path: root/aclocal (follow)
* Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1998-11-191-2/+2
| | | | | | | Here is a cosmetic patch which corrects a few spelling problems in parts written by me. Apparently, I must have written these under the influence of ether (:-)
* Merged Vista SCORE603e, Radstone PPCn_60x, and DY-4 DMV177 BSPs alongJoel Sherrill1998-10-281-0/+1
| | | | with libchip.
* Regenerated after fixing a typo.Joel Sherrill1998-10-051-2/+1
* Modifed i386 gas test to put each directive on its own line perJoel Sherrill1998-10-051-1/+4
| | | | problem report from Erik Ivanenko <erik.ivanenko@utoronto.ca>.
* Added new autoconf test for i386 code16/code32 support. The guts of theJoel Sherrill1998-09-301-3/+2
| | | | | | test were suggested by Ian Taylor <ian@airs.com> and Joel did the hard part of putting it in aclocal and editting all the offending Makefiles and source code which could use this feature.
* Added Id's.Joel Sherrill1998-09-309-0/+23
* New configure test from Ian Lance Taylor <ian@airs.com>:Joel Sherrill1998-09-301-0/+25
| | | | | If the target is an i386, this test checks whether or not the binutils is new enough to have good support for code16.
* Patches from Ralf Corsepius <corsepiu@faw.uni-ulm.de> and myself toJoel Sherrill1998-08-191-0/+8
| | | | | | | | | | | | | | | | | | | | | | | | make solaris target buildable. > 1. The ipc check fails since solaris does not define union semun. > The unix port code actually defines this type itself on solaris. Doing > the same thing lets it get configured. Then... > 2. It looks like BSDINSTALL is not defined properly. BSDINSTALL is defined in make/host.cfg.in as BSDINSTALL=@INSTALL@ @INSTALL@ is generated by autoconf's standard macro AC_PROG_INSTALL, which is widely used in almost any autoconf/automake configured package. In case there is really something wrong with it, then it must be considered a bug in autoconf. I can see a doubious fragment in AC_PROG_INSTALL, which is used when no appropriate bsd-install is found. Finally Ralf saw a problem with the find on solaris which I also saw and fixed.
* Patch from Dario Alcocer <alcocer@connectnet.com> and Ralf CorsepiusJoel Sherrill1998-07-231-0/+88
| | | | | | | | | | <corsepiu@faw.uni-ulm.de> which attempts to detect when the UNIX port is being configured on a system without System V IPC support. This is an optional component on both FreeBSD and Linux systems. Most Linux 2.x kernels ship with it enabled but it is still a real risk. This test may have undesirable side-effects on some hosts. We will address those conflicts as they arise.
* Patch from David Fiddes <D.J.Fiddes@hw.ac.uk>. Comments below:Joel Sherrill1998-07-101-1/+1
| | | | | | | | | | | With a bit of help from Ralf I was able to trace the problem with sed. It was a typo, sed should have had it's params surrounded by 's rather than "s which bash picked up and discarded. The patch is enclosed. Ralf and I aren't sure why configure didn't just stop at this point... The rest of configure/build went OK because there are two sections where the \\-for-/ hack is implemented and the other one is more important and worked just fine.
* Monstrous patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>. I haveJoel Sherrill1998-06-276-34/+167
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | made no attempt to divide the comments up and place them with just the appropriate files. Here is an excerpt from Ralf's email: Changes including comments on changes I made after cycling through all the targets: * Added ranlib support. Now all targets use "ranlib" instead of "ar -s" to build an index for a library. If ranlib isn't detected during configuration, check if ar -s is working and try "ar -s" instead of * Removed $(XXX_FOR_TARGET) from make/target.cfg.in, use $(XXX) instead now. * gcc-target-default.cfg: LINK_XXXX-defines reworked to solve the -l problem under posix (cf gcc-target-default.cfg) * rtems-glom replaced by Makefile-rules inside of the wrapup/Makefile.in that has been using rtems-glom until now. * Removed CCC and friends in gcc-target-default.cfg, as they have been breaking CXX support. * Removed CONFIG.$(TARGET_ARCH).CC lines from several custom/*.cfg files, because this is now set in custom/default.cfg. * Added aclocal/ar-s.m4, check whether "ar -s" is working * Added aclocal/cygwin.m4 and aclocal/exeext.m4. * Reworked aclocal/canonicalize-tools.m4: Added ar -s check; fixes for problems when XXX_FOR_TARGET is given via environment variables (didn't work for gcc until now), adding cygwin check, improved autoconf-cache handling. * Removed -l from make rule dependencies. LINK_LIBS is now allowed to contain -L and -l. LINK_OBJS and LINK_FILES must not contain -L or -l. gcc28 make-exe rules now link using $(LINK_OBJS) $(LINK_LIBS) => Almost all custom/*.cfg are modified. This is very likely to break something because of typos or having missed to edit a file. Open problems, known bugs, things I didn't do: * custom/p4000.cfg seems to be out of date and requires to be reviewed. (JRS NOTE: It is subordinate p4650 and p4600 -- both of which build ok after minor changes.) * custom/psim.cfg needs to be reviewed, I added some changes to it, I am insecure about. (JRS NOTE: psim had a minor problem endif/endef swapped but runs fine.) * rtems-glom.in can now be removed. * gcc*.cfg files "make depend" rules don't honor language specific flags (e.g CXXFLAGS is ignored for *.cc) - Nothing to worry about now, but may cause problems for hosts/targets not using gcc or rtems-add-ons that use external packages. * AFAIS, the no_bsp BSP can't be build anymore, i.e. configure refused to configure for it whatever I tried. * The toplevel and