* | build: Enable RISC-V SMP build | Sebastian Huber | 2018-06-28 | 1 | -1/+1 |
| | | | | Update #3433. | ||||
* | Require the user to provide a BSP list when build SMP or MP. | Chris Johns | 2018-04-10 | 1 | -3/+4 |
| | | | | Close 3383. | ||||
* | configure: Documentation | Sebastian Huber | 2013-06-12 | 1 | -1/+2 |
* | smp: Add ARM support | Sebastian Huber | 2013-05-31 | 1 | -1/+1 |
* | smp: Add PowerPC support | Sebastian Huber | 2013-05-31 | 1 | -1/+1 |
* | Revert: Remove CVS Ids | Joel Sherrill | 2012-05-07 | 1 | -0/+2 |
| | | | | | See http://www.rtems.org/pipermail/rtems-devel/2012-May/001006.html for details. | ||||
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 1 | -2/+0 |
* | 2011-05-24 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2011-06-28 | 1 | -1/+1 |
| | | | | | PR 1810/misc * ChangeLog: Fix previous damage. | ||||
* | 2011-03-16 Jennifer Averett <jennifer.averett@OARcorp.com> | Joel Sherrill | 2011-03-16 | 1 | -0/+18 |
PR 1729/cpukit * aclocal/enable-smp.m4: New file. |
