<corsepiu@faw.uni-ulm.de>:
This patch removes MKDIR from RTEMS source tree and fixes another small
bug in the definition of INSTALL_VARIANT (cf. to the patch itself for
details, it should be self-explanatory)
After applying the patch please do:
cvs rm aclocal/mkdir.m4
FYI: I am not talking about using "make -C <dir>", which probably
is much faster on M$ hosts than RTEMS's implementation, but about
removing --enable-gmake-print support and to apply a variant of
automake's subdirectory.
Automake's subdirectory rule seems to be a little bit faster, but I
wouldn't bet on this.
Attached to this mail is my proposal.
After applying the patch, please run
cvs rm aclocal/enable-gmake-print.m4
--enable-tests problem a better way.
preparations for automake.
* aclocal/rtems-top.m4:
configure scripts did not match on the default value of --enable-tests.
releasing a snapshot:
1. Cleanup to aclocal/
cvs rm -f aclocal/cygwin.m4
cvs rm -f aclocal/exeext.m4
2. rtems-rc-19990328-0.diff
Some (minor) bug-fixes:
3. rtems-rc-19990328-1.diff
-ac -am -ci.
(reduces size of configure.in
With my most recent automake patch (automake II) we could even simplify more
files below make/, because the host-compiler related parts of those files
aren't used anymore :-.
Whatsoever, the patch below should fix this problem.
Note: This is a mere bug fix, it doesn't move any of the variables involved
to target.cfg nor does it try to eliminate any variable.
description follows:
Description:
config.h.ins)
acpolish
configure scripts
Remarks:
[$(prefix)].
issues.
egcs/contrib/egcs_update).
ATTENTION:
* "make RTEMS_BSP=<bsp> dist"
OK, I 've made up my mind to cut a big chunk of my automake-patches (:-).
Below you can find a drop-in replacement of the aclocal directory. It
contains a lot of new macro files, most of them are directly cut from rtems
top-level configure script, some are new some are identical to former
versions. The motivation behind these files is to reuse parts from rtems
current top-level configure.in script in up-coming subdirectory configure.in
scripts.
I'd like to ask you to untar the archive ontop of the source tree and to
add/commit these files to CVS. Adding these files should not have any
influence on RTEMS momentary configuration (except of you are required to
run aclocal -I aclocal && autoconf afterwards), because most of them
currently are not used at all.
BTW: Please upgrade to autoconf-2.13 and automake-2.4, if you havn't done
this already (egcs/CVS require them, too). My upcoming automake files
require automake-2.4 which requires autoconf-2.13 or later.
it work.
with libchip.
problem report from Erik Ivanenko <erik.ivanenko@utoronto.ca>.
test were suggested by Ian Taylor <ian@airs.com> and Joel did the
hard part of putting it in aclocal and editting all the offending
Makefiles and source code which could use this feature.
It fixes netboot build problem, KA9Q configuration
for pc386, some compiler wardning, it also removed some stuff
ifdef'ed with '#if 0'.
BSDINSTALL=@INSTALL@
in autoconf.
fixed.
<corsepiu@faw.uni-ulm.de> which attempts to detect when the UNIX port
is being configured on a system without System V IPC support. This
is an optional component on both FreeBSD and Linux systems. Most
Linux 2.x kernels ship with it enabled but it is still a real risk.
This test may have undesirable side-effects on some hosts. We will
address those conflicts as they arise.
one of the aclocal macros.
all the targets:
breaking CXX support.
handling.
after minor changes.)
insecure about.
external packages.
may be broken).
disturb now.
--enable-* flags).
--enable-gcc28 are given.
mvme162.cfg-bug.
that gcc automatically generates references to.
successfully work on powerpc-rtems and hppa1.1-rtems.
support the -pipe option on the compiler.
Yep, I have a bunch of bug-fixes and additions pending (Yet another monster
patch, ... I can hear you scream :-).
1) configure.in : one AC_CONFIG_HEADER(...) line too much.
2) configure.in: gcc28 support is enabled by default, i.e. if no
--enable-gcc28 option is passed on the command line. I am not sure if this
is intentional.
IMO, AC_ARG_ENABLE for --enable-gcc28 should look like:
AC_ARG_ENABLE(gcc28, \
[ --enable-gcc28 enable use of gcc 2.8.x features], \
[case "${enableval}" in
yes) RTEMS_USE_GCC272=no ;;
no) RTEMS_USE_GCC272=yes ;;
*) AC_MSG_ERROR(bad value ${enableval} for gcc-28 option) ;;
esac],[RTEMS_USE_GCC272=yes])
3) At the end of c/src/exec/score/cpu/m68k/m68k.h
> #ifdef __cplusplus
> #endif
> #endif /* !ASM */
in my opinion these two statements should be swapped:
> #endif /* !ASM */
> #ifdef __cplusplus
> #endif
I didn't try to compile for m68k, but does't this give an error? Is it
compensated somewhere else - or didn't I look carefully enough?
