path: root/aclocal/enable-multiprocessing.m4 (follow)
* 2002-06-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-06-301-5/+4
| | | | | * aclocal/check-multiprocessing.m4: Reworked. * aclocal/enable-multiprocessing.m4: Remove RTEMS_HAS_MULTIPROCESSING.
* 2001-07-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-131-1/+1
| | | | | | | | | | | | | | | | | | | | | | | | * configure.in: autoupdate to autoconf-2.52. * bootstrap: Add handling for configure.ac, make autoheader verbose, fix auto*tool invocation order. * aclocal/rtems-test-no-pause.m4: Introduce AC_HELP_STRING. * aclocal/enable-bare.m4: Introduce AC_HELP_STRING. * aclocal/enable-cxx.m4: Introduce AC_HELP_STRING. * aclocal/enable-gcc28: Introduce AC_HELP_STRING. * aclocal/enable-inlines.m4: Introduce AC_HELP_STRING. * aclocal/enable-itron.m4: Introduce AC_HELP_STRING. * aclocal/enable-libcdir.m4: Introduce AC_HELP_STRING. * aclocal/enable-multiprocessing.m4: Introduce AC_HELP_STRING. * aclocal/enable-networking.m4: Introduce AC_HELP_STRING. * aclocal/enable-posix.m4: Introduce AC_HELP_STRING. * aclocal/enable-rdbg.m4: Introduce AC_HELP_STRING. * aclocal/enable-rtemsbsp.m4: Introduce AC_HELP_STRING. * aclocal/enable-tests.m4: Introduce AC_HELP_STRING. * aclocal/env-rtemsbsp.m4: Add AC_ARC_VAR(RTEMS_BSP), apply true in RTEMS_CONFIG_PER_BSP conditional. * aclocal/multilib.m4: Introduce AC_HELP_STRING. * aclocal/rtems-debug.m4: Introduce AC_HELP_STRING. * aclocal/rtems-top.m4: Add AC_PREFIX_DEFAULT(/opt/rtems).
* Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1999-03-291-0/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | Yet some more modifications, I would recommend to be considered before releasing a snapshot: 1. Cleanup to aclocal/ cvs rm -f aclocal/cygwin.m4 cvs rm -f aclocal/exeext.m4 They are neither used nor needed anymore, however they also don't disturb (we use autoconf-2.13's AC_EXEEXT instead, now) ---------- 2. rtems-rc-19990328-0.diff Some (minor) bug-fixes: * make/Templates/Makefile.inc.in: use the new installation directory ($(prefix)/ instead of $(prefix)/rtems/) * c/src/exec/score/tools/generic/Makefile.am: added line to include local.am * c/src/exec/score/tools/*/configure.in: added CVS Id header ---------- 3. rtems-rc-19990328-1.diff Enhancements and cleanups to autogen, rtems-polish.sh, configure.in etc. * autogen: Use the file "VERSION" to detect RTEMS toplevel directory, extended usage-message, use "find -print" * c/update-tools/cipolish: New script to beautify configure.in scripts * c/update-tools/rtems-polish.sh: Use the file "VERSION" to detect RTEMS toplevel directory, extended usage-message, added variable for perl scripts' subdirectory, use "find -print", cipolish support, new options -ac -am -ci. * aclocal/*.m4, configure.in: moved some AC_SUBST lines to aclocal/*.m4 (reduces size of configure.in scripts, eases splitting configure.in scripts). ----------
* Towards automake VIII patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1999-03-191-0/+12
OK, I 've made up my mind to cut a big chunk of my automake-patches (:-). Below you can find a drop-in replacement of the aclocal directory. It contains a lot of new macro files, most of them are directly cut from rtems top-level configure script, some are new some are identical to former versions. The motivation behind these files is to reuse parts from rtems current top-level configure.in script in up-coming subdirectory configure.in scripts. I'd like to ask you to untar the archive ontop of the source tree and to add/commit these files to CVS. Adding these files should not have any influence on RTEMS momentary configuration (except of you are required to run aclocal -I aclocal && autoconf afterwards), because most of them currently are not used at all. --------- BTW: Please upgrade to autoconf-2.13 and automake-2.4, if you havn't done this already (egcs/CVS require them, too). My upcoming automake files require automake-2.4 which requires autoconf-2.13 or later.
