The d542af2e4304b663461330a60313fb6c4fdbf4db commit was a bad one.
The riscv32 and riscv64 targets share a riscv source directory. The
potential future powerpcspe and powerpc targets need this change as
well.
For example ${target_arch} is "riscv32" and ${cfg_arch} is "riscv".
well.
Update #3285.
Also generate an error if the architecure does not match the --target
architecture given to configure's command line.
Close #2641.
Close 3383.
for details.
* Makefile.am: DIST_SUBDIRS = $(SUBDIRS).
Rework dist-hook.
* configure.ac: Reflect changes to RTEMS_ENABLE_RTEMSBSP.
* aclocal/enable-rtemsbsp.m4: Add support for --disable-rtemsbsp.
* aclocal/bsp-alias.m4, aclocal/canonical-target-name.m4,
aclocal/check-bsps.m4, aclocal/check-custom-bsp.m4,
aclocal/enable-bare.m4, aclocal/enable-cxx.m4,
aclocal/enable-inlines.m4, aclocal/enable-itron.m4,
aclocal/enable-multiprocessing.m4, aclocal/enable-networking.m4,
aclocal/enable-posix.m4, aclocal/enable-rdbg.m4,
aclocal/enable-rtems-debug.m4, aclocal/enable-rtemsbsp.m4,
aclocal/enable-tests.m4, aclocal/multilib.m4,
aclocal/path-ksh.m4, aclocal/project-root.m4,
aclocal/rtems-top.m4, aclocal/tool-paths.m4,
acinclude.m4:
Fix underquoting to silence automake-1.8.
* aclocal/enable-bare.m4: Improve quoting of AC_HELP_STRING.
* aclocal/enable-cxx.m4: Improve quoting of AC_HELP_STRING.
* aclocal/enable-inlines.m4: Improve quoting of AC_HELP_STRING.
* aclocal/enable-itron.m4: Improve quoting of AC_HELP_STRING.
* aclocal/enable-multiprocessing.m4: Improve quoting of AC_HELP_STRING.
* aclocal/enable-networking.m4: Improve quoting of AC_HELP_STRING.
* aclocal/enable-posix.m4: Improve quoting of AC_HELP_STRING.
* aclocal/enable-rdbg.m4: Improve quoting of AC_HELP_STRING.
* aclocal/enable-rtemsbsp.m4: Improve quoting of AC_HELP_STRING.
* aclocal/enable-tests.m4: Improve quoting of AC_HELP_STRING.
(autoconf > 2.54 seems to have problems with the old form of
quoting).
* aclocal/enable-rtemsbsp.m4: Remove '\' in AC_MSG_ERROR
(autoconf > 2.54 complains about).
* configure.in: autoupdate to autoconf-2.52.
* bootstrap: Add handling for configure.ac, make autoheader verbose,
fix auto*tool invocation order.
* aclocal/rtems-test-no-pause.m4: Introduce AC_HELP_STRING.
* aclocal/enable-bare.m4: Introduce AC_HELP_STRING.
* aclocal/enable-cxx.m4: Introduce AC_HELP_STRING.
* aclocal/enable-gcc28: Introduce AC_HELP_STRING.
* aclocal/enable-inlines.m4: Introduce AC_HELP_STRING.
* aclocal/enable-itron.m4: Introduce AC_HELP_STRING.
* aclocal/enable-libcdir.m4: Introduce AC_HELP_STRING.
* aclocal/enable-multiprocessing.m4: Introduce AC_HELP_STRING.
* aclocal/enable-networking.m4: Introduce AC_HELP_STRING.
* aclocal/enable-posix.m4: Introduce AC_HELP_STRING.
* aclocal/enable-rdbg.m4: Introduce AC_HELP_STRING.
* aclocal/enable-rtemsbsp.m4: Introduce AC_HELP_STRING.
* aclocal/enable-tests.m4: Introduce AC_HELP_STRING.
