to its own top level package.
mkdir c/src/librpc
mkdir c/src/librpc/src
mkdir c/src/librpc/include
rm -rf c/src/lib/librpc
rm -rf c/src/lib/include/rpc
in the required order .
# make[5]: Entering directory
# mips64orion-rtems-gcc -v
# mips64orion-rtems-ld -v
configuration and unix/posix:
c/src/lib/libc/Makefile.in
only (was completely broken).
Linux-posix.cfg.
of other bsp's/CPU.
cd <srcdir>
and
cd c/src/lib; autoconf
or
After upgrading my linux box to the brand new SuSE 6.2 release, which is
glibc-2.1 based, I came across a bug in RTEMS - IIRC, I even warned you
about it about 1/2 a year ago, but nothing has been done since then :-.
The *.m4 macros to check for SYSV/IPC are broken for linux/glibc2.1,
because they assume that linux always defines union semun, which isn't
true anymore for glibc2.1 (the manpage for semctl states _X_OPEN
specifies it this way). Therefore I have tried to implement a more
general approach for handling SYSV for unix/posix which checks for
presence of struct semun, instead of trying to evaluate OS specific
preprocessor symbols.
This approach is a bit adventureous, because I only tested it with
linux/glibc2.1 and linux/libc5, but not under other Unix variants RTEMS
supports. I am quite confident it will work on other hosts, too, but who
knows :-.
[FYI: I think this might also is the cause of some problems with RedHat
6.X / Mandrake linux recently reported on the rtems list -- rtems-4.0.0
can not be build for posix on any glibc2.1 based host]
Furthermore the patch below contains a couple of minor fixes and
configuration cleanups, which IMO should be applied before releasing a
new snapshot.
To apply this patch:
patch -p1 < rtems-rc-19990709-8.diff
in a previous patch.
CHANGES
autoconf check
autoconf check
$(prefix)/<bsp>/make/bsp.cfg
compatible.
Makefile.ins
* I've gone a little ??) further than I had announced before.
> When I run my script that just repeatedly builds different targets, some
> of them die with an error like this:
> Making all RTEMS_BSP=gen68360 in cpugmake[5]: Entering directory
> `/usr1/rtems/build/build-m68k-rtems/c/src/exec/score/cpu'
> Making all RTEMS_BSP=gen68360 in @RTEMS_CPU@
> /bin/sh: @RTEMS_CPU@: No such file or directory
> gmake[5]: *** [all] Error 1
> gmake[5]: Leaving directory
> It is not always the same variable substitution that fails. Sometimes it
> is @INSTALL@. But reliably, it is a variable substitution that is
> failing.
> Do you have any idea why this happens?
Yep, I think I know what's going on.
AC_SUBST(RTEMS_CPU) is missing in configure.ins, thus @RTEMS_CPU@ in
target.cfg.in doesn't get substituted correctly, causing the bug above. Due
to the redundancy of RTEMS_CPU, other most BSPs don't seem to be affected.
Other similar problems probably exist for the unix/posix bsp and the hppa.1
cpu, because their */tools/*Makefile.ams require RTEMS_CPU, too.
Fixes/Changes:
--target=no_cpu*rtems.
before adding :-)
toplevel/configure.in
files changed to RTEMS_CPU
<corsepiu@faw.uni-ulm.de>:
This patch removes MKDIR from RTEMS source tree and fixes another small
bug in the definition of INSTALL_VARIANT (cf. to the patch itself for
details, it should be self-explanatory)
After applying the patch please do:
cvs rm aclocal/mkdir.m4
FYI: I am not talking about using "make -C <dir>", which probably
is much faster on M$ hosts than RTEMS's implementation, but about
removing --enable-gmake-print support and to apply a variant of
automake's subdirectory.
Automake's subdirectory rule seems to be a little bit faster, but I
wouldn't bet on this.
Attached to this mail is my proposal.
After applying the patch, please run
cvs rm aclocal/enable-gmake-print.m4
--enable-tests problem a better way.
preparations for automake.
* aclocal/rtems-top.m4:
configure scripts did not match on the default value of --enable-tests.
releasing a snapshot:
1. Cleanup to aclocal/
cvs rm -f aclocal/cygwin.m4
cvs rm -f aclocal/exeext.m4
2. rtems-rc-19990328-0.diff
Some (minor) bug-fixes:
3. rtems-rc-19990328-1.diff
-ac -am -ci.
(reduces size of configure.in
description follows:
Description:
config.h.ins)
acpolish
configure scripts
Remarks:
[$(prefix)].
issues.
egcs/contrib/egcs_update).
