* aclocal/prog-cc.m4: Remove GCC272 support.
Remove ENABLE_LIBCDIR.
* aclocal/prog-cxx.m4: Ditto.
* aclocal/enable-gcc28.m4: Remove.
* aclocal/enable-libcdir.m4: Ditto.
* aclocal/enable-libcdir.m4, aclocal/enable-gcc28.m4: Remove
ENABLE_GCC28.
* aclocal/version.m4: New file.
* aclocal/rtems-top.m4: Add RTEMS_VERSIONING, replace VERSION w/
aclocal/version.m4.
* bootstrap: Use aclocal/version.m4 instead of VERSION.
* configure.ac: Use aclocal/version.m4 instead of VERSION.
aclocal/version.m4.
* aclocal/env-rtemscpu.m4: automake-1.6 preparations:
Add AM_CONDITIONAL([RTEMS_CONFIG_PER_BSP],[false]).
* aclocal/subdirs.m4: Propagate the current $prefix to the
sub-configures.
* aclocal/sysv-ipc.m4: Use 3-args AC_DEFINE for autoconf-2.5x
compatibility.
* bootstrap: Let --clean remove texinfo.tex.
* aclocal/env-rtemsbsp.m4: Use ${RTEMS_BSP} to setup includedir.
* aclocal/check-tool.m4: Remove AC_CHECK_TOOL_PREFIX, conditionalize
check upon host_alias != build_alias.
* aclocal/check-newlib.m4: Apply AS_IF.
* aclocal/config-subdirs.m4: Remove _RTEMS_PUSH_BUILDDIR,
_RTEMS_POP_BUILDDIR, _RTEMS_GIVEN_INSTALL, _RTEMS_SUB_SRCDIR.
* aclocal/subdirs.m4: Fix comments, apply AS_IF.
* aclocal/sysv-ipc.m4: Reflect autoconf-2.5x canonicalization
changes.
* aclocal/target.m4: Add _RTEMS_PUSH_BUILDDIR, _RTEMS_POP_BUILDDIR,
* automake/compile.am: Remove librtemsall from LINK_FILES.
* configure.ac: Reworked for multilibs, reflect changes to aclocal/*.m4.
* aclocal/subdirs.m4: New file.
* aclocal/multi.m4: New file, adopted from autoconf-2.52 w/
modifications.
* aclocal/check-posix.m4: Apply AS_IF.
* aclocal/config-subdirs.m4: Reflect changes to other m4-macros.
* aclocal/env-rtemsbsp.m4: Add PROJECT_INCLUDE, PROJECT_RELEASE.
Add AM_CONDITIONAL(MULTILIB). Adapt GCC_SPECS to multilibs.
* aclocal/env-rtemscpu.m4: Remove RTEMS_BSP. Add support for
MULTIBUILDTOP, MULTISUBDIR. Adapt GCC_SPECS to multilibs.
Add PROJECT_INCLUDE, PROJECT_RELEASE, includedir, libdir.
* aclocal/multilib.m4: Fix m4-quoting, adopt automake-1.5's
OUTPUT_COMMANDS.
* aclocal/project-root.m4: Remove PROJECT_INCLUDE, PROJECT_RELEASE.
* aclocal/rtems-debug.m4: Minor cleanups.
* aclocal/rtems-top.m4: Minor cleanups.
* automake/compile.am: Further steps towards automake's rules.
* aclocal/bsp-configure.m4: New file.
* Makefile.am: Add aclocal/bsp-configure.m4.
* aclocal/bsp-alias.m4: Remove score603e_g1.
* aclocal/check-bsps.m4: Remove score603e_g1.
* aclocal/prog-cc.m4: Apply m4_if.
* automake/force-preinstall.am: New file.
* aclocal/ppc.m4: New file.
* aclocal/check-bsps.m4: Reworked.
* aclocal/bsp-alias.m4: Add score603e_g1, apply m4sugar.
* aclocal/bspopts.m4: New file.
* aclocal/check-rdbg.m4: Fix latent bug exposed by removal of
config.cache's which prevented powerpc targets librdbg from building.
* aclocal/rtems-cpu-subdirs.m4: Add PREFIX arg to RTEMS_CPU_SUBDIRS,
add 2nd arg to _RTEMS_CPU_SUBDIR.
* aclocal/target.m4: Replace ac_configure_args with
rtems_configure_args, add rtems_configure_args to INIT-CMDS.
* aclocal/rtems-cpu-subdirs.m4: New file.
