path: root/aclocal (unfollow)
2008-07-27Require AC_DISABLE_OPTION_CHECKING.Ralf Corsepius1-0/+4
AC_PREREQ(2.62).
2008-07-27Remove doxygen comments.Ralf Corsepius2-18/+0
2008-07-14updated gen83xx BSPThomas Doerfler2-1/+22
updated haleakala BSP added MPC55xx BSP
2008-07-11added BSP to m68kThomas Doerfler2-1/+4
adapted PPC exception code
2008-02-20s/AC_HELP/AS_HELP/.Ralf Corsepius9-9/+9
2007-11-062007-11-06 Ray Xu <rayx.cn@gmail.com>Joel Sherrill2-0/+2
* aclocal/bsp-alias.m4, aclocal/check-bsps.m4:
2007-09-212007-09-21 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius1-2/+2
* aclocal/version.m4: Bump RTEMS_API to 4.9. Bump RTEMS_VERSION to 4.8.99.0.
2007-08-10added BSP hsc_cm01Thomas Doerfler2-1/+2
2007-08-07Upgrade to 4.7.99.2Joel Sherrill1-1/+1
2007-08-062007-08-06 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill1-1/+1
* README.configure, aclocal/bsp-alias.m4: Rename EP5200 to IceCube since that is the nickname for the Freescale evaluation board it is based upon. BSP was tested on a Freescale MPC5200LITE.
2007-08-022007-08-02 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill1-15/+0
* Makefile.maint, configure.ac, release_support: Remove RDBG. * aclocal/enable-rdbg.m4: Removed.
2007-07-10compilable release of virtex/gen83xx/gen5200 powerpc adaptations. Merged ↵Thomas Doerfler2-0/+2
many different versions of new exception handling code to shared sources.
2007-06-202007-06-20 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill1-0/+1
* aclocal/bsp-alias.m4, README.configure: Add ep5200, IceCube, 5200Lite.
2007-05-152007-05-15 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill1-1/+0
* README.configure, aclocal/check-bsps.m4: Remove references to mbx860_1b since it is just an alternate name for the mbx860_001b.
2007-05-112007-05-11 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2-4/+1
* README.configure, aclocal/bsp-alias.m4, aclocal/check-bsps.m4: Per Jiri Gaisler remove unused erc32nfp and leon1 BSP variants.
2007-03-13Upgrade to 4.7.99.1Joel Sherrill1-1/+1
2007-02-22Revert to version 4.7.99-0Ralf Corsepius1-1/+1
2007-02-22Testing: Upgrade to 4.7.99.1Ralf Corsepius1-1/+1
2006-10-192006-10-19 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-11/+0
* configure.ac: Remove all macro implementations and use only the static inline. Static inline functions are now well supported so there is no reason for duplicate maintenance. * aclocal/enable-inlines.m4: Removed.
2006-10-182006-10-18 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2-2/+2
* aclocal/rtems-top.m4: Remove RTEMS_API. * aclocal/version.m4: Add RTEMS_API. Bump RTEMS_API to 4.8.
2006-10-172006-10-17 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius1-1/+1
* aclocal/version.m4: Bump version to 4.7.99.0.
2006-07-09applied patches for PR1117/1118/1119/1120Thomas Doerfler2-1/+2
2006-04-182006-04-18 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-1/+1
* aclocal/version.m4: Updated to rtems-4.6.99.3.
2006-01-122006-01-12 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius1-11/+10
* aclocal/bsp-alias.m4: Revert Joel's 2006-01-10 change. Alpha-sort the aliases list.
2006-01-102006-01-10 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-0/+1
* aclocal/bsp-alias.m4: Add sis as alias of erc32.
2006-01-092006-01-09 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2-6/+5
* aclocal/bsp-alias.m4: Remove brs5l. Remove leon2. Alias leon1 to leon2. Add sis. * aclocal/check_bsps.m4: Remove brs5l. Remove leon. Add leon2. Add sis to erc32 family.
2005-12-312005-11-31 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2-1/+4
PR 851/bsps * aclocal/bsp-alias.m4, aclocal/check-bsps.m4: Add gen5200 BSP family.
2005-11-032005-11-03 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius1-1/+6
* aclocal/check-bsps.m4: Add the plethora of mbx* BSP.
