS: Committing in . CVS: CVS: Modified Files: CVS: c/src/tests/libtests/termios/init.c CVS: ----------------------------------------------------------------------
* Patch rtems-rc-20000626-1.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill2000-07-061-5/+5
| | | | | | | | | | | | | | | | | | | | | | Comments follow: Building linux/posix fails due to including lib/include/sys/cdefs.h instead of linux's sys/cdefs.h. AFAIS, this sys/cdefs.h is specific to newlib and should probably not be used on any unix host. Therefore, I changed the relevant Makefile.am/configure.in to condionally install sys/cdefs.h only if newlib is present. This triggered another bug inside of the newlib-check for one of RTEMS target's (Unfortunately I can't remember which - mips/i960 ? ... one of the more exotic ...), for which int func() isn't identical to void func(). Note: This patch needs to be tested under Cygwin and Solaris. I am particularily unsure about Cygwin/posix, as it applies a different version newlib which must not trigger RTEMS newlib check (it is supposed to fail) and if it may need RTEMS's sys/cdefs.h.
* Patch rtems-rc-20000627-1 from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-06-292-6/+72
| | | | | | | | | | | | | | | | | | | | | that is part of the multilib/gnu-canonicalization movement: Changes: * New m4-macro: aclocal/multilib.am * Suppress multiprocessing if --enable-multilib is given to configure Notes: For now this patch only suppresses multiprocessing if --enable-multilib is given to configure and should not have any other side-effects, ie. it works around a minor issue which prevents introduction of multilibs in general. The RTEMS_ENABLE_MULTILIB_MASTER macro is the core part to build real multilibs, but can not be applied before other multilib related issues with RTEMS have been solved. (e.g. sptables.h, bsp_specs, Cygnus/Gnu canonicalization, _RTEMS_version, targopts.h, changing the installation point/tooldir support, etc.).
* Patch from James Housley <jim@thehousleys.net> to address FreeBSD 4.xJoel Sherrill2000-06-165-4/+5
| | | | build issues.
* Patch rtems-rc-20000614-1-cvs.diff from Ralf CorsepiusJoel Sherrill2000-06-143-10/+16
| | | | | | | | | <corsepiu@faw.uni-ulm.de> that addresses a couple of minor configuration issues which popped up when experimenting with multilibs. Note: The multigen generated make/custom/bare-*.cfg will still be non-functional, even after having applied this patch.
* Patch from John Cotton <john.cotton@nrc.ca>, Charles-Antoine GauthierJoel Sherrill2000-06-122-0/+2
| | | | | | | | | | | | | | | <charles.gauthier@iit.nrc.ca>, and Darlene A. Stewart <Darlene.Stewart@nrc.ca> to add support for a number of very significant things: + BSPs for many variations on the Motorola MBX8xx board series + Cache Manager including initial support for m68040 and PowerPC + Rework of mpc8xx libcpu code so all mpc8xx CPUs now use same code base. + Rework of eth_comm BSP to utiltize above. John reports this works on the 821 and 860