* aclocal/canonical-target-name.m4: Use AC_CANONICAL_TARGET instead
of AC_CANONICAL_SYSTEM.
* aclocal/config-subdirs.m4: Use AS_MKDIR_P instead of
mkinstalldirs and mkdir.
* aclocal/target.m4: Obsolete RTEMS_OUTPUT_BUILD_SUBDIRS,
hack RTEMS_CONFIG_BUILD_SUBDIRS, introduce
_RTEMS_OUTPUT_BUILD_SUBDIRS.
* configure.in: autoupdate to autoconf-2.52.
* bootstrap: Add handling for configure.ac, make autoheader verbose,
fix auto*tool invocation order.
* aclocal/rtems-test-no-pause.m4: Introduce AC_HELP_STRING.
* aclocal/enable-bare.m4: Introduce AC_HELP_STRING.
* aclocal/enable-cxx.m4: Introduce AC_HELP_STRING.
* aclocal/enable-gcc28: Introduce AC_HELP_STRING.
* aclocal/enable-inlines.m4: Introduce AC_HELP_STRING.
* aclocal/enable-itron.m4: Introduce AC_HELP_STRING.
* aclocal/enable-libcdir.m4: Introduce AC_HELP_STRING.
* aclocal/enable-multiprocessing.m4: Introduce AC_HELP_STRING.
* aclocal/enable-networking.m4: Introduce AC_HELP_STRING.
* aclocal/enable-posix.m4: Introduce AC_HELP_STRING.
* aclocal/enable-rdbg.m4: Introduce AC_HELP_STRING.
* aclocal/enable-rtemsbsp.m4: Introduce AC_HELP_STRING.
* aclocal/enable-tests.m4: Introduce AC_HELP_STRING.
* aclocal/env-rtemsbsp.m4: Add AC_ARC_VAR(RTEMS_BSP), apply true in
RTEMS_CONFIG_PER_BSP conditional.
* aclocal/multilib.m4: Introduce AC_HELP_STRING.
* aclocal/rtems-debug.m4: Introduce AC_HELP_STRING.
* aclocal/rtems-top.m4: Add AC_PREFIX_DEFAULT(/opt/rtems).
* canonical-target-name.m4: Fix m4-quoting for autoconf-2.49f.
* aclocal/config-subdirs.m: Fix m4-quoting for autoconf-2.49f,
Add support for DOS-drive-letters.
* aclocal/prog-cc.m4: Add CPPFLAGS and CFLAGS handling to
RTEMS_PROG_CC_FOR_TARGET.
* aclocal/check-rdbg.m4: Added check to determine which PowerPC
BSPs support the new exception processing model and
consequently, librdbg.
* aclocal/config-subdirs.m4: Let CC default to $host_alias-gcc in
TARGET_CONFIG_SUBDIRS.
* aclocal/enable-bsp.m4: fix quoting.
* aclocal/check-bsps.m4, aclocal/bsp-alias.m4: Add pc386dx.
* aclocal/config-subdirs.m4: New file.
* aclocal/target.m4: Use macros from config-subdirs.m4.
* aclocal/env-rtemsbsp.m4, aclocal/env-rtemscpu.m4:
Add -B$(PROJECT_ROOT)/ to GCC_SPECS.
* configre.in: Fix AM_INIT_AUTOMAKE.
* aclocal/bsp-arg-enable.m4: Extend comments.
* aclocal/check-bsps.m4: Remove extraneous comments, add test -d in
the default clause.
* aclocal/enable-rtemsbsp.m4: Split out RTEMS_ENV_RTEMSBSP,
RTEMS_ENV_RTEMSCPU.
* aclocal/env-rtemsbsp.m4: New file for RTEMS_ENV_RTEMSBSP, add
special treatment for GCC_SPECS.
* aclocal/env-rtemscpu.m4: New file for RTEMS_ENV_RTEMSCPU, add
* aclocal/bsp-enable-arg.m4: New file, introduce RTEMS_BSP_ARG_ENABLE.
* aclocal/prog-cc.m4: Add AC_PROG_CPP, use build_os in GCCSED hack.
* automake/compile.am: New treatment of CPP, GCCSPECS, use `..`
instead of $(shell ..) for LIBC_LIB*.
* aclocal/bsp-alias.m4, aclocal/check-bsps.m4: Add simsh7032 and
simsh7045.
* aclocal/canonical-host.m4: Abandon changequotes (autoconf-2.49b).
* aclocal/check-newlib.m4: Let check message refer to RTEMS newlib.
