path: root/aclocal (follow)
* 2006-10-17 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2006-10-192-3/+3
| | | | | | * configure.ac: Requires automake-1.10. Require autoconf-2.60. * aclocal/rtems-top.m4, aclocal/version.m4: Adaptions to automake-1.10.
* applied patches for PR1117/1118/1119/1120Thomas Doerfler2006-07-092-1/+2
* 2006-04-18 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2006-04-181-1/+1
| | | | * aclocal/version.m4: Updated to rtems-4.6.99.3.
* 2006-01-12 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2006-01-121-11/+10
| | | | | * aclocal/bsp-alias.m4: Revert Joel's 2006-01-10 change. Alpha-sort the aliases list.
* 2006-01-10 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2006-01-101-0/+1
| | | | * aclocal/bsp-alias.m4: Add sis as alias of erc32.
* 2006-01-09 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2006-01-092-6/+5
| | | | | | | * aclocal/bsp-alias.m4: Remove brs5l. Remove leon2. Alias leon1 to leon2. Add sis. * aclocal/check_bsps.m4: Remove brs5l. Remove leon. Add leon2. Add sis to erc32 family.
* 2005-11-31 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-12-312-1/+4
| | | | | | PR 851/bsps * aclocal/bsp-alias.m4, aclocal/check-bsps.m4: Add gen5200 BSP family.
* 2005-11-03 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-11-031-1/+6
| | | | * aclocal/check-bsps.m4: Add the plethora of mbx* BSP.
* 2005-09-02 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2005-09-021-1/+1
| | | | * aclocal/version.m4: Updated to rtems-4.6.99.2.
* 2005-02-04 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-02-041-19/+0
| | | | * aclocal/enable-itron.m4: Allow unix.
* 2004-11-16 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-11-161-1/+1
| | | | | * aclocal/check-bsps.m4: Use ls instead of globs to pickup bsp_specs.
* 2004-11-12 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-11-121-1/+1
| | | | | * aclocal/check-bsps.m4: Add MVME2100 BSP as alias of motorola_shared.
* 2004-11-10 Joel Sherrill <joel@oarcorp.com>Joel Sherrill2004-11-101-0/+1
| | | | * aclocal/bsp-alias.m4: Add MVME2100 BSP as alias of motorola_shared.
* 2004-10-22 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-10-221-1/+1
| | | | * alocal/check-custom-bsp.m4: Reflect new location of bspkit*cfg.
* 2004-10-18 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-10-182-23/+36
| | | | | | * aclocal/check-bsps.m4: Add bspkit support. Don't check for presence of *.cfg. * aclocal/check-custom-bsp.m4: Add bspkit support.
* 2004-10-18 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-10-181-21/+0
| | | | * aclocal/enable-bare.m4: Remove.
* 2004-09-24 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-09-241-28/+0
| | | | * aclocal/rtems-cpu-subdirs.m4: Remove (unused).
* 2004-07-28Joel Sherrill2004-07-281-1/+1
| | | | * aclocal/version.m4: Updated to rtems-4.6.99.1.
* 2004-03-31 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-03-311-7/+0
| | | | | | * aclocal/rtems-top.m4: Remove ENDIF. Remove with_target_subdir defaulting to '.'. * acinclude.m4: Add --includedir to sub_configure_args.
* 2004-02-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-201-7/+1
| | | | | * aclocal/rtems-top.m4: Sync with c/src/aclocal/rtems-top.m4 * Makefile.am: Cosmetics.
* 2004-02-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-171-4/+5
| | | | | | | * Makefile.am: DIST_SUBDIRS = $(SUBDIRS). Rework dist-hook. * configure.ac: Reflect changes to RTEMS_ENABLE_RTEMSBSP. * aclocal/enable-rtemsbsp.m4: Add support for --disable-rtemsbsp.
* 2004-02-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-121-1/+1
| | | | | * VERSION: 4.6.99.0. * aclocal/version.m4: 4.6.99.0.
* 2004-02-06 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-02-061-0/+2
| | | | | * aclocal/bsp-alias.m4: Readd aliases for p4600 and p4650 which were accidentally removed when purging the mips64orion.
* 2004-02-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-032-4/+1
| | | | | | * aclocal/rpm.m4: Make osversions the default. * aclocal/rtems-top.m4: Remove check for version.m4 (Breaks make distcheck).
* 2004-02-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-011-0/+20
| | | | * aclocal/rpms.m4: New (extracted from scripts/configure.ac).
* 2004-01-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-161-15/+19
| | | | | * configure.ac: Require automake >= 1.8.2. * aclocal/check-bsps.m4: Also test for make/custom/*.cfg.
* 2004-01-07 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-01-072-3/+0
| | | | | * aclocal/bsp-alias.m4, aclocal/rtems-cpu-subdirs.m4: mips64orion port removed as mips port more completely covers the MIPS family.
* 2003-12-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-12-171-1/+1
| | | | * aclocal/version.m4: Updated to rtems-20031217-test.
