2015-09-11 | Upgrade to 4.11.99.0 | Sebastian Huber | 1 | -2/+2 | |
2015-04-17 | DRVMGR: added driver manager to cpukit/libdrvmgr | Daniel Hellstrom | 1 | -0/+12 | |
2014-05-08 | configure: Paravirtualization for all targets | Sebastian Huber | 1 | -7/+3 | |
Virtual machines with paravirtualization exist not only on x86. | |||||
2013-11-27 | add --enable-paravirt to the configure options | Philipp Eppelt | 1 | -0/+17 | |
2013-06-12 | configure: Documentation | Sebastian Huber | 2 | -2/+5 | |
2013-05-31 | smp: Add ARM support | Sebastian Huber | 1 | -1/+1 | |
2013-05-31 | smp: Add PowerPC support | Sebastian Huber | 1 | -1/+1 | |
2012-05-18 | Remove references to configure.in. | Ralf Corsépius | 2 | -3/+3 | |
2012-05-18 | Remove stray dnl. | Ralf Corsépius | 2 | -4/+0 | |
2012-05-11 | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 15 | -32/+0 | |
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed. | |||||
2012-05-07 | Revert: Remove CVS Ids | Joel Sherrill | 15 | -0/+37 | |
See http://www.rtems.org/pipermail/rtems-devel/2012-May/001006.html for details. | |||||
2012-05-04 | Remove CVS-Ids. | Ralf Corsépius | 15 | -37/+0 | |
2011-06-28 | 2011-05-24 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 1 | -1/+1 | |
PR 1810/misc * ChangeLog: Fix previous damage. | |||||
2011-03-16 | 2011-03-16 Jennifer Averett <jennifer.averett@OARcorp.com> | Joel Sherrill | 1 | -0/+18 | |
PR 1729/cpukit * aclocal/enable-smp.m4: New file. | |||||
2011-03-06 | 2011-03-06 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+2 | |
* aclocal/rtems-top.m4: Add pkgdatadir. Override pkgdatadir to $(datadir)/rtems$_RTEMS_API. * Makefile.am: Install make/Templates to pkgdatadir. | |||||
2011-03-04 | 2011-03-04 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 3 | -6/+6 | |
* Makefile.maint, aclocal/rpm.m4, aclocal/rtems-top.m4, aclocal/version.m4: Rename RTEMS_API into _RTEMS_API. | |||||
2010-07-27 | 2010-07-27 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 1 | -0/+3 | |
PR 1532/testing * aclocal/project-root.m4: Add initial tests for untar capabilities. | |||||
2010-06-17 | 2010-06-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -12/+0 | |
* aclocal/enable-itron.m4: Remove. * configure.ac: Remove itron. | |||||
2010-06-07 | 2010-06-07 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -2/+2 | |
* aclocal/version.m4: Bump RTEMS_API to 4.11. Bump _RTEMS_VERSION to 4.10.99.0. | |||||
2010-05-11 | 2010-05-11 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -1/+1 | |
* aclocal/bsp-alias.m4: Change quoting to work-round http://www.freebsd.org/cgi/query-pr.cgi?pr=146378. | |||||
2009-10-23 | 2009-10-23 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -4/+0 | |
* aclocal/check-custom-bsp.m4: Be less verbose. | |||||
2009-10-21 | 2009-10-21 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -1/+1 | |
* aclocal/bsp-alias.m4: Fix quoting bug. | |||||
2009-10-17 | Remove "blacklist". | Ralf Corsepius | 1 | -10/+1 | |
2009-10-17 | Remove "${srcdir}/${RTEMS_TOPdir}/make/custom/$1". | Ralf Corsepius | 1 | -4/+2 | |
2009-10-16 | 2009-10-16 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -7/+1 | |
* aclocal/bsp-alias.m4: Remove bare BSP (Abandoned). | |||||
2009-10-16 | Cosmetics. | Ralf Corsepius | 1 | -2/+2 | |
2009-10-16 | 2009-10-16 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -45/+8 | |
* aclocal/bsp-alias.m4: Pickup bsps from c/src/lib/libbsp/<cpu>/<bsp_family>/make/custom*.cfg. | |||||
2009-10-15 | 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -31/+17 | |
* aclocal/check-bsps.m4: Pickup bsps from c/src/lib/libbsp/<cpu>/<bsp_family>/make/custom*.cfg. | |||||
2009-10-15 | 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -1/+2 | |
