* aclocal/rtems-top.m4: Add RTEMS_API.
AC_DEFAULT_PREFIX([/opt/rtems-][RTEMS_API]).
* aclocal/enable-rtems-debug.m4: New (Missed in yesterday's
patches).
* aclocal/enable-tests.m4: Change to support
--enable-tests=no|yes|samples, default is samples.
* aclocal/bsp-arg-enable.m4, aclocal/bsp-configure.m4,
aclocal/bspopts.m4, aclocal/canonicalize-tools.m4,
aclocal/check-bsp-cache.m4, aclocal/check-cxx.m4,
aclocal/check-itron.m4, aclocal/check-multiprocessing.m4,
aclocal/check-networking.m4, aclocal/check-newlib.m4,
aclocal/check-posix.m4, aclocal/check-rdbg.m4,
aclocal/check-tool.m4, aclocal/env-rtemsbsp.m4,
aclocal/gcc-isystem.m4, aclocal/gcc-pipe.m4,
aclocal/gcc-specs.m4, aclocal/i386-gas-code16.m4,
aclocal/path-perl.m4, aclocal/ppc.m4,
aclocal/prog-cc.m4, aclocal/prog-ccas.m4,
aclocal/prog-cxx.m4, aclocal/prog-gnat.m4,
aclocal/rtems-debug.m4, aclocal/rtems-flags.m4,
aclocal/rtems-test-no-pause.m4, aclocal/target.m4:
Remove (Unused).
* automake/leaf.am, automake/force-preinstall.am:
Remove (Unused).
* aclocal/version.m4: Updated to rtems-ss-20030703.
* configure.ac: Remove "BLEEDING EDGE" warning.
Put docs into RTEMS_BUILD_CONFIG_SUBDIRS.
* acinclude.m4: Add AC_PREREQ(2.57).
Major overhaul (PR 412).
* aclocal/prog-cc.m4: Add RTEMS_GCC_ISYSTEM.
* aclocal/gcc-isystem.m4: New.
* Makefile.am: Add aclocal/gcc-isystem.m4.
PR 321:
* aclocal/check-bsp-cache.m4: Remove support for profile-variant.
* aclocal/env-rtemsbsp.m4
* automake/compile.am
* automake/host.am
* automake/local.am
* aclocal/check-cxx.m4: Remove LIBSUFFIX_VA.
* automake/compile.am: Remove LIBSUFFIX_VA.
Merger from rtems-4-6-branch.
* aclocal/version.m4: Updated to rtems-ss-20030417.
* aclocal/version.m4: Updated to rtems-ss-20030411.
* aclocal/version.m4: Updated to rtems-ss-20020411.
* README.configure, aclocal/rtems-cpu-subdirs.m4: Remove a29k
references.
* aclocal/version.m4: Updated to rtems-ss-20030128.
* aclocal/rtems-cpu-subdirs.m4: Print out RTEMS_CPU in error message.
* aclocal/enable-cxx.m4: Use $enable_cxx instead of $enableval.
* aclocal/prog-cxx.m4: Remove RTEMS_PROG_CXX.
Rework RTEMS_PROG_CXX_FOR_TARGET.
* aclocal/prog-cxx.m4: Swap RTEMS_CHECK_TOOL/AC_PROG_CXX.
* aclocal/bsp-configure.m4: Remove RTEMS_CHECK_BSP_CACHE.
* aclocal/env-rtemsbsp.m4: Add comments to AC_ARG_VARs.
Add AC_ARG_VAR(RTEMS_CPU_MODEL).
* aclocal/env-rtemsbsp.m4: Add AC_ARG_VAR for CPU_CFLAGS,
CFLAGS_OPTIMIZE_V, CFLAGS_DEBUG_V, CFLAGS_PROFILE_V, RTEMS_BSP_FAMILY.
* aclocal/prog-cc.m4: Reworked CFLAGS handling.
* aclocal/prog-cxx.m4: Reworked CXXFLAGS handling.
* aclocal/rtems-flags.m4: New.
* aclocal/prog-cc.m4: Remove GCCSED.
* aclocal/prog-ccas.m4: New.
* aclocal/check-custom-bsp.m4: New, split out from check-bsps.m4.
* aclocal/check-bsps.m4: Split out RTEMS_CHECK_CUSTOM_BSP.
* aclocal/canonicalize-tools.m4: Remove RTEMS_GCC_PRINT.
* aclocal/quoting.m4: Reworked (Part of fix to PR 312).
