* | Change RTEMS_API from 5.0 to 5 | Sebastian Huber | 2017-11-13 | 1 | -1/+1 |
| | | | | | | | This fixes the legacy Makefile based build system which expects RTEMS_API to be identical to the tool chain version. Update #3220. | ||||
* | Upgrade to 5.0.0 | Sebastian Huber | 2017-11-09 | 1 | -2/+2 |
| | | | | | | | Tool name will be "rtems5", e.g. arm-rtems5-gcc. Next release will 5.1.0. Branch version after release will be 5.1.1. Next master will be 6.0.0. | ||||
* | Upgrade to 4.11.99.0 | Sebastian Huber | 2015-09-11 | 1 | -2/+2 |
* | 2011-03-04 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-03-04 | 1 | -1/+1 |
| | | | | | * Makefile.maint, aclocal/rpm.m4, aclocal/rtems-top.m4, aclocal/version.m4: Rename RTEMS_API into _RTEMS_API. | ||||
* | 2010-06-07 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-06-07 | 1 | -2/+2 |
| | | | | | * aclocal/version.m4: Bump RTEMS_API to 4.11. Bump _RTEMS_VERSION to 4.10.99.0. | ||||
* | 2008-09-22 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-09-22 | 1 | -2/+2 |
| | | | | | * aclocal/version.m4: Bump RTEMS_API to 4.10. Bump _RTEMS_VERSION to 4.9.99.0. | ||||
* | 2007-09-21 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-09-21 | 1 | -2/+2 |
| | | | | | * aclocal/version.m4: Bump RTEMS_API to 4.9. Bump RTEMS_VERSION to 4.8.99.0. | ||||
* | Upgrade to 4.7.99.2 | Joel Sherrill | 2007-08-07 | 1 | -1/+1 |
* | Upgrade to 4.7.99.1 | Joel Sherrill | 2007-03-13 | 1 | -1/+1 |
* | Revert to version 4.7.99-0 | Ralf Corsepius | 2007-02-22 | 1 | -1/+1 |
* | Testing: Upgrade to 4.7.99.1 | Ralf Corsepius | 2007-02-22 | 1 | -1/+1 |
* | 2006-10-18 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-10-18 | 1 | -0/+2 |
| | | | | | * aclocal/rtems-top.m4: Remove RTEMS_API. * aclocal/version.m4: Add RTEMS_API. Bump RTEMS_API to 4.8. | ||||
* | 2006-10-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-10-17 | 1 | -1/+1 |
| | | | | * aclocal/version.m4: Bump version to 4.7.99.0. | ||||
* | 2006-04-18 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-04-18 | 1 | -1/+1 |
| | | | | * aclocal/version.m4: Updated to rtems-4.6.99.3. | ||||
* | 2005-09-02 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-09-02 | 1 | -1/+1 |
| | | | | * aclocal/version.m4: Updated to rtems-4.6.99.2. | ||||
* | 2004-07-28 | Joel Sherrill | 2004-07-28 | 1 | -1/+1 |
| | | | | * aclocal/version.m4: Updated to rtems-4.6.99.1. | ||||
* | 2004-02-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-02-12 | 1 | -1/+1 |
| | | | | | * VERSION: 4.6.99.0. * aclocal/version.m4: 4.6.99.0. | ||||
* | 2003-12-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-12-17 | 1 | -1/+1 |
| | | | | * aclocal/version.m4: Updated to rtems-20031217-test. | ||||
* | 2003-07-03 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-07-03 | 1 | -1/+1 |
| | | | | * aclocal/version.m4: Updated to rtems-ss-20030703. | ||||
* | 2003-04-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-04-17 | 1 | -1/+1 |
| | | | | * aclocal/version.m4: Updated to rtems-ss-20030417. | ||||
* | 2003-04-11 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-04-11 | 1 | -1/+1 |
| | | | | * aclocal/version.m4: Updated to rtems-ss-20030411. | ||||
| | | | | * aclocal/version.m4: Updated to rtems-ss-20020411. | ||||
* | 2003-01-28 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-01-28 | 1 | -1/+1 |
| | | | | * aclocal/version.m4: Updated to rtems-ss-20030128. | ||||
* | 2002-11-18 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-11-18 | 1 | -1/+1 |
| | | | | * aclocal/version.m4: Updated to rtems-ss-20021118. | ||||
* | 2002-11-11 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-11-11 | 1 | -1/+1 |
| | | | | * aclocal/version.m4: Updated to rtems-ss-20021111. | ||||
* | 2002-10-21 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-10-21 | 1 | -1/+1 |
| | | | | * aclocal/version.m4: Updated to rtems-20021021-test. | ||||
* | 2002-10-07 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-10-07 | 1 | -1/+1 |
| | | | | * aclocal/version.m4: Updated to rtems-ss-20021007. | ||||
* | 2002-10-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-10-04 | 1 | -1/+1 |
| | | | | * aclocal/version.m4: Updated to rtems-ss-20021004. | ||||
* | 2002-08-07 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-08-07 | 1 | -1/+1 |
| | | | | * aclocal/version.m4: Updated to rtems-ss-20020807. | ||||
* | 2002-07-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-07-17 | 1 | -1/+1 |
| | | | | * aclocal/version.m4: Updated to rtems-ss-20020717. | ||||
* | 2002-06-28 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-06-28 | 1 | -1/+1 |
| | | | | * aclocal/version.m4: Updated to rtems-ss-20020628. | ||||
* | 2002-05-28 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-05-28 | 1 | -2/+2 |
| | | | | * aclocal/version.m4: Updated to rtems-ss-20020528. | ||||
* | 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2002-03-28 | 1 | -0/+2 |
* aclocal/version.m4: New file. * aclocal/rtems-top.m4: Add RTEMS_VERSIONING, replace VERSION w/ aclocal/version.m4. * bootstrap: Use aclocal/version.m4 instead of VERSION. * configure.ac: Use aclocal/version.m4 instead of VERSION. |
