path: root/aclocal (follow)
* 2002-04-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-172-13/+4
| | | | | | | | * aclocal/prog-cc.m4: Remove GCC272 support. Remove ENABLE_LIBCDIR. * aclocal/prog-cxx.m4: Ditto. * aclocal/enable-gcc28.m4: Remove. * aclocal/enable-libcdir.m4: Ditto.
* 2002-04-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-162-24/+0
| | | | | * aclocal/enable-libcdir.m4, aclocal/enable-gcc28.m4: Remove ENABLE_GCC28.
* 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-03-281-0/+2
| | | | | | | | * aclocal/version.m4: New file. * aclocal/rtems-top.m4: Add RTEMS_VERSIONING, replace VERSION w/ aclocal/version.m4. * bootstrap: Use aclocal/version.m4 instead of VERSION. * configure.ac: Use aclocal/version.m4 instead of VERSION.
* 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-03-281-12/+5
* 2002-03-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-03-151-0/+1
| | | | | * aclocal/env-rtemscpu.m4: automake-1.6 preparations: Add AM_CONDITIONAL([RTEMS_CONFIG_PER_BSP],[false]).
* 2002-02-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-02-061-1/+5
| | | | | * aclocal/subdirs.m4: Propagate the current $prefix to the sub-configures.
* 2002-01-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-241-1/+1
| | | | | | * aclocal/sysv-ipc.m4: Use 3-args AC_DEFINE for autoconf-2.5x compatibility. * bootstrap: Let --clean remove texinfo.tex.
* 2002-01-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-221-1/+1
| | | | * aclocal/env-rtemsbsp.m4: Use ${RTEMS_BSP} to setup includedir.
* 2002-02-07 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-081-3/+4
| | | | | * aclocal/check-tool.m4: Remove AC_CHECK_TOOL_PREFIX, conditionalize check upon host_alias != build_alias.
* 2002-02-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-065-107/+109
| | | | | | | | | | | | * aclocal/check-newlib.m4: Apply AS_IF. * aclocal/config-subdirs.m4: Remove _RTEMS_PUSH_BUILDDIR, _RTEMS_POP_BUILDDIR, _RTEMS_GIVEN_INSTALL, _RTEMS_SUB_SRCDIR. * aclocal/subdirs.m4: Fix comments, apply AS_IF. * aclocal/sysv-ipc.m4: Reflect autoconf-2.5x canonicalization changes. * aclocal/target.m4: Add _RTEMS_PUSH_BUILDDIR, _RTEMS_POP_BUILDDIR, _RTEMS_GIVEN_INSTALL, _RTEMS_SUB_SRCDIR. * automake/compile.am: Remove librtemsall from LINK_FILES.
* 2001-12-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-12-2010-198/+499
| | | | | | | | | | | | | | | | | | | | * configure.ac: Reworked for multilibs, reflect changes to aclocal/*.m4. * aclocal/subdirs.m4: New file. * aclocal/multi.m4: New file, adopted from autoconf-2.52 w/ modifications. * aclocal/check-posix.m4: Apply AS_IF. * aclocal/config-subdirs.m4: Reflect changes to other m4-macros. * aclocal/env-rtemsbsp.m4: Add PROJECT_INCLUDE, PROJECT_RELEASE. Add AM_CONDITIONAL(MULTILIB). Adapt GCC_SPECS to multilibs. * aclocal/env-rtemscpu.m4: Remove RTEMS_BSP. Add support for MULTIBUILDTOP, MULTISUBDIR. Adapt GCC_SPECS to multilibs. Add PROJECT_INCLUDE, PROJECT_RELEASE, includedir, libdir. * aclocal/multilib.m4: Fix m4-quoting, adopt automake-1.5's OUTPUT_COMMANDS. * aclocal/project-root.m4: Remove PROJECT_INCLUDE, PROJECT_RELEASE. * aclocal/rtems-debug.m4: Minor cleanups. * aclocal/rtems-top.m4: Minor cleanups. * automake/compile.am: Further steps towards automake's rules.
* 2001-11-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-12-031-0/+17
| | | | | * aclocal/bsp-configure.m4: New file. * Makefile.am: Add aclocal/bsp-configure.m4.
