path: root/aclocal/version.m4 (follow)
* Upgrade to 4.11.99.0Sebastian Huber2015-09-111-2/+2
* 2011-03-04 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-03-041-1/+1
| | | | | * Makefile.maint, aclocal/rpm.m4, aclocal/rtems-top.m4, aclocal/version.m4: Rename RTEMS_API into _RTEMS_API.
* 2010-06-07 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2010-06-071-2/+2
| | | | | * aclocal/version.m4: Bump RTEMS_API to 4.11. Bump _RTEMS_VERSION to 4.10.99.0.
* 2008-09-22 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2008-09-221-2/+2
| | | | | * aclocal/version.m4: Bump RTEMS_API to 4.10. Bump _RTEMS_VERSION to 4.9.99.0.
* 2007-09-21 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2007-09-211-2/+2
| | | | | * aclocal/version.m4: Bump RTEMS_API to 4.9. Bump RTEMS_VERSION to 4.8.99.0.
* Upgrade to 4.7.99.2Joel Sherrill2007-08-071-1/+1
* Upgrade to 4.7.99.1Joel Sherrill2007-03-131-1/+1
* Revert to version 4.7.99-0Ralf Corsepius2007-02-221-1/+1
* Testing: Upgrade to 4.7.99.1Ralf Corsepius2007-02-221-1/+1
* 2006-10-18 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2006-10-181-0/+2
| | | | | * aclocal/rtems-top.m4: Remove RTEMS_API. * aclocal/version.m4: Add RTEMS_API. Bump RTEMS_API to 4.8.
* 2006-10-17 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2006-10-171-1/+1
| | | | * aclocal/version.m4: Bump version to 4.7.99.0.
* 2006-04-18 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2006-04-181-1/+1
| | | | * aclocal/version.m4: Updated to rtems-4.6.99.3.
* 2005-09-02 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2005-09-021-1/+1
| | | | * aclocal/version.m4: Updated to rtems-4.6.99.2.
* 2004-07-28Joel Sherrill2004-07-281-1/+1
| | | | * aclocal/version.m4: Updated to rtems-4.6.99.1.
* 2004-02-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-121-1/+1
| | | | | * VERSION: 4.6.99.0. * aclocal/version.m4: 4.6.99.0.
* 2003-12-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-12-171-1/+1
| | | | * aclocal/version.m4: Updated to rtems-20031217-test.
* 2003-07-03 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-07-031-1/+1
| | | | * aclocal/version.m4: Updated to rtems-ss-20030703.
* 2003-04-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-04-171-1/+1
| | | | * aclocal/version.m4: Updated to rtems-ss-20030417.
* 2003-04-11 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-04-111-1/+1
| | | | * aclocal/version.m4: Updated to rtems-ss-20030411.
| | | | * aclocal/version.m4: Updated to rtems-ss-20020411.
* 2003-01-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-01-281-1/+1
| | | | * aclocal/version.m4: Updated to rtems-ss-20030128.
* 2002-11-18 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-11-181-1/+1
| | | | * aclocal/version.m4: Updated to rtems-ss-20021118.
* 2002-11-11 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-11-111-1/+1
| | | | * aclocal/version.m4: Updated to rtems-ss-20021111.
* 2002-10-21 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-10-211-1/+1
| | | | * aclocal/version.m4: Updated to rtems-20021021-test.
* 2002-10-07 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-10-071-1/+1
| | | | * aclocal/version.m4: Updated to rtems-ss-20021007.
* 2002-10-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-10-041-1/+1
| | | | * aclocal/version.m4: Updated to rtems-ss-20021004.
* 2002-08-07 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-08-071-1/+1
| | | | * aclocal/version.m4: Updated to rtems-ss-20020807.
* 2002-07-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-07-171-1/+1
| | | | * aclocal/version.m4: Updated to rtems-ss-20020717.
* 2002-06-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-06-281-1/+1
| | | | * aclocal/version.m4: Updated to rtems-ss-20020628.
* 2002-05-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-05-281-2/+2
| | | | * aclocal/version.m4: Updated to rtems-ss-20020528.
* 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-03-281-0/+2
* aclocal/version.m4: New file. * aclocal/rtems-top.m4: Add RTEMS_VERSIONING, replace VERSION w/ aclocal/version.m4. * bootstrap: Use aclocal/version.m4 instead of VERSION. * configure.ac: Use aclocal/version.m4 instead of VERSION.
