path: root/aclocal/prog-cc.m4 (follow)
* Patch from Ralf Corseipus to fix latent configure problems suddenly triggered:Joel Sherrill1998-05-201-34/+24
| | | | | | | | | | | | | | | | | | | | | | | The breakdown: * CC_FOR_TARGET and CXX_FOR_TARGET were not correctly re-read from autoconf's configuration cache (config.cache) * If <target>-[gcc|g++] was not found while running configure, the config macros tried to use other (wrong) compilers (e.g. cc). Changes: * New RTEMS_PROG_CC macro (aclocal/prog-cc.m4). * New RTEMS_PROG_CXX macro (aclocal/prog-cxx.m4) * Moved a shell script fragment from configure.in to a new m4-autoconf macro (New file: aclocal/tool-prefix.m4) * Minor changes to configure.in I tested it with linux/posix (native gcc/primary libc) and sh-rtems/gensh1 on a linux host and didn't notice any bugs related to the problems mentioned above. There seem to be more bugs with the posix bsp, but I consider them minor as the build run completed successfully. It is just too late for me to attempt to fix them now.
* Updated now that the phony crt0.c in newlib defines all odd symbolsJoel Sherrill1998-03-231-18/+1
| | | | that gcc automatically generates references to.
* Added enough symbols to the conftest.c program to make sure it wouldJoel Sherrill1998-03-211-1/+17
| | | | successfully link on both the powerpc and hppa1.1.
* New files missed in previous merge.Joel Sherrill1998-02-191-0/+76