* 2001-11-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-11-213-3/+1
| | | | | | * aclocal/bsp-alias.m4: Remove score603e_g1. * aclocal/check-bsps.m4: Remove score603e_g1. * aclocal/prog-cc.m4: Apply m4_if.
* 2001-11-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-11-201-0/+111
| | | | | * automake/force-preinstall.am: New file. * aclocal/ppc.m4: New file.
* 2001-11-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-11-152-26/+20
| | | | | * aclocal/check-bsps.m4: Reworked. * aclocal/bsp-alias.m4: Add score603e_g1, apply m4sugar.
* 2001-11-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-11-141-0/+66
| | | | * aclocal/bspopts.m4: New file.
* 2001-10-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-171-6/+2
| | | | | * aclocal/check-rdbg.m4: Fix latent bug exposed by removal of config.cache's which prevented powerpc targets librdbg from building.
* 2001-10-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-172-20/+22
| | | | | | | | * aclocal/rtems-cpu-subdirs.m4: Add PREFIX arg to RTEMS_CPU_SUBDIRS, add 2nd arg to _RTEMS_CPU_SUBDIR. * aclocal/target.m4: Replace ac_configure_args with rtems_configure_args, add rtems_configure_args to INIT-CMDS. * Makefile.am: Require automake-1.5.
* 2001-10-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-101-0/+31
| | | | * aclocal/rtems-cpu-subdirs.m4: New file.
* 2001-09-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-143-34/+43
| | | | | | | | | | * aclocal/canonical-target-name.m4: Use AC_CANONICAL_TARGET instead of AC_CANONICAL_SYSTEM. * aclocal/config-subdirs.m4: Use AS_MKDIR_P instead of mkinstalldirs and mkdir. * aclocal/target.m4: Obsolete RTEMS_OUTPUT_BUILD_SUBDIRS, hack RTEMS_CONFIG_BUILD_SUBDIRS, introduce _RTEMS_OUTPUT_BUILD_SUBDIRS.
* 2001-07-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-1317-21/+25
| | | | | | | | | | | | | | | | | | | | | | | | * configure.in: autoupdate to autoconf-2.52. * bootstrap: Add handling for configure.ac, make autoheader verbose, fix auto*tool invocation order. * aclocal/rtems-test-no-pause.m4: Introduce AC_HELP_STRING. * aclocal/enable-bare.m4: Introduce AC_HELP_STRING. * aclocal/enable-cxx.m4: Introduce AC_HELP_STRING. * aclocal/enable-gcc28: Introduce AC_HELP_STRING. * aclocal/enable-inlines.m4: Introduce AC_HELP_STRING. * aclocal/enable-itron.m4: Introduce AC_HELP_STRING. * aclocal/enable-libcdir.m4: Introduce AC_HELP_STRING. * aclocal/enable-multiprocessing.m4: Introduce AC_HELP_STRING. * aclocal/enable-networking.m4: Introduce AC_HELP_STRING. * aclocal/enable-posix.m4: Introduce AC_HELP_STRING. * aclocal/enable-rdbg.m4: Introduce AC_HELP_STRING. * aclocal/enable-rtemsbsp.m4: Introduce AC_HELP_STRING. * aclocal/enable-tests.m4: Introduce AC_HELP_STRING. * aclocal/env-rtemsbsp.m4: Add AC_ARC_VAR(RTEMS_BSP), apply true in RTEMS_CONFIG_PER_BSP conditional. * aclocal/multilib.m4: Introduce AC_HELP_STRING. * aclocal/rtems-debug.m4: Introduce AC_HELP_STRING. * aclocal/rtems-top.m4: Add AC_PREFIX_DEFAULT(/opt/rtems).
* 2001-05-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-05-242-14/+10
| | | | | | * canonical-target-name.m4: Fix m4-quoting for autoconf-2.49f. * aclocal/config-subdirs.m: Fix m4-quoting for autoconf-2.49f, Add support for DOS-drive-letters.
* 2001-04-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-05-071-0/+6
| | | | | * aclocal/prog-cc.m4: Add CPPFLAGS and CFLAGS handling to RTEMS_PROG_CC_FOR_TARGET.
