path: root/aclocal/enable-itron.m4 (follow)
* 2000-11-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-091-5/+3
| | | | | | | | | | | | | | | | | * aclocal/enable-itron.m4: Remove changequotes (autoconf-2.49b). * aclocal/enable-posix.m4: Remove changequotes (autoconf-2.49b), use $host instead of $target (BUG-FIX). * configure.in: Use $target and $host instead of $target_alias and $host_alias (autoconf-2.49b). * aclocal/check-newlib.m4: Remove CC_FOR_TARGET (BUG-FIX) * aclocal/sysv-ipc.m4: Move AC_DEFINE outside of AC_CACHE (BUG-FIX) NOTES: * autoconf-2.49b depredicates using changequotes. * The changes to configure.in are due to cleanups in autoconf-2.49b's implemention of canonicalization. With autoconf-2.1x it wasn't always clear, when to use $xxx or $xxx_alias. Now this is clear.
* Patch from James Housley <jim@thehousleys.net> to address FreeBSD 4.xJoel Sherrill2000-06-161-1/+1
| | | | build issues.
* Merged from 4.5.0-beta3aJoel Sherrill2000-06-121-2/+2
* Patch rtems-rc-19991123-rc-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1999-11-301-1/+0
| | | | | | | | | | | | | | | | | | | | | | | which (among other things) converted the mptests to automake. SUB_DIRS was used instead of SUBDIRS in some Makefile.ins (apparently a leftover from moving the start* directories) Addtional major bugs: * psxtests/include was empty (incomplete psxtests changes). * bogus handling of *.scn in itrontests (screens/sptests vs. screens/itrontests installation dirs) In addition I have added a few more changes (I couldn't resist) * automake support for itrontests * OPERATION_COUNT support in tmitrontests/ * automake support for tmitrontests * automake suppport for mptests * Some (minor) corrections to several configure.in/Makefile.ams => c/src/tests/ is completly under automake control, now. => we could start to sort out the structural issues with c/src/tests (tests/support, stubdr, tools, get "make dist" working)
* Miscellaneous patches from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1999-11-231-1/+1
| | | | | that are part of the Makefile.am conversion effort but were missed in the previous commits.
* This patch adds the basic framework for the ITRON 3.0 API implementationJoel Sherrill1999-11-091-0/+36
for RTEMS.
