path: root/aclocal/check-tool.m4 (follow)
* Generate an error if no valid gcc is found when configure runs.Chris Johns2018-04-101-0/+9
| | | | Close #3385.
* 2003-08-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-211-11/+0
| | | | | | | | | | | | | | | | | | | | | * aclocal/bsp-arg-enable.m4, aclocal/bsp-configure.m4, aclocal/bspopts.m4, aclocal/canonicalize-tools.m4, aclocal/check-bsp-cache.m4, aclocal/check-cxx.m4, aclocal/check-itron.m4, aclocal/check-multiprocessing.m4, aclocal/check-networking.m4, aclocal/check-newlib.m4, aclocal/check-posix.m4, aclocal/check-rdbg.m4, aclocal/check-tool.m4, aclocal/env-rtemsbsp.m4, aclocal/gcc-isystem.m4, aclocal/gcc-pipe.m4, aclocal/gcc-specs.m4, aclocal/i386-gas-code16.m4, aclocal/path-perl.m4, aclocal/ppc.m4, aclocal/prog-cc.m4, aclocal/prog-ccas.m4, aclocal/prog-cxx.m4, aclocal/prog-gnat.m4, aclocal/rtems-debug.m4, aclocal/rtems-flags.m4, aclocal/rtems-test-no-pause.m4, aclocal/target.m4: Remove (Unused). * automake/leaf.am, automake/force-preinstall.am: Remove (Unused). * Makefile.am: Reflect changes above.
* 2002-02-07 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-081-3/+4
| | | | | * aclocal/check-tool.m4: Remove AC_CHECK_TOOL_PREFIX, conditionalize check upon host_alias != build_alias.
* 2000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-031-0/+10
* aclocal/canonicalize-tools.m4, aclocal/check-tool.m4, aclocal/prog-cc.m4, aclocal/prog-cxx.m4: Replace AC_CHECK_TOOL with an RTEMS specific but more restrictive autoconf macro.