5) configure.in: --enable-cpp should probably be renamed to --enable-cxx, as
gnu-programs use "cxx" to specify C++ specific configure options, while cpp
is used for the preprocessor (e.g egcs uses --with-cxx-includedir, autoconf
internally uses $CXX),
6) The macro files from aclocal/*.m4 contain the buggy sed-rules formerly
contained in aclocal..m4, i.e. the sed/sort-bug fix to aclocal.m4 didn't
make it to aclocal/*.m4. I think I should feel guilty for that - Obviously I
submitted the contents of an old aclocal-directory last time. - Sorry.
7) For sh-rtems, we currently need to add additional managers to
MANAGERS_REQUIRED (from inside of custom/*.cfg). Currently MANAGERS_REQUIRED
is defined in make/compilers/*.cfg. This seems to prevent overriding
MANAGERS_REQUIRED from custom/*.cfg files - Obviously the files are included
in such a way that the settings from compilers/*cfg always override settings
from custom/*.cfg files.
Furthermore, I think, defining MANAGERS_* inside gcc-<target>.cfg files is
not correct - MANAGERS are not gcc-variant-dependent, but depend
on targets/bsps and therefore should be defined in a bsp/target dependent
file, e.g. in custom/*.cfg or target.cfg.in.
I think defining default settings for MANAGERS* in custom/default.cfg could
be an appropriate location. But this requires all custom/*.cfg files to
include default.cfg, which *-posix.cfg files don't seem to do.
Therefore I would like propose to move MANAGERS* to target.cfg.in - they are
included by all custom/*.cfg files. Perhaps we/you should use this
opportunity to merge parts from custom/default.cfg into target.cfg.in. This
ensures to have the setting included once per target makefile and will open
the opportunity to have autoconf doing additional work on
bsp-configurations.
Peanuts sofar, ... but here it comes ... (:-)
8) I am preparing a major enhancement to autoconf support for
gnutools/compilers. It is not yet finished, but usable and I'll therefore
attach a preliminary version to this mail.
Motivation:
* Fix problems with --enable-gcc28, if target-cc is not gcc28 compatible
* Fix -pipe problems
* Fix problems with hard-coded paths in configuration files (esp. posix)
* Fix consistency problems with explictly given gnutools and gcc's gnutools
Currently included:
* detection and checking of host and target compiler (gcc/g++)
* checking if target gnutools are in path
* checking if <target>-gcc -specs works (autodisabling gcc28 if not)
* checking if <target>-gcc -pipe works
Todo :
* *posix.cfg files are not yet adapted => The hard-coded paths for these
systems are still in use.
* Check if the host compiler $CC is properly propagated to the Makefiles (I
doubt it, but this should not matter)
* Check if rtems' generic tools still work properly (It looks like, but who
knows)
* Integrate CXX support into default.cfg or gcc-target-default.cfg (It looks
like C++ support is only used by posix BSPs)
* Automatically handle RANLIB/MKLIB for targets
* Plenty ... (:-)
Open problems:
* Untested for non-gcc compatible host and target compilers. This should be
no problem if the tools are named follow gnutool's naming convention and are
included in $PATH while running configure.
* Intentionally using different tools than that gcc has been configured for,
e.g. use a different assembler ? This should be still possible if
XX_FOR_TARGET is hard-coded into custom/*.cfg. I don't see why anybody
should want to do this, but who knows?
I have tested this version on linux and solaris hosts, with gcc's
directories mounted at weird non-standard mount points, using egcs
(linux/sh-rtemscoff), gcc-2.7.2.2 using native tools (solaris), gcc-2.7.2.3
w/ gnutools (solaris/linux). I don't expect it to break anything, but of
cause I can't promise it. It will break most/all *-posix.cfg configuration
almost for certain, but not more as rtems' current *posix.cfg configurations
already do (hard-coded configurations).
I am not sure if this is ready to be included into the next snapshot or not.
Perhaps you might try this on your systems and if it you don't notice
serious bugs you might put it into the snapshot for public testing (I don't
like this, but I don't see another possiblity to test generality).
I enclose a patch for configure.in and some configuration files which
comprizes fixes for all items mentioned except of #3 . Don't forget to run
"aclocal -I aclocal; autoconf;" after applying the patch (:-).
enclose.
RTEMS_CHECK_FILES_IN uses a sequence of find, sort and sed to collect
all *.in files in a given subdirectory.
The current version uses : `find $1 -name $2 -print | sed 's%\.in%%' |
sort` with $1 being a subdirectory $2 set to Makefile.in.
This works as long all subdirectories start with a letter that is
lexically bigger than the letter M, but will fail otherwise.
eliminated autoconf looking for commands which are unused, and reduce the
number of Makefiles generated.
generate the list of Makefiles in the configure script.
