2018-04-11 | Updated README. | Chris Johns | 1 | -17/+50 | |
2015-05-21 | Top files: Update and prep for release branch | Joel Sherrill | 1 | -6/+9 | |
2015-05-14 | README:XXX | Joel Sherrill | 1 | -6/+9 | |
2013-04-23 | README: Update README and INSTALL to try to be GNU'ish. | Gedare Bloom | 1 | -1/+7 | |
2013-04-23 | README: Rewrite and reduce | Gedare Bloom | 1 | -89/+11 | |
Delete old bit-rotting README files and rewrite the README to point readers toward authoritative sources of documentation. | |||||
2012-05-11 | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 1 | -4/+0 | |
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed. | |||||
2000-09-01 | 2000-08-31 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -1/+1 | |
* LICENSE.NET, README, README.configure: Spelling corrections. | |||||
1997-04-25 | Updated to point to README.configure for build instructions. | Joel Sherrill | 1 | -0/+4 | |
