* aclocal/enable-rtemsbsp.m4: Add RTEMS_ENABLE_BARE,
AC_SUBST(BARE_CPU_MODEL),AC_SUBST(BARE_CPU_CFLAGS).
* aclocal/i386-gas-code16.m4: AC_DEFINE NEW_GAS.
* aclocal/target.m4: Cleanup comments
* Automake/compile.am: Add DEFS support to keep building happy.
* aclocal/project-root.m4: Introduce PROJECT_TOPdir, add comments.
* aclocal/check-bsps.m4: Fix c4* and sim68000 entries
* make/custom/pck6.cfg: New file
* make/custom/pc486.cfg: Use -m486
* make/custom/pc586.cfg: Use -mpentium
* make/custom/pc686.cfg: Use -mmpentiumpro
* make/custom/i386ex.cfg: Use -msoft-float
* aclocal/check-bsps.h:
- Add pck6-BSP
- Exclude ChangeLog from being picked up as BSP
* aclocal/bsp-alias.m4: Add pck6-BSP
alias simcpu32 that supports the CPU32 simulator in BSVC. At this
point, it is still under development.
that is an improvement in the version handling macro that compensates
for Joel's bug in the release script which broke the VERSION file format.
cpuopts.h.
exec/configure.in, only.
quoting bugs in autoconf).
formating changes :)
cpuopts.h.
to disabled.
problems at runtime.
that is another small step toward multilibs:
* Eliminate RTEMS_CHECK_CUSTOM_BSP from all configure.ins below exec/
* Add RTEMS_CHECK_CUSTOM_BSP to the multilib-disabled branch in
RTEMS_ENV_RTEMSCPU to preserve the old per-BSP building scheme
functional.
* --enable-multilibs is still non-functional
* This patch should not have any influence on the old building
scheme (--disable-multilib should silently fall back to the old
building scheme).
* running ./bootstrap is required after applying the patch
<corsepiu@faw.uni-ulm.de> that adds a piece of the
*-rc-20000705-? series that was not added to CVS accidentally.
that makes --disable-multilib the default.
that is a somewhat experimental, multilib-related patch:
* Use RTEMS_ENV_RTEMSCPU instead of RTEMS_ENV_RTEMSBSP in
configure.ins below exec/.
At the moment, RTEMS_ENV_RTEMSCPU is more or less an optical change
to emphasize that these subdirectories shall not depend on RTEMS_BSP
than a real behavioral change.
* Add AC_DEFINE_* to several aclocal/*.m4 macros to prepare
autoheader/autoconf generated targopts.h and similiar configuration
headers.
* c/src/configure.in: remove exec from cfg_subdirs if multilibs are
enabled (c/src is build per bsp, exec shall be build per cpu in c/
or from the toplevel in future, when multilibs are enabled.)
* This patch should not have any impact on the current building scheme.
* --enable-multilib still does not work.
* running bootstrap from the toplevel directory is required.
CVS:
CVS: Committing in .
CVS:
CVS: Modified Files:
Comments follow:
Building linux/posix fails due to including lib/include/sys/cdefs.h
instead of linux's sys/cdefs.h.
AFAIS, this sys/cdefs.h is specific to newlib and should probably
not be used on any unix host.
Therefore, I changed the relevant Makefile.am/configure.in to
condionally install sys/cdefs.h only if newlib is present.
This triggered another bug inside of the newlib-check for one of
RTEMS target's (Unfortunately I can't remember which - mips/i960 ?
... one of the more exotic ...), for which int func() isn't
identical to void func().
Note: This patch needs to be tested under Cygwin and Solaris. I am
particularily unsure about Cygwin/posix, as it applies a different
version newlib which must not trigger RTEMS newlib check (it is
supposed to fail) and if it may need RTEMS's sys/cdefs.h.
that is part of the multilib/gnu-canonicalization movement:
* New m4-macro: aclocal/multilib.am
* Suppress multiprocessing if --enable-multilib is given to
configure
For now this patch only suppresses multiprocessing if
--enable-multilib is given to configure and should not have any
other side-effects, ie. it works around a minor issue which prevents
introduction of multilibs in general.
The RTEMS_ENABLE_MULTILIB_MASTER macro is the core part to build
real multilibs, but can not be applied before other multilib related
issues with RTEMS have been solved. (e.g. sptables.h, bsp_specs,
Cygnus/Gnu canonicalization, _RTEMS_version, targopts.h, changing
the installation point/tooldir support, etc.).
build issues.
<corsepiu@faw.uni-ulm.de> that addresses a couple of
minor configuration issues which popped up when
experimenting with multilibs.
