* aclocal/check-bsps.m4: Add csb337 bsp family.
* Makefile.am, configure.ac, preinstall.am: Added BSP variants.
* console/console-config.c, clock/clock-config.c, ssp/ssp.c: Fixed
register settings. Cleanup.
* include/bsp.h: Added network defines and functions.
* include/lpc24xx.h: Added AHB and EMC defines. Fixed Ethernet status
sizes.
* include/system-clocks.h, misc/system-clocks.c: Added micro seconds
delay function that uses Timer 1. Changed PLL setup.
* network/network.c, startup/bspreset.c, startup/linkcmds.lpc2478,
startup/linkcmds.lpc2478_ncs, startup/linkcmds.lpc2478_ncs_ram: New
files.
* startup/bspstart.c: Added EMC initialization. Changes for ROM boot.
* aclocal/check-bsps.m4: remove stray ")" from rtl22xx_t alias.
* aclocal/bsp-alias.m4, aclocal/check-bsps.m4: Add h8sxsim as variant
of h8sim.
* README.configure, aclocal/bsp-alias.m4, aclocal/check-bsps.m4: Add
M32C port and m32csim BSP.
PR 1324/bsps
* aclocal/check-bsps.m4: Revert Joel's icecube patch.
Recognize the the GDB SuperH simulator is just an architectural
simulator and does not include devices. Rename existing simulator BSP
configurations to simsh1 and simsh2 and add simsh4.
PR 1324/bsps
* aclocal/check-bsps.m4: Add missing icecube.
updated haleakala BSP
added MPC55xx BSP
adapted PPC exception code
many different versions of new exception handling code to shared sources.
* README.configure, aclocal/check-bsps.m4: Remove references to
mbx860_1b since it is just an alternate name for the mbx860_001b.
Per Jiri Gaisler remove unused erc32nfp and leon1 BSP variants.
* aclocal/bsp-alias.m4: Remove brs5l. Remove leon2.
Alias leon1 to leon2. Add sis.
* aclocal/check_bsps.m4: Remove brs5l.
Remove leon. Add leon2. Add sis to erc32 family.
PR 851/bsps
* aclocal/bsp-alias.m4, aclocal/check-bsps.m4: Add gen5200 BSP
family.
* aclocal/check-bsps.m4: Add the plethora of mbx* BSP.
* aclocal/check-bsps.m4: Use ls instead of globs to pickup
bsp_specs.
* aclocal/check-bsps.m4: Add MVME2100 BSP as alias of
motorola_shared.
* aclocal/check-bsps.m4: Add bspkit support. Don't check for
presence of *.cfg.
* aclocal/check-custom-bsp.m4: Add bspkit support.
* configure.ac: Require automake >= 1.8.2.
* aclocal/check-bsps.m4: Also test for make/custom/*.cfg.
* aclocal/bsp-alias.m4, aclocal/canonical-target-name.m4,
aclocal/check-bsps.m4, aclocal/check-custom-bsp.m4,
aclocal/enable-bare.m4, aclocal/enable-cxx.m4,
aclocal/enable-inlines.m4, aclocal/enable-itron.m4,
aclocal/enable-multiprocessing.m4, aclocal/enable-networking.m4,
aclocal/enable-posix.m4, aclocal/enable-rdbg.m4,
aclocal/enable-rtems-debug.m4, aclocal/enable-rtemsbsp.m4,
aclocal/enable-tests.m4, aclocal/multilib.m4,
aclocal/path-ksh.m4, aclocal/project-root.m4,
aclocal/rtems-top.m4, aclocal/tool-paths.m4,
acinclude.m4:
Fix underquoting to silence automake-1.8.
* aclocal/prog-ccas.m4: New.
* aclocal/check-custom-bsp.m4: New, split out from check-bsps.m4.
* aclocal/check-bsps.m4: Split out RTEMS_CHECK_CUSTOM_BSP.
* aclocal/canonicalize-tools.m4: Remove RTEMS_GCC_PRINT.
* aclocal/bsp-alias.m4, aclocal/check-bsps.m4: Added support for
Motorola MTX603e.
* aclocal/bsp-alias.m4: Remove score603e_g1.
* aclocal/check-bsps.m4: Remove score603e_g1.
* aclocal/prog-cc.m4: Apply m4_if.
* aclocal/check-bsps.m4: Reworked.
* aclocal/bsp-alias.m4: Add score603e_g1, apply m4sugar.
* aclocal/config-subdirs.m4: Let CC default to $host_alias-gcc in
TARGET_CONFIG_SUBDIRS.
* aclocal/enable-bsp.m4: fix quoting.
* aclocal/check-bsps.m4, aclocal/bsp-alias.m4: Add pc386dx.
* configre.in: Fix AM_INIT_AUTOMAKE.
* aclocal/bsp-arg-enable.m4: Extend comments.
* aclocal/check-bsps.m4: Remove extraneous comments, add test -d in
the default clause.
* aclocal/bsp-alias.m4, aclocal/check-bsps.m4: Add simsh7032 and
simsh7045.
Modified to reflect addition of LEON BSPs as well as the
no-FP ERC32 variant.
* aclocal/check-bsps.m4: Fix c4* and sim68000 entries
* make/custom/pck6.cfg: New file
* make/custom/pc486.cfg: Use -m486
* make/custom/pc586.cfg: Use -mpentium
* make/custom/pc686.cfg: Use -mmpentiumpro
* make/custom/i386ex.cfg: Use -msoft-float
* aclocal/check-bsps.h:
- Add pck6-BSP
- Exclude ChangeLog from being picked up as BSP
* aclocal/bsp-alias.m4: Add pck6-BSP
alias simcpu32 that supports the CPU32 simulator in BSVC. At this
point, it is still under development.
significant things:
and PowerPC
same code base.
which is described below:
break something.
SUBDIRS in a Makefile.am)
* An update to gensh2.cfg.
cd <srcdir>
Removed all go32 configuration tests.
This patch also comments out some special treatment for Cygwin from
*.m4 macros. According to reports from David Fiddes. these should
not be necessary anymore.
mkdir c/src/librpc
mkdir c/src/librpc/src
mkdir c/src/librpc/include
rm -rf c/src/lib/librpc
rm -rf c/src/lib/include/rpc
in the required order .
# make[5]: Entering directory
# mips64orion-rtems-gcc -v
# mips64orion-rtems-ld -v
* I've gone a little ??) further than I had announced before.
