path: root/aclocal (follow)
* 2004-02-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-032-4/+1
| | | | | | * aclocal/rpm.m4: Make osversions the default. * aclocal/rtems-top.m4: Remove check for version.m4 (Breaks make distcheck).
* 2004-02-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-011-0/+20
| | | | * aclocal/rpms.m4: New (extracted from scripts/configure.ac).
* 2004-01-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-161-15/+19
| | | | | * configure.ac: Require automake >= 1.8.2. * aclocal/check-bsps.m4: Also test for make/custom/*.cfg.
* 2004-01-07 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-01-072-3/+0
| | | | | * aclocal/bsp-alias.m4, aclocal/rtems-cpu-subdirs.m4: mips64orion port removed as mips port more completely covers the MIPS family.
* 2003-12-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-12-171-1/+1
| | | | * aclocal/version.m4: Updated to rtems-20031217-test.
* 2003-11-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-11-2620-32/+27
| | | | | | | | | | | | | | | * aclocal/bsp-alias.m4, aclocal/canonical-target-name.m4, aclocal/check-bsps.m4, aclocal/check-custom-bsp.m4, aclocal/enable-bare.m4, aclocal/enable-cxx.m4, aclocal/enable-inlines.m4, aclocal/enable-itron.m4, aclocal/enable-multiprocessing.m4, aclocal/enable-networking.m4, aclocal/enable-posix.m4, aclocal/enable-rdbg.m4, aclocal/enable-rtems-debug.m4, aclocal/enable-rtemsbsp.m4, aclocal/enable-tests.m4, aclocal/multilib.m4, aclocal/path-ksh.m4, aclocal/project-root.m4, aclocal/rtems-top.m4, aclocal/tool-paths.m4, acinclude.m4: Fix underquoting to silence automake-1.8.
* 2003-10-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-10-231-34/+0
| | | | | * aclocal/config-subdirs.m4: Remove. * Makefile.am: Reflect changes above.
* 2003-10-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-10-231-25/+0
| | | | | * aclocal/canonical-host.m4: Remove. * Makefile.am: Reflect changes above.
* 2003-10-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-10-021-18/+0
| | | | | | | * aclocal/check-cpu.m4: Remove. * Makefile.am: Remove reference to aclocal/check-cpu.m4. * acinclude.m4 (RTEMS_TARGET_CONFIG_SUBDIR): Check for presence of $1 in $srcdir before adding dir to SUBDIRS.
* 2003-09-26 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-261-1/+0
| | | | * README.configure, aclocal/rtems-cpu-subdirs.m4: Removing HPPA port.
* 2003-08-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-291-1/+3
| | | | | * aclocal/rtems-top.m4: Add RTEMS_API. AC_DEFAULT_PREFIX([/opt/rtems-][RTEMS_API]).
* 2003-08-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-222-8/+18
| | | | | | | * aclocal/enable-rtems-debug.m4: New (Missed in yesterday's patches). * aclocal/enable-tests.m4: Change to support --enable-tests=no|yes|samples, default is samples.
* 2003-08-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-2128-983/+0
| | | | | | | | | | | | | | | | | | | | | * aclocal/bsp-arg-enable.m4, aclocal/bsp-configure.m4, aclocal/bspopts.m4, aclocal/canonicalize-tools.m4, aclocal/check-bsp-cache.m4, aclocal/check-cxx.m4, aclocal/check-itron.m4, aclocal/check-multiprocessing.m4, aclocal/check-networking.m4, aclocal/check-newlib.m4, aclocal/check-posix.m4, aclocal/check-rdbg.m4, aclocal/check-tool.m4, aclocal/env-rtemsbsp.m4, aclocal/gcc-isystem.m4, aclocal/gcc-pipe.m4, aclocal/gcc-specs.m4, aclocal/i386-gas-code16.m4, aclocal/path-perl.m4, aclocal/ppc.m4, aclocal/prog-cc.m4, aclocal/prog-ccas.m4, aclocal/prog-cxx.m4, aclocal/prog-gnat.m4, aclocal/rtems-debug.m4, aclocal/rtems-flags.m4, aclocal/rtems-test-no-pause.m4, aclocal/target.m4: Remove (Unused). * automake/leaf.am, automake/force-preinstall.am: Remove (Unused). * Makefile.am: Reflect changes above.