* aclocal/check-custom-bsp.m4: Let _RTEMS_CHECK_CUSTOM_BSP look for *.cfg into c/src/lib/libbsp/<cpu>/<bsp_family>/make/custom. | |||||
2009-10-14 | Remove posix/unix simulator. | Ralf Corsepius | 2 | -22/+0 | |
2009-10-05 | renamed lpc24xx BSPs | Thomas Doerfler | 2 | -4/+5 | |
2009-10-01 | 2009-10-01 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 1 | -0/+5 | |
* aclocal/bsp-alias.m4: Add BSP for GDB ARM simulator so we can easily experiment with and debug different ARM architectural variations. | |||||
2009-09-14 | 2009-09-14 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+1 | |
* aclocal/check-bsps.m4: Add csb337 bsp family. | |||||
2009-07-23 | 2009-07-23 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -4/+2 | |
* aclocal/enable-itron.m4: Default to not building itron. | |||||
2009-05-28 | 2009-05-28 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 1 | -1/+2 | |
* aclocal/bsp-alias.m4: Add csb637 as variant of csb337. | |||||
2009-02-27 | * README: Added NCS. | Thomas Doerfler | 2 | -1/+3 | |
* Makefile.am, configure.ac, preinstall.am: Added BSP variants. * console/console-config.c, clock/clock-config.c, ssp/ssp.c: Fixed register settings. Cleanup. * include/bsp.h: Added network defines and functions. * include/lpc24xx.h: Added AHB and EMC defines. Fixed Ethernet status sizes. * include/system-clocks.h, misc/system-clocks.c: Added micro seconds delay function that uses Timer 1. Changed PLL setup. * network/network.c, startup/bspreset.c, startup/linkcmds.lpc2478, startup/linkcmds.lpc2478_ncs, startup/linkcmds.lpc2478_ncs_ram: New files. * startup/bspstart.c: Added EMC initialization. Changes for ROM boot. | |||||
2009-02-19 | 2009-02-19 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 1 | -0/+1 | |
* aclocal/bsp-alias.m4: Add simsh2e. | |||||
2009-02-06 | 2009-02-06 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -1/+0 | |
* aclocal/canonical-target-name.m4: Remove comment referring to HPUX9. | |||||
2009-02-05 | Remove pck6 BSP. | Ralf Corsepius | 2 | -2/+1 | |
2008-12-30 | 2008-12-30 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -1/+1 | |
* aclocal/check-bsps.m4: remove stray ")" from rtl22xx_t alias. | |||||
2008-12-22 | Remove tic4x. | Ralf Corsepius | 1 | -3/+0 | |
2008-10-14 | 2008-10-14 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2 | -0/+2 | |
* aclocal/bsp-alias.m4, aclocal/check-bsps.m4: Add h8sxsim as variant of h8sim. | |||||
2008-10-02 | 2008-10-02 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2 | -0/+2 | |
* README.configure, aclocal/bsp-alias.m4, aclocal/check-bsps.m4: Add M32C port and m32csim BSP. | |||||
2008-10-01 | 2008-10-01 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -2/+2 | |
PR 1324/bsps * aclocal/check-bsps.m4: Revert Joel's icecube patch. | |||||
2008-09-25 | 2008-09-25 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2 | -3/+4 | |
* README.configure, aclocal/bsp-alias.m4, aclocal/check-bsps.m4: Recognize the the GDB SuperH simulator is just an architectural simulator and does not include devices. Rename existing simulator BSP configurations to simsh1 and simsh2 and add simsh4. | |||||
2008-09-24 | 2008-09-24 Ralf Corsépius <ralf.corsepius@rtems.org> | Joel Sherrill | 1 | -1/+1 | |
PR 1324/bsps * aclocal/check-bsps.m4: Add missing icecube. | |||||
2008-09-22 | 2008-09-22 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -2/+2 | |
* aclocal/version.m4: Bump RTEMS_API to 4.10. Bump _RTEMS_VERSION to 4.9.99.0. | |||||
2008-09-22 | added BSP for ARM LPC24xx | Thomas Doerfler | 2 | -0/+2 | |
2008-09-08 | added new BSP for powerpc/tqm8xx boards | Thomas Doerfler | 2 | -0/+3 | |
2008-08-15 | 2008-08-15 Allan Hessenflow <allanh@kallisti.com> | Joel Sherrill | 1 | -0/+1 | |
* src/lib/libbsp/mips/jmr3904/tools/runtest: Add bf537Stamp. |