2005-09-022005-09-02 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-1/+1
* aclocal/version.m4: Updated to rtems-4.6.99.2.
2005-02-042005-02-04 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius1-19/+0
* aclocal/enable-itron.m4: Allow unix.
2004-11-162004-11-16 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius1-1/+1
* aclocal/check-bsps.m4: Use ls instead of globs to pickup bsp_specs.
2004-11-122004-11-12 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius1-1/+1
* aclocal/check-bsps.m4: Add MVME2100 BSP as alias of motorola_shared.
2004-11-102004-11-10 Joel Sherrill <joel@oarcorp.com>Joel Sherrill1-0/+1
* aclocal/bsp-alias.m4: Add MVME2100 BSP as alias of motorola_shared.
2004-10-222004-10-22 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius1-1/+1
* alocal/check-custom-bsp.m4: Reflect new location of bspkit*cfg.
2004-10-182004-10-18 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2-23/+36
* aclocal/check-bsps.m4: Add bspkit support. Don't check for presence of *.cfg. * aclocal/check-custom-bsp.m4: Add bspkit support.
2004-10-182004-10-18 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius1-21/+0
* aclocal/enable-bare.m4: Remove.
2004-09-242004-09-24 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius1-28/+0
* aclocal/rtems-cpu-subdirs.m4: Remove (unused).
2004-07-282004-07-28Joel Sherrill1-1/+1
* aclocal/version.m4: Updated to rtems-4.6.99.1.
2004-03-312004-03-31 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius1-7/+0
* aclocal/rtems-top.m4: Remove ENDIF. Remove with_target_subdir defaulting to '.'. * acinclude.m4: Add --includedir to sub_configure_args.
2004-02-202004-02-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius1-7/+1
* aclocal/rtems-top.m4: Sync with c/src/aclocal/rtems-top.m4 * Makefile.am: Cosmetics.
2004-02-172004-02-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius1-4/+5
* Makefile.am: DIST_SUBDIRS = $(SUBDIRS). Rework dist-hook. * configure.ac: Reflect changes to RTEMS_ENABLE_RTEMSBSP. * aclocal/enable-rtemsbsp.m4: Add support for --disable-rtemsbsp.
2004-02-122004-02-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius1-1/+1
* VERSION: 4.6.99.0. * aclocal/version.m4: 4.6.99.0.
2004-02-062004-02-06 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-0/+2
* aclocal/bsp-alias.m4: Readd aliases for p4600 and p4650 which were accidentally removed when purging the mips64orion.
2004-02-032004-02-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2-4/+1
* aclocal/rpm.m4: Make osversions the default. * aclocal/rtems-top.m4: Remove check for version.m4 (Breaks make distcheck).
2004-02-012004-02-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius1-0/+20
* aclocal/rpms.m4: New (extracted from scripts/configure.ac).
2004-01-162004-01-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius1-15/+19
* configure.ac: Require automake >= 1.8.2. * aclocal/check-bsps.m4: Also test for make/custom/*.cfg.
2004-01-072004-01-07 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2-3/+0
* aclocal/bsp-alias.m4, aclocal/rtems-cpu-subdirs.m4: mips64orion port removed as mips port more completely covers the MIPS family.
2003-12-172003-12-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-1/+1
* aclocal/version.m4: Updated to rtems-20031217-test.
2003-11-262003-11-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius20-32/+27
* aclocal/bsp-alias.m4, aclocal/canonical-target-name.m4, aclocal/check-bsps.m4, aclocal/check-custom-bsp.m4, aclocal/enable-bare.m4, aclocal/enable-cxx.m4, aclocal/enable-inlines.m4, aclocal/enable-itron.m4, aclocal/enable-multiprocessing.m4, aclocal/enable-networking.m4, aclocal/enable-posix.m4, aclocal/enable-rdbg.m4, aclocal/enable-rtems-debug.m4, aclocal/enable-rtemsbsp.m4, aclocal/enable-tests.m4, aclocal/multilib.m4, aclocal/path-ksh.m4, aclocal/project-root.m4, aclocal/rtems-top.m4, aclocal/tool-paths.m4, acinclude.m4: Fix underquoting to silence automake-1.8.
2003-10-232003-10-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius1-34/+0
* aclocal/config-subdirs.m4: Remove. * Makefile.am: Reflect changes above.
