path: root/aclocal/enable-tests.m4 (follow)
* Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to correct theJoel Sherrill1999-04-121-4/+4
| | | | --enable-tests problem a better way.
* Eric Norum <eric@skatter.usask.ca> noticed that the documentation andJoel Sherrill1999-04-061-1/+1
| | | | configure scripts did not match on the default value of --enable-tests.
* Towards automake VIII patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1999-03-191-0/+15
OK, I 've made up my mind to cut a big chunk of my automake-patches (:-). Below you can find a drop-in replacement of the aclocal directory. It contains a lot of new macro files, most of them are directly cut from rtems top-level configure script, some are new some are identical to former versions. The motivation behind these files is to reuse parts from rtems current top-level configure.in script in up-coming subdirectory configure.in scripts. I'd like to ask you to untar the archive ontop of the source tree and to add/commit these files to CVS. Adding these files should not have any influence on RTEMS momentary configuration (except of you are required to run aclocal -I aclocal && autoconf afterwards), because most of them currently are not used at all. --------- BTW: Please upgrade to autoconf-2.13 and automake-2.4, if you havn't done this already (egcs/CVS require them, too). My upcoming automake files require automake-2.4 which requires autoconf-2.13 or later.