* 2001-04-20 Eric Valette <valette@crf.canon.fr>Joel Sherrill2001-04-201-0/+21
| | | | | | * aclocal/check-rdbg.m4: Added check to determine which PowerPC BSPs support the new exception processing model and consequently, librdbg.
* 2001-02-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-02-214-3/+4
| | | | | | | * aclocal/config-subdirs.m4: Let CC default to $host_alias-gcc in TARGET_CONFIG_SUBDIRS. * aclocal/enable-bsp.m4: fix quoting. * aclocal/check-bsps.m4, aclocal/bsp-alias.m4: Add pc386dx.
* 2001-02-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-02-052-45/+254
| | | | | | * aclocal/config-subdirs.m4: New file. * aclocal/target.m4: Use macros from config-subdirs.m4.
* 2001-02-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-02-022-2/+2
| | | | | * aclocal/env-rtemsbsp.m4, aclocal/env-rtemscpu.m4: Add -B$(PROJECT_ROOT)/ to GCC_SPECS.
* 2001-02-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-02-022-8/+8
| | | | | | | * configre.in: Fix AM_INIT_AUTOMAKE. * aclocal/bsp-arg-enable.m4: Extend comments. * aclocal/check-bsps.m4: Remove extraneous comments, add test -d in the default clause.
* 2001-01-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-01-295-45/+83
| | | | | | | | | | | | | * aclocal/enable-rtemsbsp.m4: Split out RTEMS_ENV_RTEMSBSP, RTEMS_ENV_RTEMSCPU. * aclocal/env-rtemsbsp.m4: New file for RTEMS_ENV_RTEMSBSP, add special treatment for GCC_SPECS. * aclocal/env-rtemscpu.m4: New file for RTEMS_ENV_RTEMSCPU, add special treatment for GCC_SPECS. * aclocal/bsp-enable-arg.m4: New file, introduce RTEMS_BSP_ARG_ENABLE. * aclocal/prog-cc.m4: Add AC_PROG_CPP, use build_os in GCCSED hack. * automake/compile.am: New treatment of CPP, GCCSPECS, use `..` instead of $(shell ..) for LIBC_LIB*.
* 2001-01-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-01-222-0/+3
| | | | | * aclocal/bsp-alias.m4, aclocal/check-bsps.m4: Add simsh7032 and simsh7045.
* 2000-11-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-154-19/+10
| | | | | | | | * aclocal/canonical-host.m4: Abandon changequotes (autoconf-2.49b). * aclocal/check-newlib.m4: Let check message refer to RTEMS newlib. * aclocal/rtems-debug.m4: Fix formating and contents of the check's help string. * aclocal/rtems-top.m4: Remove AC_ARG_WITH(target-subdir).
* 2000-11-13 Jiri Gaisler <jgais@ws.estec.esa.nl>Joel Sherrill2000-11-132-0/+5
| | | | | | * README.configure, aclocal/bsp-alias.m4, aclocal/check-bsps.m4: Modified to reflect addition of LEON BSPs as well as the no-FP ERC32 variant.
* 2000-11-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-095-10/+10
| | | | | | | | | | | * aclocal/gcc-pipe.m4: Use $GCC instead of ac_cv_prog_gcc (autoconf standard). * aclocal/gcc-specs.m4: Use $GCC instead of ac_cv_prog_gcc (autoconf standard). * aclocal/multilib.m4: Fix m4-quoting (BUG-FIX). * aclocal/check-bsp-cache.m4: Fix m4-quoting (autoconf-2.49b). * aclocal/prog-cc.m4: Use $GCC instead of ac_cv_prog_gcc (autoconf standard), replace CC_FOR_TARGET with CC (BUG-FIX).