* automake/compile.am: Remove LD_PATHS (Unused).
* aclocal/check-newlib.m4: Adaptation to autoconf-2.5x (AC_TRY_LINK
is announced obsolete).
* aclocal/sysv-ipc.m4: Remove (Unused).
* aclocal/target.m4: Sync with acinclude.m4 (Part of fix to PR 312).
* aclocal/target.m4: Apply RTEMS_CONFIGURE_ARGS_QUOTE (Part of fix
to PR 312).
* aclocal/version.m4: Updated to rtems-ss-20021118.
* aclocal/bsp-alias.m4, aclocal/check-bsps.m4: Added support for
Motorola MTX603e.
* acinclude.m4: Add CXX_FOR_*, CXXFLAGS_FOR_*.
Fix stupid typo (continue/configure).
* aclocal/prog-cc.m4: Remove obsolete comments.
Acknowledge CFLAGS.
* aclocal/version.m4: Updated to rtems-ss-20021111.
Further preparations for autoconf > 2.52:
* aclocal/enable-inlines.m4: Use AS_IF instead of if/then/else.
* aclocal/quoting.m4: Use `eval echo $ac_args` to unquote $ac_arg.
* aclocal/target.m4: Use `eval echo $rtems_args` to unquote $ac_arg.
* aclocal/enable-bare.m4: Improve quoting of AC_HELP_STRING.
* aclocal/enable-cxx.m4: Improve quoting of AC_HELP_STRING.
* aclocal/enable-inlines.m4: Improve quoting of AC_HELP_STRING.
* aclocal/enable-itron.m4: Improve quoting of AC_HELP_STRING.
* aclocal/enable-multiprocessing.m4: Improve quoting of AC_HELP_STRING.
* aclocal/enable-networking.m4: Improve quoting of AC_HELP_STRING.
* aclocal/enable-posix.m4: Improve quoting of AC_HELP_STRING.
* aclocal/enable-rdbg.m4: Improve quoting of AC_HELP_STRING.
* aclocal/enable-rtemsbsp.m4: Improve quoting of AC_HELP_STRING.
* aclocal/enable-tests.m4: Improve quoting of AC_HELP_STRING.
(autoconf > 2.54 seems to have problems with the old form of
quoting).
* aclocal/enable-rtemsbsp.m4: Remove '\' in AC_MSG_ERROR
(autoconf > 2.54 complains about).
* aclocal/version.m4: Updated to rtems-20021021-test.
* aclocal/ppc.m4: Apply RTEMS_CONFIGURE_ARGS_QUOTE.
* aclocal/quoting.m4: New (Implements RTEMS_CONFIGURE_ARGS_QUOTE).
* acinclude.m4: Apply RTEMS_CONFIGURE_ARGS_QUOTE.
* aclocal/version.m4: Updated to rtems-ss-20021007.
* aclocal/version.m4: Updated to rtems-ss-20021004.
* aclocal/bsp-configure.m4: Create bspopts.h on the fly, filter out
autoconf-2.53 PACKAGE crap.
* aclocal/prog-gnat.m4: New.
* aclocal/bsp-configure.m4: Fix small typo in comment.
* aclocal/env-rtemsbsp.m4: RTEMS_ROOT="\$(PROJECT_ROOT)/c/$RTEMS_BSP".
* aclocal/check-bsp-cache.m4: Convert to autoconf-2.5x quoting
rules. Add RTEMS_BSP_CFLAGS, RTEMS_BSP_CFLAGS_OPTIMIZE_V,
RTEMS_BSP_CFLAGS_DEBUG_V, RTEMS_BSP_CFLAGS_PROFILE_V.
* aclocal/version.m4: Updated to rtems-ss-20020807.
* aclocal/env-rtemsbsp.m4: Remove RTEMS_CONFIG_PER_BSP.
* aclocal/rtems-cpu-subdirs.m4: Removed the or16 port
was just a stub and only the OR32 port is getting worked on.
* aclocal/subdirs.m4: Remove.
* acinclude.m4: New (Replaces aclocal/subdirs.m4).
* aclocal/check-cpu.m4: Peek into cpukit/score/cpu instead of
exec/score/cpu.
* aclocal/bsp-configure.m4: Add RTEMS_CHECK_MULTIPROCESSING.
* automake/compile.am: Add test -d $(ARCH) || mkdir $(ARCH) to all
compilation rules (Work-around to an automake bug).
* automake/lib.am: Add test -d $(ARCH) || mkdir $(ARCH) to
make-library.