Note: The multigen generated make/custom/bare-*.cfg will still be
non-functional, even after having applied this patch.
significant things:
and PowerPC
same code base.
that contains:
* Removes MKLIB
handling)
<corsepiu@faw.uni-ulm.de>.
the mvme2307 and mcp750 BSPs. In addition, it can support many
Motorola PowerPC based VME and PCI boards.
which is described below:
break something.
SUBDIRS in a Makefile.am)
* An update to gensh2.cfg.
cd <srcdir>
which adds automake support to libbsp/bare.
to generalize librdbg for all i386 BSPs. His comments:
The patch below generalizes librdbg for all i386 bsps. It is not a
complete rewrite, but a minimal invasive attempt to generalization.
mv c/src/librdbg/src/i386/pc386 c/src/librdbg/src/i386/any
patch -p1 < patches-rc-19991203-1.diff
./bootstrap
<corsepiu@faw.uni-ulm.de>:
The patch below provides
before)
rtems-rc-19991123-rc-2.diff
Attention:
Addtional major bugs:
in the previous commits.
*.cfg files.
dependencies
automake and RTEMS make rules
convention)
performs automatically.
WARNING:
Makefile.ams.
for RTEMS.
Removed all go32 configuration tests.
This patch also comments out some special treatment for Cygwin from
*.m4 macros. According to reports from David Fiddes. these should
not be necessary anymore.
to its own top level package.
mkdir c/src/librpc
mkdir c/src/librpc/src
mkdir c/src/librpc/include
rm -rf c/src/lib/librpc
rm -rf c/src/lib/include/rpc
in the required order .
# make[5]: Entering directory
# mips64orion-rtems-gcc -v
# mips64orion-rtems-ld -v
configuration and unix/posix:
c/src/lib/libc/Makefile.in
only (was completely broken).
Linux-posix.cfg.
of other bsp's/CPU.
cd <srcdir>
and
cd c/src/lib; autoconf
or
After upgrading my linux box to the brand new SuSE 6.2 release, which is
glibc-2.1 based, I came across a bug in RTEMS - IIRC, I even warned you
about it about 1/2 a year ago, but nothing has been done since then :-.
The *.m4 macros to check for SYSV/IPC are broken for linux/glibc2.1,
because they assume that linux always defines union semun, which isn't
true anymore for glibc2.1 (the manpage for semctl states _X_OPEN
specifies it this way). Therefore I have tried to implement a more
general approach for handling SYSV for unix/posix which checks for
presence of struct semun, instead of trying to evaluate OS specific
preprocessor symbols.
This approach is a bit adventureous, because I only tested it with
linux/glibc2.1 and linux/libc5, but not under other Unix variants RTEMS
supports. I am quite confident it will work on other hosts, too, but who
knows :-.
[FYI: I think this might also is the cause of some problems with RedHat
6.X / Mandrake linux recently reported on the rtems list -- rtems-4.0.0
can not be build for posix on any glibc2.1 based host]
Furthermore the patch below contains a couple of minor fixes and
configuration cleanups, which IMO should be applied before releasing a
new snapshot.
To apply this patch:
patch -p1 < rtems-rc-19990709-8.diff
in a previous patch.
CHANGES
autoconf check
autoconf check
$(prefix)/<bsp>/make/bsp.cfg
compatible.
Makefile.ins
* I've gone a little ??) further than I had announced before.
> When I run my script that just repeatedly builds different targets, some
> of them die with an error like this:
> Making all RTEMS_BSP=gen68360 in cpugmake[5]: Entering directory
> `/usr1/rtems/build/build-m68k-rtems/c/src/exec/score/cpu'
> Making all RTEMS_BSP=gen68360 in @RTEMS_CPU@
> /bin/sh: @RTEMS_CPU@: No such file or directory
> gmake[5]: *** [all] Error 1
> gmake[5]: Leaving directory
> It is not always the same variable substitution that fails. Sometimes it
> is @INSTALL@. But reliably, it is a variable substitution that is
> failing.
> Do you have any idea why this happens?
Yep, I think I know what's going on.
AC_SUBST(RTEMS_CPU) is missing in configure.ins, thus @RTEMS_CPU@ in
target.cfg.in doesn't get substituted correctly, causing the bug above. Due
to the redundancy of RTEMS_CPU, other most BSPs don't seem to be affected.
Other similar problems probably exist for the unix/posix bsp and the hppa.1
cpu, because their */tools/*Makefile.ams require RTEMS_CPU, too.
Fixes/Changes:
--target=no_cpu*rtems.
before adding :-)
toplevel/configure.in
files changed to RTEMS_CPU
This patch removes MKDIR from RTEMS source tree and fixes another small
bug in the definition of INSTALL_VARIANT (cf. to the patch itself for
details, it should be self-explanatory)
After applying the patch please do:
cvs rm aclocal/mkdir.m4
