* README.configure, aclocal/bsp-alias.m4: Rename EP5200 to IceCube
since that is the nickname for the Freescale evaluation board it is
based upon. BSP was tested on a Freescale MPC5200LITE.
* Makefile.maint, configure.ac, release_support: Remove RDBG.
* aclocal/enable-rdbg.m4: Removed.
many different versions of new exception handling code to shared sources.
* aclocal/bsp-alias.m4, README.configure: Add ep5200, IceCube, 5200Lite.
* README.configure, aclocal/check-bsps.m4: Remove references to
mbx860_1b since it is just an alternate name for the mbx860_001b.
* README.configure, aclocal/bsp-alias.m4, aclocal/check-bsps.m4:
Per Jiri Gaisler remove unused erc32nfp and leon1 BSP variants.
* configure.ac: Remove all macro implementations and use only the
static inline. Static inline functions are now well supported so
there is no reason for duplicate maintenance.
* aclocal/enable-inlines.m4: Removed.
* aclocal/rtems-top.m4: Remove RTEMS_API.
* aclocal/version.m4: Add RTEMS_API. Bump RTEMS_API to 4.8.
* aclocal/version.m4: Bump version to 4.7.99.0.
* aclocal/version.m4: Updated to rtems-4.6.99.3.
* aclocal/bsp-alias.m4: Revert Joel's 2006-01-10 change.
Alpha-sort the aliases list.
* aclocal/bsp-alias.m4: Add sis as alias of erc32.
* aclocal/bsp-alias.m4: Remove brs5l. Remove leon2.
Alias leon1 to leon2. Add sis.
* aclocal/check_bsps.m4: Remove brs5l.
Remove leon. Add leon2. Add sis to erc32 family.
PR 851/bsps
* aclocal/bsp-alias.m4, aclocal/check-bsps.m4: Add gen5200 BSP
family.
* aclocal/check-bsps.m4: Add the plethora of mbx* BSP.
* aclocal/version.m4: Updated to rtems-4.6.99.2.
* aclocal/enable-itron.m4: Allow unix.
* aclocal/check-bsps.m4: Use ls instead of globs to pickup
bsp_specs.
* aclocal/check-bsps.m4: Add MVME2100 BSP as alias of
motorola_shared.
* aclocal/bsp-alias.m4: Add MVME2100 BSP as alias of motorola_shared.
* alocal/check-custom-bsp.m4: Reflect new location of bspkit*cfg.
* aclocal/check-bsps.m4: Add bspkit support. Don't check for
presence of *.cfg.
* aclocal/check-custom-bsp.m4: Add bspkit support.
* aclocal/enable-bare.m4: Remove.
* aclocal/rtems-cpu-subdirs.m4: Remove (unused).
* aclocal/version.m4: Updated to rtems-4.6.99.1.
* aclocal/rtems-top.m4: Remove ENDIF.
Remove with_target_subdir defaulting to '.'.
* acinclude.m4: Add --includedir to sub_configure_args.
* aclocal/rtems-top.m4: Sync with c/src/aclocal/rtems-top.m4
* Makefile.am: Cosmetics.
* Makefile.am: DIST_SUBDIRS = $(SUBDIRS).
Rework dist-hook.
* configure.ac: Reflect changes to RTEMS_ENABLE_RTEMSBSP.
* aclocal/enable-rtemsbsp.m4: Add support for --disable-rtemsbsp.
* VERSION: 4.6.99.0.
* aclocal/version.m4: 4.6.99.0.
* aclocal/bsp-alias.m4: Readd aliases for p4600 and p4650
which were accidentally removed when purging the mips64orion.
* aclocal/rpm.m4: Make osversions the default.
* aclocal/rtems-top.m4: Remove check for version.m4 (Breaks make
distcheck).
* aclocal/rpms.m4: New (extracted from scripts/configure.ac).
* configure.ac: Require automake >= 1.8.2.
* aclocal/check-bsps.m4: Also test for make/custom/*.cfg.
* aclocal/bsp-alias.m4, aclocal/rtems-cpu-subdirs.m4: mips64orion port
removed as mips port more completely covers the MIPS family.
* aclocal/version.m4: Updated to rtems-20031217-test.
* aclocal/bsp-alias.m4, aclocal/canonical-target-name.m4,
aclocal/check-bsps.m4, aclocal/check-custom-bsp.m4,
aclocal/enable-bare.m4, aclocal/enable-cxx.m4,
aclocal/enable-inlines.m4, aclocal/enable-itron.m4,
aclocal/enable-multiprocessing.m4, aclocal/enable-networking.m4,
aclocal/enable-posix.m4, aclocal/enable-rdbg.m4,
aclocal/enable-rtems-debug.m4, aclocal/enable-rtemsbsp.m4,
aclocal/enable-tests.m4, aclocal/multilib.m4,
aclocal/path-ksh.m4, aclocal/project-root.m4,
aclocal/rtems-top.m4, aclocal/tool-paths.m4,
acinclude.m4:
Fix underquoting to silence automake-1.8.
* aclocal/config-subdirs.m4: Remove.
* aclocal/canonical-host.m4: Remove.
* aclocal/check-cpu.m4: Remove.
* Makefile.am: Remove reference to aclocal/check-cpu.m4.
* acinclude.m4 (RTEMS_TARGET_CONFIG_SUBDIR): Check for presence of
$1 in $srcdir before adding dir to SUBDIRS.
* README.configure, aclocal/rtems-cpu-subdirs.m4: Removing HPPA port.
* aclocal/rtems-top.m4: Add RTEMS_API.
AC_DEFAULT_PREFIX([/opt/rtems-][RTEMS_API]).
* aclocal/enable-rtems-debug.m4: New (Missed in yesterday's
patches).
* aclocal/enable-tests.m4: Change to support
--enable-tests=no|yes|samples, default is samples.
* aclocal/bsp-arg-enable.m4, aclocal/bsp-configure.m4,
aclocal/bspopts.m4, aclocal/canonicalize-tools.m4,
aclocal/check-bsp-cache.m4, aclocal/check-cxx.m4,
aclocal/check-itron.m4, aclocal/check-multiprocessing.m4,
aclocal/check-networking.m4, aclocal/check-newlib.m4,
aclocal/check-posix.m4, aclocal/check-rdbg.m4,
aclocal/check-tool.m4, aclocal/env-rtemsbsp.m4,
aclocal/gcc-isystem.m4, aclocal/gcc-pipe.m4,
aclocal/gcc-specs.m4, aclocal/i386-gas-code16.m4,
aclocal/path-perl.m4, aclocal/ppc.m4,
aclocal/prog-cc.m4, aclocal/prog-ccas.m4,
aclocal/prog-cxx.m4, aclocal/prog-gnat.m4,
aclocal/rtems-debug.m4, aclocal/rtems-flags.m4,
aclocal/rtems-test-no-pause.m4, aclocal/target.m4:
Remove (Unused).
* automake/leaf.am, automake/force-preinstall.am:
Remove (Unused).
* aclocal/version.m4: Updated to rtems-ss-20030703.
