path: root/README (follow)
* README: Fix the rtems.git lineChris Johns2020-04-271-1/+1
| | | | Updates #3231
* Updated README.Chris Johns2018-04-111-17/+50
* README:XXXJoel Sherrill2015-05-141-6/+9
* README: Update README and INSTALL to try to be GNU'ish.Gedare Bloom2013-04-231-1/+7
* README: Rewrite and reduceGedare Bloom2013-04-231-89/+11
| | | | | Delete old bit-rotting README files and rewrite the README to point readers toward authoritative sources of documentation.
* Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill2012-05-111-4/+0
* 2000-08-31 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-011-1/+1
| | | | * LICENSE.NET, README, README.configure: Spelling corrections.
* Updated to point to README.configure for build instructions.Joel Sherrill1997-04-251-0/+4
* Initial revisionJoel Sherrill1995-05-111-0/+93