* aclocal/rtems-debug.m4: Fix formating and contents of the check's
help string.
* aclocal/rtems-top.m4: Remove AC_ARG_WITH(target-subdir).
* README.configure, aclocal/bsp-alias.m4, aclocal/check-bsps.m4:
Modified to reflect addition of LEON BSPs as well as the
no-FP ERC32 variant.
* aclocal/gcc-pipe.m4: Use $GCC instead of ac_cv_prog_gcc (autoconf
standard).
* aclocal/gcc-specs.m4: Use $GCC instead of ac_cv_prog_gcc (autoconf
standard).
* aclocal/multilib.m4: Fix m4-quoting (BUG-FIX).
* aclocal/check-bsp-cache.m4: Fix m4-quoting (autoconf-2.49b).
* aclocal/prog-cc.m4: Use $GCC instead of ac_cv_prog_gcc (autoconf
standard), replace CC_FOR_TARGET with CC (BUG-FIX).
* aclocal/enable-itron.m4: Remove changequotes (autoconf-2.49b).
* aclocal/enable-posix.m4: Remove changequotes (autoconf-2.49b), use
$host instead of $target (BUG-FIX).
* configure.in: Use $target and $host instead of $target_alias and
$host_alias (autoconf-2.49b).
* aclocal/check-newlib.m4: Remove CC_FOR_TARGET (BUG-FIX)
* aclocal/sysv-ipc.m4: Move AC_DEFINE outside of AC_CACHE (BUG-FIX)
NOTES:
* autoconf-2.49b depredicates using changequotes.
* The changes to configure.in are due to cleanups in
autoconf-2.49b's implemention of canonicalization. With
autoconf-2.1x it wasn't always clear, when to use $xxx or
$xxx_alias. Now this is clear.
* aclocal/canonicalize-tools.m4, aclocal/check-tool.m4,
aclocal/prog-cc.m4, aclocal/prog-cxx.m4: Replace AC_CHECK_TOOL
with an RTEMS specific but more restrictive autoconf macro.
* aclocal/canonicalize-tools.m4: Remove RTEMS_PATH_TOOL, use
AC_CHECK_TOOL instead of RTEMS_PATH_TOOL in RTEMS_CANONICALIZE_TOOLS.
* aclocal/*: Replace with contents of macros/*.m4
* macros/: Remove.
* aclocal/ar-s.m4 aclocal/tool-prefix.m4: Remove.
* Makefile.am: Reflect changes to aclocal/ and macros/.
* macros/enable-hwapi.m4: Removed.
* aclocal/rtems-top.m4, automake/compile.am, automake/lib.am:
A small cleanup step towards gnu-canonicalization.
* aclocal/enable-hwapi.m4: Now longer used and removed.
* aclocal/rtems-top.m4: Add ENDIF-hack.
* automake/compile.am: Add include $(DEPENDS) + ENDIF-hack.
* aclocal/check-cxx.m4: Add AC_SUBST(CPLUS_LD_LIBS)
* aclocal/prog-cc.m4: Cleanup comments, require RTEMS_ENABLE_GCC28,
add automake conditionals RTEMS_USE_GCC, RTEMS_USE_GCC272.
* automake/compile.am: Replaced.
* automake/local.am: Remove building variant handling.
* aclocal/enable-rtemsbsp.m4: Add RTEMS_ENABLE_BARE,
AC_SUBST(BARE_CPU_MODEL),AC_SUBST(BARE_CPU_CFLAGS).
* aclocal/i386-gas-code16.m4: AC_DEFINE NEW_GAS.
* aclocal/target.m4: Cleanup comments
* Automake/compile.am: Add DEFS support to keep building happy.
* aclocal/project-root.m4: Introduce PROJECT_TOPdir, add comments.
* aclocal/check-bsps.m4: Fix c4* and sim68000 entries
* make/custom/pck6.cfg: New file
* make/custom/pc486.cfg: Use -m486
* make/custom/pc586.cfg: Use -mpentium
* make/custom/pc686.cfg: Use -mmpentiumpro
* make/custom/i386ex.cfg: Use -msoft-float
* aclocal/check-bsps.h:
- Add pck6-BSP
- Exclude ChangeLog from being picked up as BSP
* aclocal/bsp-alias.m4: Add pck6-BSP
alias simcpu32 that supports the CPU32 simulator in BSVC. At this
point, it is still under development.
that is an improvement in the version handling macro that compensates
for Joel's bug in the release script which broke the VERSION file format.
