* | Cosmetics. | Ralf Corsepius | 2009-10-16 | 1 | -2/+2 |
* | 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-15 | 1 | -1/+2 |
| | | | | | * aclocal/check-custom-bsp.m4: Let _RTEMS_CHECK_CUSTOM_BSP look for *.cfg into c/src/lib/libbsp/<cpu>/<bsp_family>/make/custom. | ||||
* | 2004-10-22 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-10-22 | 1 | -1/+1 |
| | | | | * alocal/check-custom-bsp.m4: Reflect new location of bspkit*cfg. | ||||
* | 2004-10-18 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-10-18 | 1 | -7/+20 |
| | | | | | | * aclocal/check-bsps.m4: Add bspkit support. Don't check for presence of *.cfg. * aclocal/check-custom-bsp.m4: Add bspkit support. | ||||
* | 2003-11-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-11-26 | 1 | -1/+2 |
| | | | | | | | | | | | | | | | * aclocal/bsp-alias.m4, aclocal/canonical-target-name.m4, aclocal/check-bsps.m4, aclocal/check-custom-bsp.m4, aclocal/enable-bare.m4, aclocal/enable-cxx.m4, aclocal/enable-inlines.m4, aclocal/enable-itron.m4, aclocal/enable-multiprocessing.m4, aclocal/enable-networking.m4, aclocal/enable-posix.m4, aclocal/enable-rdbg.m4, aclocal/enable-rtems-debug.m4, aclocal/enable-rtemsbsp.m4, aclocal/enable-tests.m4, aclocal/multilib.m4, aclocal/path-ksh.m4, aclocal/project-root.m4, aclocal/rtems-top.m4, aclocal/tool-paths.m4, acinclude.m4: Fix underquoting to silence automake-1.8. | ||||
* | 2002-11-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-11-29 | 1 | -0/+10 |
* aclocal/prog-ccas.m4: New. * aclocal/check-custom-bsp.m4: New, split out from check-bsps.m4. * aclocal/check-bsps.m4: Split out RTEMS_CHECK_CUSTOM_BSP. * aclocal/canonicalize-tools.m4: Remove RTEMS_GCC_PRINT. |
