* aclocal/bsp-alias.m4, aclocal/canonical-target-name.m4,
aclocal/check-bsps.m4, aclocal/check-custom-bsp.m4,
aclocal/enable-bare.m4, aclocal/enable-cxx.m4,
aclocal/enable-inlines.m4, aclocal/enable-itron.m4,
aclocal/enable-multiprocessing.m4, aclocal/enable-networking.m4,
aclocal/enable-posix.m4, aclocal/enable-rdbg.m4,
aclocal/enable-rtems-debug.m4, aclocal/enable-rtemsbsp.m4,
aclocal/enable-tests.m4, aclocal/multilib.m4,
aclocal/path-ksh.m4, aclocal/project-root.m4,
aclocal/rtems-top.m4, aclocal/tool-paths.m4,
acinclude.m4:
Fix underquoting to silence automake-1.8.
* aclocal/env-rtemscpu.m4: Remove.
* aclocal/multi.m4: Remove.
* aclocal/multilib.m4: Remove RTEMS_ENABLE_MULTILIB_MASTER.
* configure.ac: Reworked for multilibs, reflect changes to aclocal/*.m4.
* aclocal/subdirs.m4: New file.
* aclocal/multi.m4: New file, adopted from autoconf-2.52 w/
modifications.
* aclocal/check-posix.m4: Apply AS_IF.
* aclocal/config-subdirs.m4: Reflect changes to other m4-macros.
* aclocal/env-rtemsbsp.m4: Add PROJECT_INCLUDE, PROJECT_RELEASE.
Add AM_CONDITIONAL(MULTILIB). Adapt GCC_SPECS to multilibs.
* aclocal/env-rtemscpu.m4: Remove RTEMS_BSP. Add support for
MULTIBUILDTOP, MULTISUBDIR. Adapt GCC_SPECS to multilibs.
Add PROJECT_INCLUDE, PROJECT_RELEASE, includedir, libdir.
* aclocal/multilib.m4: Fix m4-quoting, adopt automake-1.5's
OUTPUT_COMMANDS.
* aclocal/project-root.m4: Remove PROJECT_INCLUDE, PROJECT_RELEASE.
* aclocal/rtems-debug.m4: Minor cleanups.
* aclocal/rtems-top.m4: Minor cleanups.
* automake/compile.am: Further steps towards automake's rules.
* configure.in: autoupdate to autoconf-2.52.
* bootstrap: Add handling for configure.ac, make autoheader verbose,
fix auto*tool invocation order.
* aclocal/rtems-test-no-pause.m4: Introduce AC_HELP_STRING.
* aclocal/enable-bare.m4: Introduce AC_HELP_STRING.
* aclocal/enable-cxx.m4: Introduce AC_HELP_STRING.
* aclocal/enable-gcc28: Introduce AC_HELP_STRING.
* aclocal/enable-inlines.m4: Introduce AC_HELP_STRING.
* aclocal/enable-itron.m4: Introduce AC_HELP_STRING.
* aclocal/enable-libcdir.m4: Introduce AC_HELP_STRING.
* aclocal/enable-multiprocessing.m4: Introduce AC_HELP_STRING.
* aclocal/enable-networking.m4: Introduce AC_HELP_STRING.
* aclocal/enable-posix.m4: Introduce AC_HELP_STRING.
* aclocal/enable-rdbg.m4: Introduce AC_HELP_STRING.
* aclocal/enable-rtemsbsp.m4: Introduce AC_HELP_STRING.
* aclocal/enable-tests.m4: Introduce AC_HELP_STRING.
* aclocal/env-rtemsbsp.m4: Add AC_ARC_VAR(RTEMS_BSP), apply true in
RTEMS_CONFIG_PER_BSP conditional.
* aclocal/multilib.m4: Introduce AC_HELP_STRING.
* aclocal/rtems-debug.m4: Introduce AC_HELP_STRING.
* aclocal/rtems-top.m4: Add AC_PREFIX_DEFAULT(/opt/rtems).
* aclocal/gcc-pipe.m4: Use $GCC instead of ac_cv_prog_gcc (autoconf
standard).
* aclocal/gcc-specs.m4: Use $GCC instead of ac_cv_prog_gcc (autoconf
standard).
* aclocal/multilib.m4: Fix m4-quoting (BUG-FIX).
* aclocal/check-bsp-cache.m4: Fix m4-quoting (autoconf-2.49b).
* aclocal/prog-cc.m4: Use $GCC instead of ac_cv_prog_gcc (autoconf
standard), replace CC_FOR_TARGET with CC (BUG-FIX).
* aclocal/*: Replace with contents of macros/*.m4
* macros/: Remove.
* aclocal/ar-s.m4 aclocal/tool-prefix.m4: Remove.
* Makefile.am: Reflect changes to aclocal/ and macros/.
that makes --disable-multilib the default.
that is part of the multilib/gnu-canonicalization movement:
* New m4-macro: aclocal/multilib.am
* Suppress multiprocessing if --enable-multilib is given to
configure
For now this patch only suppresses multiprocessing if
--enable-multilib is given to configure and should not have any
other side-effects, ie. it works around a minor issue which prevents
introduction of multilibs in general.
The RTEMS_ENABLE_MULTILIB_MASTER macro is the core part to build
real multilibs, but can not be applied before other multilib related
issues with RTEMS have been solved. (e.g. sptables.h, bsp_specs,
Cygnus/Gnu canonicalization, _RTEMS_version, targopts.h, changing
the installation point/tooldir support, etc.).