ATTENTION:
* "make RTEMS_BSP=<bsp> dist"
OK, I 've made up my mind to cut a big chunk of my automake-patches (:-).
Below you can find a drop-in replacement of the aclocal directory. It
contains a lot of new macro files, most of them are directly cut from rtems
top-level configure script, some are new some are identical to former
versions. The motivation behind these files is to reuse parts from rtems
current top-level configure.in script in up-coming subdirectory configure.in
scripts.
I'd like to ask you to untar the archive ontop of the source tree and to
add/commit these files to CVS. Adding these files should not have any
influence on RTEMS momentary configuration (except of you are required to
run aclocal -I aclocal && autoconf afterwards), because most of them
currently are not used at all.
BTW: Please upgrade to autoconf-2.13 and automake-2.4, if you havn't done
this already (egcs/CVS require them, too). My upcoming automake files
require automake-2.4 which requires autoconf-2.13 or later.
Moves some configure.in fragments to new macro files below aclocal/
(Motivation: Prepare splitting the toplevel configure.in script)
Here is a cosmetic patch which corrects a few spelling problems in parts
written by me.
Apparently, I must have written these under the influence of ether (:-)
with libchip.
problem report from Erik Ivanenko <erik.ivanenko@utoronto.ca>.
test were suggested by Ian Taylor <ian@airs.com> and Joel did the
hard part of putting it in aclocal and editting all the offending
Makefiles and source code which could use this feature.
If the target is an i386, this test checks whether or not the binutils
is new enough to have good support for code16.
BSDINSTALL=@INSTALL@
in autoconf.
fixed.
<corsepiu@faw.uni-ulm.de> which attempts to detect when the UNIX port
is being configured on a system without System V IPC support. This
is an optional component on both FreeBSD and Linux systems. Most
Linux 2.x kernels ship with it enabled but it is still a real risk.
This test may have undesirable side-effects on some hosts. We will
address those conflicts as they arise.
With a bit of help from Ralf I was able to trace the problem with sed. It
was a typo, sed should have had it's params surrounded by 's rather than "s
which bash picked up and discarded. The patch is enclosed.
Ralf and I aren't sure why configure didn't just stop at this point... The
rest of configure/build went OK because there are two sections where the
\\-for-/ hack is implemented and the other one is more important and worked
just fine.
all the targets:
breaking CXX support.
handling.
after minor changes.)
insecure about.
external packages.
may be broken).
disturb now.
--enable-* flags).
--enable-gcc28 are given.
mvme162.cfg-bug.
not properly report it all the time.
The breakdown:
* CC_FOR_TARGET and CXX_FOR_TARGET were not correctly re-read
from autoconf's configuration cache (config.cache)
* If <target>-[gcc|g++] was not found while running configure,
the config macros tried to use other (wrong) compilers (e.g. cc).
* New RTEMS_PROG_CC macro (aclocal/prog-cc.m4).
* New RTEMS_PROG_CXX macro (aclocal/prog-cxx.m4)
* Moved a shell script fragment from configure.in to a
new m4-autoconf macro (New file: aclocal/tool-prefix.m4)
* Minor changes to configure.in
I tested it with linux/posix (native gcc/primary libc) and
sh-rtems/gensh1 on a linux host and didn't notice any bugs
related to the problems mentioned above. There seem to be
more bugs with the posix bsp, but I consider them minor as
the build run completed successfully. It is just too late
for me to attempt to fix them now.
that gcc automatically generates references to.
successfully link on both the powerpc and hppa1.1.
support the -pipe option on the compiler.
6) The macro files from aclocal/*.m4 contain the buggy sed-rules formerly
contained in aclocal..m4, i.e. the sed/sort-bug fix to aclocal.m4 didn't
make it to aclocal/*.m4. I think I should feel guilty for that - Obviously I
submitted the contents of an old aclocal-directory last time. - Sorry.
It adds make rules for reconfiguring build-trees ("make Makefile") and
adds dependency rules for configure and friends (i.e. calls autoconf).
Most of this code has been "borrowed" from automake and was adapted to
rtems.
Addionally, I added automatic generation of the "aclocal.m4"-file by
"aclocal" (from the automake package). Therefore I splitted aclocal.m4
into several separate files (attached to this mail), each containing one
of rtems customized autoconf/m4-macros and have put them into a new
subdirectory "aclocal". Normal users won't be influenced and won't even
need this, unless they try to modify configure.in.
The main advantage of this is: these aclocal/m4-macros become reusable
and easier to administer. As a disadvantage, rtems becomes dependent of
having aclocal/automake installed. To keep building rtems functional if
autoconf or aclocal isn't installed, the related Makefile commands are
prefixed by "-" -- only an error message should be issued by "make".
