* aclocal/enable-itron.m4: Allow unix.
* aclocal/check-bsps.m4: Use ls instead of globs to pickup
bsp_specs.
* aclocal/check-bsps.m4: Add MVME2100 BSP as alias of
motorola_shared.
* aclocal/bsp-alias.m4: Add MVME2100 BSP as alias of motorola_shared.
* alocal/check-custom-bsp.m4: Reflect new location of bspkit*cfg.
* aclocal/check-bsps.m4: Add bspkit support. Don't check for
presence of *.cfg.
* aclocal/check-custom-bsp.m4: Add bspkit support.
* aclocal/enable-bare.m4: Remove.
* aclocal/rtems-cpu-subdirs.m4: Remove (unused).
* aclocal/version.m4: Updated to rtems-4.6.99.1.
* aclocal/rtems-top.m4: Remove ENDIF.
Remove with_target_subdir defaulting to '.'.
* acinclude.m4: Add --includedir to sub_configure_args.
* aclocal/rtems-top.m4: Sync with c/src/aclocal/rtems-top.m4
* Makefile.am: Cosmetics.
* Makefile.am: DIST_SUBDIRS = $(SUBDIRS).
Rework dist-hook.
* configure.ac: Reflect changes to RTEMS_ENABLE_RTEMSBSP.
* aclocal/enable-rtemsbsp.m4: Add support for --disable-rtemsbsp.
* VERSION: 4.6.99.0.
* aclocal/version.m4: 4.6.99.0.
* aclocal/bsp-alias.m4: Readd aliases for p4600 and p4650
which were accidentally removed when purging the mips64orion.
* aclocal/rpm.m4: Make osversions the default.
* aclocal/rtems-top.m4: Remove check for version.m4 (Breaks make
distcheck).
* aclocal/rpms.m4: New (extracted from scripts/configure.ac).
* configure.ac: Require automake >= 1.8.2.
* aclocal/check-bsps.m4: Also test for make/custom/*.cfg.
* aclocal/bsp-alias.m4, aclocal/rtems-cpu-subdirs.m4: mips64orion port
removed as mips port more completely covers the MIPS family.
* aclocal/version.m4: Updated to rtems-20031217-test.
* aclocal/bsp-alias.m4, aclocal/canonical-target-name.m4,
aclocal/check-bsps.m4, aclocal/check-custom-bsp.m4,
aclocal/enable-bare.m4, aclocal/enable-cxx.m4,
aclocal/enable-inlines.m4, aclocal/enable-itron.m4,
aclocal/enable-multiprocessing.m4, aclocal/enable-networking.m4,
aclocal/enable-posix.m4, aclocal/enable-rdbg.m4,
aclocal/enable-rtems-debug.m4, aclocal/enable-rtemsbsp.m4,
aclocal/enable-tests.m4, aclocal/multilib.m4,
aclocal/path-ksh.m4, aclocal/project-root.m4,
aclocal/rtems-top.m4, aclocal/tool-paths.m4,
acinclude.m4:
Fix underquoting to silence automake-1.8.
* aclocal/config-subdirs.m4: Remove.
* aclocal/canonical-host.m4: Remove.
* aclocal/check-cpu.m4: Remove.
* Makefile.am: Remove reference to aclocal/check-cpu.m4.
* acinclude.m4 (RTEMS_TARGET_CONFIG_SUBDIR): Check for presence of
$1 in $srcdir before adding dir to SUBDIRS.
* README.configure, aclocal/rtems-cpu-subdirs.m4: Removing HPPA port.
* aclocal/rtems-top.m4: Add RTEMS_API.
AC_DEFAULT_PREFIX([/opt/rtems-][RTEMS_API]).
* aclocal/enable-rtems-debug.m4: New (Missed in yesterday's
patches).
* aclocal/enable-tests.m4: Change to support
--enable-tests=no|yes|samples, default is samples.