* aclocal/env-rtemsbsp.m4: Add AC_ARC_VAR(RTEMS_BSP), apply true in
RTEMS_CONFIG_PER_BSP conditional.
* aclocal/multilib.m4: Introduce AC_HELP_STRING.
* aclocal/rtems-debug.m4: Introduce AC_HELP_STRING.
* aclocal/rtems-top.m4: Add AC_PREFIX_DEFAULT(/opt/rtems).
* aclocal/config-subdirs.m4: Let CC default to $host_alias-gcc in
TARGET_CONFIG_SUBDIRS.
* aclocal/enable-bsp.m4: fix quoting.
* aclocal/check-bsps.m4, aclocal/bsp-alias.m4: Add pc386dx.
* aclocal/enable-rtemsbsp.m4: Split out RTEMS_ENV_RTEMSBSP,
RTEMS_ENV_RTEMSCPU.
* aclocal/env-rtemsbsp.m4: New file for RTEMS_ENV_RTEMSBSP, add
special treatment for GCC_SPECS.
* aclocal/env-rtemscpu.m4: New file for RTEMS_ENV_RTEMSCPU, add
* aclocal/bsp-enable-arg.m4: New file, introduce RTEMS_BSP_ARG_ENABLE.
* aclocal/prog-cc.m4: Add AC_PROG_CPP, use build_os in GCCSED hack.
* automake/compile.am: New treatment of CPP, GCCSPECS, use `..`
instead of $(shell ..) for LIBC_LIB*.
* aclocal/*: Replace with contents of macros/*.m4
* macros/: Remove.
* aclocal/ar-s.m4 aclocal/tool-prefix.m4: Remove.
* Makefile.am: Reflect changes to aclocal/ and macros/.
* aclocal/enable-rtemsbsp.m4: Add RTEMS_ENABLE_BARE,
AC_SUBST(BARE_CPU_MODEL),AC_SUBST(BARE_CPU_CFLAGS).
* aclocal/i386-gas-code16.m4: AC_DEFINE NEW_GAS.
* aclocal/target.m4: Cleanup comments
* Automake/compile.am: Add DEFS support to keep building happy.
that is another small step toward multilibs:
* Eliminate RTEMS_CHECK_CUSTOM_BSP from all configure.ins below exec/
* Add RTEMS_CHECK_CUSTOM_BSP to the multilib-disabled branch in
RTEMS_ENV_RTEMSCPU to preserve the old per-BSP building scheme
functional.
* --enable-multilibs is still non-functional
* This patch should not have any influence on the old building
scheme (--disable-multilib should silently fall back to the old
building scheme).
* running ./bootstrap is required after applying the patch
that is a somewhat experimental, multilib-related patch:
* Use RTEMS_ENV_RTEMSCPU instead of RTEMS_ENV_RTEMSBSP in
configure.ins below exec/.
At the moment, RTEMS_ENV_RTEMSCPU is more or less an optical change
to emphasize that these subdirectories shall not depend on RTEMS_BSP
than a real behavioral change.
* Add AC_DEFINE_* to several aclocal/*.m4 macros to prepare
autoheader/autoconf generated targopts.h and similiar configuration
headers.
* c/src/configure.in: remove exec from cfg_subdirs if multilibs are
enabled (c/src is build per bsp, exec shall be build per cpu in c/
or from the toplevel in future, when multilibs are enabled.)
* This patch should not have any impact on the current building scheme.
* --enable-multilib still does not work.
* running bootstrap from the toplevel directory is required.
CVS:
CVS: Committing in .
CVS:
CVS: Modified Files:
*.cfg files.
dependencies
automake and RTEMS make rules
convention)
performs automatically.
WARNING:
Makefile.ams.
mkdir c/src/librpc
mkdir c/src/librpc/src
mkdir c/src/librpc/include
rm -rf c/src/lib/librpc
rm -rf c/src/lib/include/rpc
in the required order .
# make[5]: Entering directory
# mips64orion-rtems-gcc -v
# mips64orion-rtems-ld -v