* 2000-11-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-094-16/+9
| | | | | | | | | | | | | | | | | * aclocal/enable-itron.m4: Remove changequotes (autoconf-2.49b). * aclocal/enable-posix.m4: Remove changequotes (autoconf-2.49b), use $host instead of $target (BUG-FIX). * configure.in: Use $target and $host instead of $target_alias and $host_alias (autoconf-2.49b). * aclocal/check-newlib.m4: Remove CC_FOR_TARGET (BUG-FIX) * aclocal/sysv-ipc.m4: Move AC_DEFINE outside of AC_CACHE (BUG-FIX) NOTES: * autoconf-2.49b depredicates using changequotes. * The changes to configure.in are due to cleanups in autoconf-2.49b's implemention of canonicalization. With autoconf-2.1x it wasn't always clear, when to use $xxx or $xxx_alias. Now this is clear.
* 2000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-031-0/+10
| | | | | | * aclocal/canonicalize-tools.m4, aclocal/check-tool.m4, aclocal/prog-cc.m4, aclocal/prog-cxx.m4: Replace AC_CHECK_TOOL with an RTEMS specific but more restrictive autoconf macro.
* 2000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-023-16/+12
* 2000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-021-44/+3
| | | | | * aclocal/canonicalize-tools.m4: Remove RTEMS_PATH_TOOL, use AC_CHECK_TOOL instead of RTEMS_PATH_TOOL in RTEMS_CANONICALIZE_TOOLS.
* 2000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-0215-263/+99
| | | | | | | * aclocal/*: Replace with contents of macros/*.m4 * macros/: Remove. * aclocal/ar-s.m4 aclocal/tool-prefix.m4: Remove. * Makefile.am: Reflect changes to aclocal/ and macros/.
* 2000-10-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-241-0/+3
| | | | | | * macros/enable-hwapi.m4: Removed. * aclocal/rtems-top.m4, automake/compile.am, automake/lib.am: A small cleanup step towards gnu-canonicalization.
* 2000-09-14 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-141-15/+0
| | | | * aclocal/enable-hwapi.m4: Now longer used and removed.
* 2000-09-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-131-0/+4
| | | | | * aclocal/rtems-top.m4: Add ENDIF-hack. * automake/compile.am: Add include $(DEPENDS) + ENDIF-hack.
* 2000-09-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-122-2/+13
| | | | | | | | * aclocal/check-cxx.m4: Add AC_SUBST(CPLUS_LD_LIBS) * aclocal/prog-cc.m4: Cleanup comments, require RTEMS_ENABLE_GCC28, add automake conditionals RTEMS_USE_GCC, RTEMS_USE_GCC272. * automake/compile.am: Replaced. * automake/local.am: Remove building variant handling.
* 2000-09-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-123-3/+7
| | | | | | | | * aclocal/enable-rtemsbsp.m4: Add RTEMS_ENABLE_BARE, AC_SUBST(BARE_CPU_MODEL),AC_SUBST(BARE_CPU_CFLAGS). * aclocal/i386-gas-code16.m4: AC_DEFINE NEW_GAS. * aclocal/target.m4: Cleanup comments * Automake/compile.am: Add DEFS support to keep building happy.
* 2000-09-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-061-3/+23
| | | | * aclocal/project-root.m4: Introduce PROJECT_TOPdir, add comments.
* 2000-08-31 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-011-2/+2
| | | | * aclocal/check-bsps.m4: Fix c4* and sim68000 entries
* 2000-08-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-08-252-1/+3
| | | | | | | | | | | | * make/custom/pck6.cfg: New file * make/custom/pc486.cfg: Use -m486 * make/custom/pc586.cfg: Use -mpentium * make/custom/pc686.cfg: Use -mmpentiumpro * make/custom/i386ex.cfg: Use -msoft-float * aclocal/check-bsps.h: - Add pck6-BSP - Exclude ChangeLog from being picked up as BSP * aclocal/bsp-alias.m4: Add pck6-BSP
* Added sim68000 BSP for the BSVC simulator. This BSP includes theJoel Sherrill2000-08-012-0/+2
| | | | | alias simcpu32 that supports the CPU32 simulator in BSVC. At this point, it is still under development.
* Patch rtems-rc-20000725-1-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-07-251-1/+1
| | | | | that is an improvement in the version handling macro that compensates for Joel's bug in the release script which broke the VERSION file format.
* Added c3xsim as alias of c4xsim.Joel Sherrill2000-07-252-0/+2
* Changed default value to "pause".Joel Sherrill2000-07-171-1/+1