* aclocal/bsp-arg-enable.m4, aclocal/bsp-configure.m4,
aclocal/bspopts.m4, aclocal/canonicalize-tools.m4,
aclocal/check-bsp-cache.m4, aclocal/check-cxx.m4,
aclocal/check-itron.m4, aclocal/check-multiprocessing.m4,
aclocal/check-networking.m4, aclocal/check-newlib.m4,
aclocal/check-posix.m4, aclocal/check-rdbg.m4,
aclocal/check-tool.m4, aclocal/env-rtemsbsp.m4,
aclocal/gcc-isystem.m4, aclocal/gcc-pipe.m4,
aclocal/gcc-specs.m4, aclocal/i386-gas-code16.m4,
aclocal/path-perl.m4, aclocal/ppc.m4,
aclocal/prog-cc.m4, aclocal/prog-ccas.m4,
aclocal/prog-cxx.m4, aclocal/prog-gnat.m4,
aclocal/rtems-debug.m4, aclocal/rtems-flags.m4,
aclocal/rtems-test-no-pause.m4, aclocal/target.m4:
Remove (Unused).
* automake/leaf.am, automake/force-preinstall.am:
Remove (Unused).
* aclocal/version.m4: Updated to rtems-ss-20030703.
* configure.ac: Remove "BLEEDING EDGE" warning.
Put docs into RTEMS_BUILD_CONFIG_SUBDIRS.
* acinclude.m4: Add AC_PREREQ(2.57).
Major overhaul (PR 412).
* aclocal/prog-cc.m4: Add RTEMS_GCC_ISYSTEM.
* aclocal/gcc-isystem.m4: New.
* Makefile.am: Add aclocal/gcc-isystem.m4.
PR 321:
* aclocal/check-bsp-cache.m4: Remove support for profile-variant.
* aclocal/env-rtemsbsp.m4
* automake/compile.am
* automake/host.am
* automake/local.am
* aclocal/check-cxx.m4: Remove LIBSUFFIX_VA.
* automake/compile.am: Remove LIBSUFFIX_VA.
Merger from rtems-4-6-branch.
* aclocal/version.m4: Updated to rtems-ss-20030417.
* aclocal/version.m4: Updated to rtems-ss-20030411.
* aclocal/version.m4: Updated to rtems-ss-20020411.
* README.configure, aclocal/rtems-cpu-subdirs.m4: Remove a29k
references.
* aclocal/version.m4: Updated to rtems-ss-20030128.
* aclocal/rtems-cpu-subdirs.m4: Print out RTEMS_CPU in error message.
* aclocal/enable-cxx.m4: Use $enable_cxx instead of $enableval.
* aclocal/prog-cxx.m4: Remove RTEMS_PROG_CXX.
Rework RTEMS_PROG_CXX_FOR_TARGET.
* aclocal/prog-cxx.m4: Swap RTEMS_CHECK_TOOL/AC_PROG_CXX.
* aclocal/bsp-configure.m4: Remove RTEMS_CHECK_BSP_CACHE.
* aclocal/env-rtemsbsp.m4: Add comments to AC_ARG_VARs.
Add AC_ARG_VAR(RTEMS_CPU_MODEL).
* aclocal/env-rtemsbsp.m4: Add AC_ARG_VAR for CPU_CFLAGS,
CFLAGS_OPTIMIZE_V, CFLAGS_DEBUG_V, CFLAGS_PROFILE_V, RTEMS_BSP_FAMILY.
* aclocal/prog-cc.m4: Reworked CFLAGS handling.
* aclocal/prog-cxx.m4: Reworked CXXFLAGS handling.
* aclocal/rtems-flags.m4: New.
* aclocal/prog-cc.m4: Remove GCCSED.
* aclocal/prog-ccas.m4: New.
* aclocal/check-custom-bsp.m4: New, split out from check-bsps.m4.
* aclocal/check-bsps.m4: Split out RTEMS_CHECK_CUSTOM_BSP.
* aclocal/canonicalize-tools.m4: Remove RTEMS_GCC_PRINT.
* aclocal/quoting.m4: Reworked (Part of fix to PR 312).
* automake/compile.am: Remove LD_PATHS (Unused).
* aclocal/check-newlib.m4: Adaptation to autoconf-2.5x (AC_TRY_LINK
is announced obsolete).
* aclocal/sysv-ipc.m4: Remove (Unused).
* aclocal/target.m4: Sync with acinclude.m4 (Part of fix to PR 312).
