path: root/aclocal/check-custom-bsp.m4 (follow)
* 2004-10-22 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-10-221-1/+1
| | | | * alocal/check-custom-bsp.m4: Reflect new location of bspkit*cfg.
* 2004-10-18 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-10-181-7/+20
| | | | | | * aclocal/check-bsps.m4: Add bspkit support. Don't check for presence of *.cfg. * aclocal/check-custom-bsp.m4: Add bspkit support.
* 2003-11-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-11-261-1/+2
| | | | | | | | | | | | | | | * aclocal/bsp-alias.m4, aclocal/canonical-target-name.m4, aclocal/check-bsps.m4, aclocal/check-custom-bsp.m4, aclocal/enable-bare.m4, aclocal/enable-cxx.m4, aclocal/enable-inlines.m4, aclocal/enable-itron.m4, aclocal/enable-multiprocessing.m4, aclocal/enable-networking.m4, aclocal/enable-posix.m4, aclocal/enable-rdbg.m4, aclocal/enable-rtems-debug.m4, aclocal/enable-rtemsbsp.m4, aclocal/enable-tests.m4, aclocal/multilib.m4, aclocal/path-ksh.m4, aclocal/project-root.m4, aclocal/rtems-top.m4, aclocal/tool-paths.m4, acinclude.m4: Fix underquoting to silence automake-1.8.
* 2002-11-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-11-291-0/+10
* aclocal/prog-ccas.m4: New. * aclocal/check-custom-bsp.m4: New, split out from check-bsps.m4. * aclocal/check-bsps.m4: Split out RTEMS_CHECK_CUSTOM_BSP. * aclocal/canonicalize-tools.m4: Remove RTEMS_GCC_PRINT.
