path: root/aclocal/check-multiprocessing.m4 (follow)
* 2002-06-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-06-301-28/+24
| | | | | * aclocal/check-multiprocessing.m4: Reworked. * aclocal/enable-multiprocessing.m4: Remove RTEMS_HAS_MULTIPROCESSING.
* Patch rtems-rc-20000713-1-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-07-131-1/+3
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | that is yet another multilib-related structual cleanup patch: Changes: * Make RTEMS_TEST_NO_PAUSE a tests/ subpackage specific option. - Remove RTEMS_TEST_NO_PAUSE from custom/*.cfg, targopts.h and cpuopts.h. - Add autoconf macros RTEMS_*_RTEMS_TEST_NO_PAUSE (aclocal/rtems-test-no-pause.m4). - Add RTEMS_*_RTEMS_TEST_NO_PAUSE support to sptests/configure.ins and tmtests/configure.in. These are the only subdirectories which currently apply RTEMS_TEST_NO_PAUSE. - Add autoconf-DEFS support to all test subpackages' configure.ins below tests/. I.e. AC_DEFINES now get explicitly propagated as preprocessor defines into Makefiles, cf. AM_CPPFLAGS in tests/*/*.am, instead of using a global config-files. - Remove NDEBUG from custom/*.cfg. * AC_DEFINE POSIX_API, ITRON_API and MULTIPROCESSING in exec/configure.in, only. - All other sources now should relay on the values from cpuopts.h and should not define them themselves. - Several related changes to many configure.ins * Bug-fixes to RTEMS_*_RTEMS_DEBUG macros (Actually workarounds to quoting bugs in autoconf). Notes: * This patch is rather immature and only tested for a small subset of BSPs (requires the tests to be enabled and therefore takes an tremendous amount of disc space and time.) * The patches to *cfg were generated by a script. Expect file formating changes :)
* Patch rtems-rc-20000705-3.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-07-061-0/+6
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | that is a somewhat experimental, multilib-related patch: Changes: * Use RTEMS_ENV_RTEMSCPU instead of RTEMS_ENV_RTEMSBSP in configure.ins below exec/. At the moment, RTEMS_ENV_RTEMSCPU is more or less an optical change to emphasize that these subdirectories shall not depend on RTEMS_BSP than a real behavioral change. * Add AC_DEFINE_* to several aclocal/*.m4 macros to prepare autoheader/autoconf generated targopts.h and similiar configuration headers. * c/src/configure.in: remove exec from cfg_subdirs if multilibs are enabled (c/src is build per bsp, exec shall be build per cpu in c/ or from the toplevel in future, when multilibs are enabled.) Notes: * This patch should not have any impact on the current building scheme. * --enable-multilib still does not work. * running bootstrap from the toplevel directory is required. CVS: ---------------------------------------------------------------------- CVS: Enter Log. Lines beginning with `CVS:' are removed automatically CVS: CVS: Committing in . CVS: CVS: Modified Files: CVS: c/src/tests/libtests/termios/init.c CVS: ----------------------------------------------------------------------
* Patch rtems-rc-20000627-1 from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-06-291-6/+13
| | | | | | | | | | | | | | | | | | | | | that is part of the multilib/gnu-canonicalization movement: Changes: * New m4-macro: aclocal/multilib.am * Suppress multiprocessing if --enable-multilib is given to configure Notes: For now this patch only suppresses multiprocessing if --enable-multilib is given to configure and should not have any other side-effects, ie. it works around a minor issue which prevents introduction of multilibs in general. The RTEMS_ENABLE_MULTILIB_MASTER macro is the core part to build real multilibs, but can not be applied before other multilib related issues with RTEMS have been solved. (e.g. sptables.h, bsp_specs, Cygnus/Gnu canonicalization, _RTEMS_version, targopts.h, changing the installation point/tooldir support, etc.).