* 2003-07-03 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-07-031-1/+1
| | | | * aclocal/version.m4: Updated to rtems-ss-20030703.
* 2003-06-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-06-121-2/+11
| | | | | | | | | | * configure.ac: Remove "BLEEDING EDGE" warning. Put docs into RTEMS_BUILD_CONFIG_SUBDIRS. * acinclude.m4: Add AC_PREREQ(2.57). Major overhaul (PR 412). * aclocal/prog-cc.m4: Add RTEMS_GCC_ISYSTEM. * aclocal/gcc-isystem.m4: New. * Makefile.am: Add aclocal/gcc-isystem.m4.
* 2003-06-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-06-121-0/+25
* 2003-05-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-05-272-6/+0
| | | | | | | | | PR 321: * aclocal/check-bsp-cache.m4: Remove support for profile-variant. * aclocal/env-rtemsbsp.m4 * automake/compile.am * automake/host.am * automake/local.am
* 2003-05-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-05-161-1/+1
| | | | | | * aclocal/check-cxx.m4: Remove LIBSUFFIX_VA. * automake/compile.am: Remove LIBSUFFIX_VA. Merger from rtems-4-6-branch.
* 2003-04-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-04-171-1/+1
| | | | * aclocal/version.m4: Updated to rtems-ss-20030417.
* 2003-04-11 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-04-111-1/+1
| | | | * aclocal/version.m4: Updated to rtems-ss-20030411.
| | | | * aclocal/version.m4: Updated to rtems-ss-20020411.
* Merger from rtems-4-6-branchRalf Corsepius2003-03-101-7/+1
* 2003-02-14 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-02-141-1/+0
| | | | | * README.configure, aclocal/rtems-cpu-subdirs.m4: Remove a29k references.
* Merger from rtems-4-6-branch.Ralf Corsepius2003-02-141-0/+3
* 2003-01-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-01-281-1/+1
| | | | * aclocal/version.m4: Updated to rtems-ss-20030128.
* 2001-01-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-01-162-2/+2
| | | | | * aclocal/rtems-cpu-subdirs.m4: Print out RTEMS_CPU in error message. * aclocal/enable-cxx.m4: Use $enable_cxx instead of $enableval.
* 2002-12-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-12-191-13/+10
| | | | | * aclocal/prog-cxx.m4: Remove RTEMS_PROG_CXX. Rework RTEMS_PROG_CXX_FOR_TARGET.
* 2002-12-10 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-12-101-1/+1
| | | | * aclocal/prog-cxx.m4: Swap RTEMS_CHECK_TOOL/AC_PROG_CXX.
* 2002-12-07 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-12-072-6/+6
| | | | | | * aclocal/bsp-configure.m4: Remove RTEMS_CHECK_BSP_CACHE. * aclocal/env-rtemsbsp.m4: Add comments to AC_ARG_VARs. Add AC_ARG_VAR(RTEMS_CPU_MODEL).
* 2002-12-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-12-063-4/+19
| | | | | | | * aclocal/env-rtemsbsp.m4: Add AC_ARG_VAR for CPU_CFLAGS, CFLAGS_OPTIMIZE_V, CFLAGS_DEBUG_V, CFLAGS_PROFILE_V, RTEMS_BSP_FAMILY. * aclocal/prog-cc.m4: Reworked CFLAGS handling. * aclocal/prog-cxx.m4: Reworked CXXFLAGS handling.
* 2002-12-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-12-061-0/+11
| | | | * aclocal/rtems-flags.m4: New.
* 2002-12-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-12-011-7/+0
| | | | * aclocal/prog-cc.m4: Remove GCCSED.
* 2002-11-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-11-294-17/+18
| | | | | | | * aclocal/prog-ccas.m4: New. * aclocal/check-custom-bsp.m4: New, split out from check-bsps.m4. * aclocal/check-bsps.m4: Split out RTEMS_CHECK_CUSTOM_BSP. * aclocal/canonicalize-tools.m4: Remove RTEMS_GCC_PRINT.