* 2003-11-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-11-2620-32/+27
| | | | | | | | | | | | | | | * aclocal/bsp-alias.m4, aclocal/canonical-target-name.m4, aclocal/check-bsps.m4, aclocal/check-custom-bsp.m4, aclocal/enable-bare.m4, aclocal/enable-cxx.m4, aclocal/enable-inlines.m4, aclocal/enable-itron.m4, aclocal/enable-multiprocessing.m4, aclocal/enable-networking.m4, aclocal/enable-posix.m4, aclocal/enable-rdbg.m4, aclocal/enable-rtems-debug.m4, aclocal/enable-rtemsbsp.m4, aclocal/enable-tests.m4, aclocal/multilib.m4, aclocal/path-ksh.m4, aclocal/project-root.m4, aclocal/rtems-top.m4, aclocal/tool-paths.m4, acinclude.m4: Fix underquoting to silence automake-1.8.
* 2003-10-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-10-231-34/+0
| | | | | * aclocal/config-subdirs.m4: Remove. * Makefile.am: Reflect changes above.
* 2003-10-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-10-231-25/+0
| | | | | * aclocal/canonical-host.m4: Remove. * Makefile.am: Reflect changes above.
* 2003-10-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-10-021-18/+0
| | | | | | | * aclocal/check-cpu.m4: Remove. * Makefile.am: Remove reference to aclocal/check-cpu.m4. * acinclude.m4 (RTEMS_TARGET_CONFIG_SUBDIR): Check for presence of $1 in $srcdir before adding dir to SUBDIRS.
* 2003-09-26 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-261-1/+0
| | | | * README.configure, aclocal/rtems-cpu-subdirs.m4: Removing HPPA port.
* 2003-08-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-291-1/+3
| | | | | * aclocal/rtems-top.m4: Add RTEMS_API. AC_DEFAULT_PREFIX([/opt/rtems-][RTEMS_API]).
* 2003-08-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-222-8/+18
| | | | | | | * aclocal/enable-rtems-debug.m4: New (Missed in yesterday's patches). * aclocal/enable-tests.m4: Change to support --enable-tests=no|yes|samples, default is samples.
* 2003-08-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-2128-983/+0
| | | | | | | | | | | | | | | | | | | | | * aclocal/bsp-arg-enable.m4, aclocal/bsp-configure.m4, aclocal/bspopts.m4, aclocal/canonicalize-tools.m4, aclocal/check-bsp-cache.m4, aclocal/check-cxx.m4, aclocal/check-itron.m4, aclocal/check-multiprocessing.m4, aclocal/check-networking.m4, aclocal/check-newlib.m4, aclocal/check-posix.m4, aclocal/check-rdbg.m4, aclocal/check-tool.m4, aclocal/env-rtemsbsp.m4, aclocal/gcc-isystem.m4, aclocal/gcc-pipe.m4, aclocal/gcc-specs.m4, aclocal/i386-gas-code16.m4, aclocal/path-perl.m4, aclocal/ppc.m4, aclocal/prog-cc.m4, aclocal/prog-ccas.m4, aclocal/prog-cxx.m4, aclocal/prog-gnat.m4, aclocal/rtems-debug.m4, aclocal/rtems-flags.m4, aclocal/rtems-test-no-pause.m4, aclocal/target.m4: Remove (Unused). * automake/leaf.am, automake/force-preinstall.am: Remove (Unused). * Makefile.am: Reflect changes above.
* 2003-07-03 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-07-031-1/+1
| | | | * aclocal/version.m4: Updated to rtems-ss-20030703.
* 2003-06-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-06-121-2/+11
| | | | | | | | | | * configure.ac: Remove "BLEEDING EDGE" warning. Put docs into RTEMS_BUILD_CONFIG_SUBDIRS. * acinclude.m4: Add AC_PREREQ(2.57). Major overhaul (PR 412). * aclocal/prog-cc.m4: Add RTEMS_GCC_ISYSTEM. * aclocal/gcc-isystem.m4: New. * Makefile.am: Add aclocal/gcc-isystem.m4.
* 2003-06-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-06-121-0/+25
* 2003-05-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-05-272-6/+0
| | | | | | | | | PR 321: * aclocal/check-bsp-cache.m4: Remove support for profile-variant. * aclocal/env-rtemsbsp.m4 * automake/compile.am * automake/host.am * automake/local.am
* 2003-05-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-05-161-1/+1
| | | | | | * aclocal/check-cxx.m4: Remove LIBSUFFIX_VA. * automake/compile.am: Remove LIBSUFFIX_VA. Merger from rtems-4-6-branch.
* 2003-04-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-04-171-1/+1
| | | | * aclocal/version.m4: Updated to rtems-ss-20030417.
* 2003-04-11 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-04-111-1/+1
| | | | * aclocal/version.m4: Updated to rtems-ss-20030411.
| | | | * aclocal/version.m4: Updated to rtems-ss-20020411.
* Merger from rtems-4-6-branchRalf Corsepius2003-03-101-7/+1
* 2003-02-14 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-02-141-1/+0
| | | | | * README.configure, aclocal/rtems-cpu-subdirs.m4: Remove a29k references.
* Merger from rtems-4-6-branch.Ralf Corsepius2003-02-141-0/+3
* 2003-01-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-01-281-1/+1
| | | | * aclocal/version.m4: Updated to rtems-ss-20030128.
* 2001-01-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-01-162-2/+2
| | | | | * aclocal/rtems-cpu-subdirs.m4: Print out RTEMS_CPU in error message. * aclocal/enable-cxx.m4: Use $enable_cxx instead of $enableval.
* 2002-12-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-12-191-13/+10
| | | | | * aclocal/prog-cxx.m4: Remove RTEMS_PROG_CXX. Rework RTEMS_PROG_CXX_FOR_TARGET.