* Patch rtems-rc-20000614-1-cvs.diff from Ralf CorsepiusJoel Sherrill2000-06-141-2/+2
| | | | | | | | | <corsepiu@faw.uni-ulm.de> that addresses a couple of minor configuration issues which popped up when experimenting with multilibs. Note: The multigen generated make/custom/bare-*.cfg will still be non-functional, even after having applied this patch.
* Merged from 4.5.0-beta3aJoel Sherrill2000-06-121-1/+2
* Patch rtems-rc-19991117-4.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1999-11-221-0/+1
* Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1999-10-041-0/+2
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | The patch below actuallly consists of two patches: 1) moving librpc to c/src/librpc similar to what has been done to librtems++ 2) reworked configure scripts, many safety and dependency checks added to aclocal/*.m4 macros + configuration fixes. To apply: mkdir c/src/librpc mkdir c/src/librpc/src cp c/src/lib/librpc/*.c c/src/librpc/src cp c/src/lib/librpc/Makefile.in c/src/librpc/src mkdir c/src/librpc/include mkdir c/src/librpc/include/rpc cp c/src/lib/include/rpc/* c/src/librpc/include/rpc patch -p1 < ../rtems-rc-19990820-7.diff rm -rf c/src/lib/librpc rm -rf c/src/lib/include/rpc ./autogen The additional checks in aclocal/*m4 macros add rather restrictive, sometimes unnecessarily restrictive constraints on the sequence of how macros can be used in a configure.in script. Adding them has let my problems with some more complicated configuration options vanish. Apparently some macros had not been in the required order . ---- Now I still get some linking errors for some cpus and bsps, esp when linking cdtest, but also at other locations: e.g. this happens for mips64orion/p4600: # make[5]: Entering directory `/lfs/poseidon/users/rtems/src/multi/build/mips64orion-rtems/c/p4600/tests/samples/hello' /opt/rtems/bin/mips64orion-rtems-gcc --pipe -B../../../../../../p4600/lib/ -specs bsp_specs -qrtems -DP4000 -DCPU_R4000 -DP3_DIAG -D_R4000 -D__mips=3 -mcpu=4600 -G0 -I../../../../../../p4600/lib/include/networking -g -Wall -ansi -fasm -O4 -fomit-frame-pointer -o o-p4600/hello.exe o-p4600/init.o ../../../../../../p4600/lib/no-dpmem.rel ../../../../../../p4600/lib/no-event.rel ../../../../../../p4600/lib/no-msg.rel ../../../../../../p4600/lib/no-mp.rel ../../../../../../p4600/lib/no-part.rel ../../../../../../p4600/lib/no-signal.rel ../../../../../../p4600/lib/no-timer.rel ../../../../../../p4600/lib/no-rtmon.rel /opt/rtems/mips64orion-rtems/lib/libc.a(dtoa.o): In function `_dtoa_r': /opt/hermes/embedded/build/build-mips64orion-tools/mips64orion-rtems/newlib/libc/stdlib/../../../../../src/newlib/libc/stdlib/dtoa.c:348: relocation truncated to fit: R_MIPS_LITERAL no symbol /opt/hermes/embedded/build/build-mips64orion-tools/mips64orion-rtems/newlib/libc/stdlib/../../../../../src/newlib/libc/stdlib/dtoa.c:348: relocation truncated to fit: R_MIPS_LITERAL no symbol /opt/hermes/embedded/build/build-mips64orion-tools/mips64orion-rtems/newlib/libc/stdlib/../../../../../src/newlib/libc/stdlib/dtoa.c:348: relocation truncated to fit: R_MIPS_LITERAL no symbol collect2: ld returned 1 exit status # mips64orion-rtems-gcc -v Reading specs from /opt/rtems/lib/gcc-lib/mips64orion-rtems/2.95.1/specs gcc version 2.95.1 19990816 (release) # mips64orion-rtems-ld -v GNU ld version 2.9.5 (with BFD 2.9.5)
* Patch rtems-rc-19990709-6-diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1999-08-061-2/+3
* New file from Ralf Corsepius <corsepiu@faw.uni-ulm.de> missed being addedJoel Sherrill1999-08-021-0/+26
in a previous patch.