* 2002-11-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-11-201-5/+14
| | | | * aclocal/quoting.m4: Reworked (Part of fix to PR 312).
* 2002-11-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-11-191-10/+9
| | | | | | * automake/compile.am: Remove LD_PATHS (Unused). * aclocal/check-newlib.m4: Adaptation to autoconf-2.5x (AC_TRY_LINK is announced obsolete).
* 2002-11-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-11-192-136/+6
| | | | | * aclocal/sysv-ipc.m4: Remove (Unused). * aclocal/target.m4: Sync with acinclude.m4 (Part of fix to PR 312).
* 2002-11-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-11-191-23/+5
| | | | | * aclocal/target.m4: Apply RTEMS_CONFIGURE_ARGS_QUOTE (Part of fix to PR 312).
* 2002-11-18 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-11-181-1/+1
| | | | * aclocal/version.m4: Updated to rtems-ss-20021118.
* 2002-11-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-11-182-1/+2
| | | | | * aclocal/bsp-alias.m4, aclocal/check-bsps.m4: Added support for Motorola MTX603e.
* 2002-11-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-11-151-6/+1
| | | | | | | * acinclude.m4: Add CXX_FOR_*, CXXFLAGS_FOR_*. Fix stupid typo (continue/configure). * aclocal/prog-cc.m4: Remove obsolete comments. Acknowledge CFLAGS.
* 2002-11-11 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-11-111-1/+1
| | | | * aclocal/version.m4: Updated to rtems-ss-20021111.
* 2002-11-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-11-063-10/+6
| | | | | | | Further preparations for autoconf > 2.52: * aclocal/enable-inlines.m4: Use AS_IF instead of if/then/else. * aclocal/quoting.m4: Use `eval echo $ac_args` to unquote $ac_arg. * aclocal/target.m4: Use `eval echo $rtems_args` to unquote $ac_arg.
* 2002-10-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-10-2910-14/+18
| | | | | | | | | | | | | | | * aclocal/enable-bare.m4: Improve quoting of AC_HELP_STRING. * aclocal/enable-cxx.m4: Improve quoting of AC_HELP_STRING. * aclocal/enable-inlines.m4: Improve quoting of AC_HELP_STRING. * aclocal/enable-itron.m4: Improve quoting of AC_HELP_STRING. * aclocal/enable-multiprocessing.m4: Improve quoting of AC_HELP_STRING. * aclocal/enable-networking.m4: Improve quoting of AC_HELP_STRING. * aclocal/enable-posix.m4: Improve quoting of AC_HELP_STRING. * aclocal/enable-rdbg.m4: Improve quoting of AC_HELP_STRING. * aclocal/enable-rtemsbsp.m4: Improve quoting of AC_HELP_STRING. * aclocal/enable-tests.m4: Improve quoting of AC_HELP_STRING. (autoconf > 2.54 seems to have problems with the old form of quoting).
* 2002-10-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-10-281-1/+1
| | | | | * aclocal/enable-rtemsbsp.m4: Remove '\' in AC_MSG_ERROR (autoconf > 2.54 complains about).
* 2002-10-21 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-10-211-1/+1
| | | | * aclocal/version.m4: Updated to rtems-20021021-test.
* 2002-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-10-111-25/+1
| | | | * aclocal/ppc.m4: Apply RTEMS_CONFIGURE_ARGS_QUOTE.
* 2002-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-10-111-0/+31
| | | | | * aclocal/quoting.m4: New (Implements RTEMS_CONFIGURE_ARGS_QUOTE). * acinclude.m4: Apply RTEMS_CONFIGURE_ARGS_QUOTE.
* 2002-10-07 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-10-071-1/+1
| | | | * aclocal/version.m4: Updated to rtems-ss-20021007.
* 2002-10-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-10-041-1/+1
| | | | * aclocal/version.m4: Updated to rtems-ss-20021004.
* 2002-08-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-291-1/+18
| | | | | * aclocal/bsp-configure.m4: Create bspopts.h on the fly, filter out autoconf-2.53 PACKAGE crap.
