Username: deuteriumoxide Email: jacobshin313@gmail.com
This work was performed as a GCI 2018 task.
Update #3433.
All tools should be removed from the RTEMS source repository at some
point in time. Tools with a BSD-style license will be moved to the
RTEMS tools repository. Unfortunately, this tool has no license
information.
Remove all uses of this tool from the code base. Users of HEX files
should consider to use ELF instead.
Close #3379.
This tool is now included in the RTEMS tools repository.
Close #3380.
The d542af2e4304b663461330a60313fb6c4fdbf4db commit was a bad one.
The riscv32 and riscv64 targets share a riscv source directory. The
potential future powerpcspe and powerpc targets need this change as
well.
For example ${target_arch} is "riscv32" and ${cfg_arch} is "riscv".
well.
Update #3285.
Also generate an error if the architecure does not match the --target
architecture given to configure's command line.
Close #2641.
Close 3383.
Close #3385.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Updates #3520.
This fixes the legacy Makefile based build system which expects
RTEMS_API to be identical to the tool chain version.
Update #3220.
Tool name will be "rtems5", e.g. arm-rtems5-gcc.
Next release will 5.1.0. Branch version after release will be 5.1.1.
Next master will be 6.0.0.
* Use #ifdefs for 32/64 bit code
* Use unsigned long which is 32-bit on riscv32 and 64-bit on riscv64 (register size)
* Move the code to a new shared riscv folder to be shared between riscv32 and riscv64
* Rename RTEMS_CPU extracted from command line to shared riscv target s/riscv*/riscv
Update #3109
We always build a C++ compiler and building with C++ does not effect
RTEMS or the runtime. This patch always enabled the support. There is
no need to manually enable it any more.
You can disable C++ with '--disable-cxx'.
If an architecture does not have a C++ compiler support is automatically
disabled.
Virtual machines with paravirtualization exist not only on x86.
for details.
PR 1810/misc
* ChangeLog: Fix previous damage.
PR 1729/cpukit
* aclocal/enable-smp.m4: New file.
* aclocal/rtems-top.m4: Add pkgdatadir.
Override pkgdatadir to $(datadir)/rtems$_RTEMS_API.
* Makefile.am: Install make/Templates to pkgdatadir.
* Makefile.maint, aclocal/rpm.m4, aclocal/rtems-top.m4,
aclocal/version.m4: Rename RTEMS_API into _RTEMS_API.
PR 1532/testing
* aclocal/project-root.m4: Add initial tests for untar capabilities.
* aclocal/enable-itron.m4: Remove.
* configure.ac: Remove itron.
* aclocal/version.m4: Bump RTEMS_API to 4.11.
Bump _RTEMS_VERSION to 4.10.99.0.
* aclocal/bsp-alias.m4: Change quoting to work-round
http://www.freebsd.org/cgi/query-pr.cgi?pr=146378.
* aclocal/check-custom-bsp.m4: Be less verbose.
* aclocal/bsp-alias.m4: Fix quoting bug.
* aclocal/bsp-alias.m4: Remove bare BSP (Abandoned).
* aclocal/bsp-alias.m4: Pickup bsps from
c/src/lib/libbsp/<cpu>/<bsp_family>/make/custom*.cfg.
* aclocal/check-bsps.m4: Pickup bsps from
* aclocal/check-custom-bsp.m4: Let _RTEMS_CHECK_CUSTOM_BSP look for
*.cfg into c/src/lib/libbsp/<cpu>/<bsp_family>/make/custom.
