path: root/aclocal (follow)
* Removed SIZE_FOR_TARGET change after Ralf pointed out that gcc doesJoel Sherrill1998-05-221-1/+0
| | | | not properly report it all the time.
* Use gcc to look for size alsoJoel Sherrill1998-05-211-0/+1
* New file from Ralf CorsepiusJoel Sherrill1998-05-211-0/+17
* Patch from Ralf Corseipus to fix latent configure problems suddenly triggered:Joel Sherrill1998-05-203-70/+53
| | | | | | | | | | | | | | | | | | | | | | | The breakdown: * CC_FOR_TARGET and CXX_FOR_TARGET were not correctly re-read from autoconf's configuration cache (config.cache) * If <target>-[gcc|g++] was not found while running configure, the config macros tried to use other (wrong) compilers (e.g. cc). Changes: * New RTEMS_PROG_CC macro (aclocal/prog-cc.m4). * New RTEMS_PROG_CXX macro (aclocal/prog-cxx.m4) * Moved a shell script fragment from configure.in to a new m4-autoconf macro (New file: aclocal/tool-prefix.m4) * Minor changes to configure.in I tested it with linux/posix (native gcc/primary libc) and sh-rtems/gensh1 on a linux host and didn't notice any bugs related to the problems mentioned above. There seem to be more bugs with the posix bsp, but I consider them minor as the build run completed successfully. It is just too late for me to attempt to fix them now.
* Modified to find C++ compilers.Joel Sherrill1998-05-181-6/+0
* Updated now that the phony crt0.c in newlib defines all odd symbolsJoel Sherrill1998-03-232-36/+2
| | | | that gcc automatically generates references to.
* Added enough symbols to the conftest.c program to make sure it wouldJoel Sherrill1998-03-212-3/+34
| | | | successfully link on both the powerpc and hppa1.1.
* Patch from Ralf Corsepius to properly detect that Cygwin32 does notJoel Sherrill1998-03-201-9/+18
| | | | support the -pipe option on the compiler.
* New files missed in previous merge.Joel Sherrill1998-02-195-0/+234
* Update from Ralf Corsepius:Joel Sherrill1998-02-172-5/+4
| | | | | | | 6) The macro files from aclocal/*.m4 contain the buggy sed-rules formerly contained in aclocal..m4, i.e. the sed/sort-bug fix to aclocal.m4 didn't make it to aclocal/*.m4. I think I should feel guilty for that - Obviously I submitted the contents of an old aclocal-directory last time. - Sorry.
* New autoconf feature from Ralf Corsepius:Joel Sherrill1998-02-044-0/+86
It adds make rules for reconfiguring build-trees ("make Makefile") and adds dependency rules for configure and friends (i.e. calls autoconf). Most of this code has been "borrowed" from automake and was adapted to rtems. Addionally, I added automatic generation of the "aclocal.m4"-file by "aclocal" (from the automake package). Therefore I splitted aclocal.m4 into several separate files (attached to this mail), each containing one of rtems customized autoconf/m4-macros and have put them into a new subdirectory "aclocal". Normal users won't be influenced and won't even need this, unless they try to modify configure.in. The main advantage of this is: these aclocal/m4-macros become reusable and easier to administer. As a disadvantage, rtems becomes dependent of having aclocal/automake installed. To keep building rtems functional if autoconf or aclocal isn't installed, the related Makefile commands are prefixed by "-" -- only an error message should be issued by "make".
