path: root/acinclude.m4 (follow)
* 2004-08-18 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-08-181-1/+1
| | | | | | * aclocal/ppc.m4 (RTEMS_PPC_EXCEPTIONS): Quote ac_popdir uses. * aclocal/target.m4 (_RTEMS_POP_BUILDDIR): Ditto. * acinclude.m4 (_RTEMS_CONFIG_SUBDIR): Quote ac_popdir uses.
* 2004-08-18 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-08-181-3/+3
| | | | * acinclude.m4: Fix m4-underquoting.
* 2003-06-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-06-121-56/+67
| | | | | | | | | | * configure.ac: Remove "BLEEDING EDGE" warning. Put docs into RTEMS_BUILD_CONFIG_SUBDIRS. * acinclude.m4: Add AC_PREREQ(2.57). Major overhaul (PR 412). * aclocal/prog-cc.m4: Add RTEMS_GCC_ISYSTEM. * aclocal/gcc-isystem.m4: New. * Makefile.am: Add aclocal/gcc-isystem.m4.
* 2003-03-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-03-141-10/+8
| | | | | | | * acinclude.m4: Reformat build_* handling. Preset *_alias if empty. * configure.ac: Change tools/build to build-config dirs. Conditionally build tools/build as host-config dirs.
* 2003-03-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-03-131-10/+16
| | | | | | | | | * acinclude.m4: Fix broken comments. Add hidden option --enable-experimental. * README.cdn-X: Update. * configure.ac: Build tools/build as host and build-host tools to accomodate those BSPs applying packhex in <BSP>.cfg. Build tools/cpu as build-host tools.
* 2003-03-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-03-131-91/+65
| | | | | | | | * tools/Makefile.am: Remove. * configure.ac: Remove tools/Makefile.am * acinclude.m4: Fix build_subdir handling. * Makefile.am: Remove tools from SUBDIRS. Rename HOST|BUILD|TARGET_SUBDIRS into host|build|target_SUBDIRS.
* 2002-11-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-11-201-1/+4
| | | | * acinclude.m4: Conditionally append --target=.
* 2002-11-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-11-191-27/+54
| | | | * acinclude.m4: Lots of changes addressing PR 312.
* 2002-11-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-11-181-34/+22
| | | | | * acinclude.m4: Use AS_IF instead of if/then/else/endif. * configure.ac: Ditto.
* 2002-11-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-11-151-1/+9
| | | | | | | * acinclude.m4: Add CXX_FOR_*, CXXFLAGS_FOR_*. Fix stupid typo (continue/configure). * aclocal/prog-cc.m4: Remove obsolete comments. Acknowledge CFLAGS.
* 2002-11-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-11-141-5/+6
| | | | | | * acinclude.m4: _RTEMS_OUTPUT_SUBDIRS: Move ac_subconfigure_vars to the end of the args passed to sub-configure-scripts. (Reported by Wulf Hofbauer <wh73@cornell.edu>)
* 2002-11-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-11-051-31/+33
| | | | * acinclude.m4: Adapations to autoconf > 2.52.
* 2002-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-10-111-28/+6
| | | | | * aclocal/quoting.m4: New (Implements RTEMS_CONFIGURE_ARGS_QUOTE). * acinclude.m4: Apply RTEMS_CONFIGURE_ARGS_QUOTE.
* 2002-07-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-221-0/+399
* aclocal/subdirs.m4: Remove. * acinclude.m4: New (Replaces aclocal/subdirs.m4).