toplevel+1 README files are quite out-dated * cygwin.m4 isn't of much use for rtems. In most cases (cf. aclocal/*.m4) it is worked around by directly using $host_os. I think I'll remove it soon after the next snapshot * Before release the cygwin patch needs to be tested under cygwin. I may have broken/missed something (esp. the sed-pattern to convert \\ into / may be broken). * You should try to build/run the posix-BSP under solaris - I don't expect problems, but I am not 100% sure, esp. with regard to ranlib/ar -s. * You should consider to convert all make/compilers/*.cfg files into make/compilers/*.cfg.in files and let autoconf generate the *.cfg. This may help getting rid of some if/then/else statements and help hard-coding some defines into those files in future and shouldn't disturb now. * Not having installed libc.a/libm.a on a host may still break building rtems, esp. when using -disable-gcc28 as the gcc27-configuration scheme directly accesses libc.a and libm.a. The problem should not appear when using gcc28 because it references libc/libm only through -lc and -lm which may be static or dynamic (I didn't test this). * shgen is not yet included (I didn't yet have enough time to integrate it). * I know about a few more configure-probs (esp. cross-checking --enable-* flags). + warn/refuse to configure when --enable-libcdir and --enable-gcc28 are given. + force --enable-libcdir when --disable-gcc28 is given * Replaced KSHELL with @KSH@ in some shell scripts generated by configure.in. * Added a dependency to aclocal/*.m4 in the toplevel Makefile => configure and aclocal.m4 will now be rebuild when any aclocal/*.m4 file is changed * Some changes to aclocal/gcc-pipe.m4 and aclocal/gcc-specs.m4 * Replaced i[[3456]]86-unknown-freebsd2.[[12]] with i[[3456]]86-*freebsd2.* in configure.in, as I suppose there might exist a variety of valid vendors (2nd field of the name-tripple) * Disabled override MAKEFLAGS in toplevel Makefile.in - Potential side-effects are not really clear to me. * In mvme162.cfg, $(LINK_LIBS) is missing in the CC line in gcc28's make-exe rule (yet another one I missed to edit). Just append $(LINK_LIBS) to the "CC" line, like I hopefully did to ALL other custom/*.cfg files. * the problem with mvme162lx.cfg is a follow-up problem of the mvme162.cfg-bug. * mvme162/console and idp/console had variables named Buffer which conflicted with similarly named variables in some tests.
* Removed SIZE_FOR_TARGET change after Ralf pointed out that gcc doesJoel Sherrill1998-05-221-1/+0
| | | | not properly report it all the time.
* Use gcc to look for size alsoJoel Sherrill1998-05-211-0/+1
* New file from Ralf CorsepiusJoel Sherrill1998-05-211-0/+17
* Patch from Ralf Corseipus to fix latent configure problems suddenly triggered:Joel Sherrill1998-05-203-70/+53
| | | | | | | | | | | | | | | | | | | | | | | The breakdown: * CC_FOR_TARGET and CXX_FOR_TARGET were not correctly re-read from autoconf's configuration cache (config.cache) * If <target>-[gcc|g++] was not found while running configure, the config macros tried to use other (wrong) compilers (e.g. cc). Changes: * New RTEMS_PROG_CC macro (aclocal/prog-cc.m4). * New RTEMS_PROG_CXX macro (aclocal/prog-cxx.m4) * Moved a shell script fragment from configure.in to a new m4-autoconf macro (New file: aclocal/tool-prefix.m4) * Minor changes to configure.in I tested it with linux/posix (native gcc/primary libc) and sh-rtems/gensh1 on a linux host and didn't notice any bugs related to the problems mentioned above. There seem to be more bugs with the posix bsp, but I consider them minor as the build run completed successfully. It is just too late for me to attempt to fix them now.
* Modified to find C++ compilers.Joel Sherrill1998-05-181-6/+0
* Updated now that the phony crt0.c in newlib defines all odd symbolsJoel Sherrill1998-03-232-36/+2
| | | | that gcc automatically generates references to.
* Added enough symbols to the conftest.c program to make sure it wouldJoel Sherrill1998-03-212-3/+34
| | | | successfully link on both the powerpc and hppa1.1.
* Patch from Ralf Corsepius to properly detect that Cygwin32 does notJoel Sherrill1998-03-201-9/+18
| | | | support the -pipe option on the compiler.
* New files missed in previous merge.Joel Sherrill1998-02-195-0/+234
* Update from Ralf Corsepius:Joel Sherrill1998-02-172-5/+4
| | | | | | | 6) The macro files from aclocal/*.m4 contain the buggy sed-rules formerly contained in aclocal..m4, i.e. the sed/sort-bug fix to aclocal.m4 didn't make it to aclocal/*.m4. I think I should feel guilty for that - Obviously I submitted the contents of an old aclocal-directory last time. - Sorry.
* New autoconf feature from Ralf Corsepius:Joel Sherrill1998-02-044-0/+86
It adds make rules for reconfiguring build-trees ("make Makefile") and adds dependency rules for configure and friends (i.e. calls autoconf). Most of this code has been "borrowed" from automake and was adapted to rtems. Addionally, I added automatic generation of the "aclocal.m4"-file by "aclocal" (from the automake package). Therefore I splitted aclocal.m4 into several separate files (attached to this mail), each containing one of rtems customized autoconf/m4-macros and have put them into a new subdirectory "aclocal". Normal users won't be influenced and won't even need this, unless they try to modify configure.in. The main advantage of this is: these aclocal/m4-macros become reusable and easier to administer. As a disadvantage, rtems becomes dependent of having aclocal/automake installed. To keep building rtems functional if autoconf or aclocal isn't installed, the related Makefile commands are prefixed by "-" -- only an error message should be issued by "make".
