path: root/acinclude.m4 (follow)
* s/AC_HELP/AS_HELP/.Ralf Corsepius2008-06-011-1/+1
* AC_PREREQ(2.60)Ralf Corsepius2007-01-081-1/+1
* 2006-03-09 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2006-03-091-1/+1
| | | | * acinclude.m4: Requires autoconf-2.59.
* 2004-08-17 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-08-181-1/+1
| | | | * acinclude.m4 (_RTEMS_CONFIG_SUBDIR): Quote ac_popdir uses.
* 2004-03-31 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-03-311-1/+3
| | | | | | * aclocal/rtems-top.m4: Remove ENDIF. Remove with_target_subdir defaulting to '.'. * acinclude.m4: Add --includedir to sub_configure_args.
* 2003-11-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-11-261-3/+3
| | | | | | | | | | | | | | | * aclocal/bsp-alias.m4, aclocal/canonical-target-name.m4, aclocal/check-bsps.m4, aclocal/check-custom-bsp.m4, aclocal/enable-bare.m4, aclocal/enable-cxx.m4, aclocal/enable-inlines.m4, aclocal/enable-itron.m4, aclocal/enable-multiprocessing.m4, aclocal/enable-networking.m4, aclocal/enable-posix.m4, aclocal/enable-rdbg.m4, aclocal/enable-rtems-debug.m4, aclocal/enable-rtemsbsp.m4, aclocal/enable-tests.m4, aclocal/multilib.m4, aclocal/path-ksh.m4, aclocal/project-root.m4, aclocal/rtems-top.m4, aclocal/tool-paths.m4, acinclude.m4: Fix underquoting to silence automake-1.8.
* 2003-10-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-10-021-0/+2
| | | | | | | * aclocal/check-cpu.m4: Remove. * Makefile.am: Remove reference to aclocal/check-cpu.m4. * acinclude.m4 (RTEMS_TARGET_CONFIG_SUBDIR): Check for presence of $1 in $srcdir before adding dir to SUBDIRS.
* 2003-06-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-06-121-56/+67
| | | | | | | | | | * configure.ac: Remove "BLEEDING EDGE" warning. Put docs into RTEMS_BUILD_CONFIG_SUBDIRS. * acinclude.m4: Add AC_PREREQ(2.57). Major overhaul (PR 412). * aclocal/prog-cc.m4: Add RTEMS_GCC_ISYSTEM. * aclocal/gcc-isystem.m4: New. * Makefile.am: Add aclocal/gcc-isystem.m4.
* Merger from rtems-4-6-branch.Ralf Corsepius2003-03-251-97/+75
* 2002-11-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-11-201-1/+4
| | | | * acinclude.m4: Conditionally append --target=.
* 2002-11-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-11-191-27/+54
| | | | * acinclude.m4: Lots of changes addressing PR 312.
* 2002-11-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-11-181-34/+22
| | | | | * acinclude.m4: Use AS_IF instead of if/then/else/endif. * configure.ac: Ditto.
* 2002-11-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-11-151-1/+9
| | | | | | | * acinclude.m4: Add CXX_FOR_*, CXXFLAGS_FOR_*. Fix stupid typo (continue/configure). * aclocal/prog-cc.m4: Remove obsolete comments. Acknowledge CFLAGS.
* 2002-11-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-11-141-5/+6
| | | | | | * acinclude.m4: _RTEMS_OUTPUT_SUBDIRS: Move ac_subconfigure_vars to the end of the args passed to sub-configure-scripts. (Reported by Wulf Hofbauer <wh73@cornell.edu>)
* 2002-11-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-11-051-31/+33
| | | | * acinclude.m4: Adapations to autoconf > 2.52.
* 2002-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-10-111-28/+6
| | | | | * aclocal/quoting.m4: New (Implements RTEMS_CONFIGURE_ARGS_QUOTE). * acinclude.m4: Apply RTEMS_CONFIGURE_ARGS_QUOTE.
* 2002-07-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-221-0/+399
* aclocal/subdirs.m4: Remove. * acinclude.m4: New (Replaces aclocal/subdirs.m4).
