path: root/Makefile.maint (follow)
* 2011-03-04 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-03-041-1/+1
| | | | | * Makefile.maint, aclocal/rpm.m4, aclocal/rtems-top.m4, aclocal/version.m4: Rename RTEMS_API into _RTEMS_API.
* 2010-06-21 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2010-06-211-5/+6
| | | | * Makefile.maint, README.configure: Remove more ITRON references.
* 2009-02-06 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-02-061-2/+2
| | | | * Makefile.maint: rtems_api=4.10.
* 2009-02-06 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-02-061-0/+17
| | | | * Makefile.maint: Dump stuff hanging around for much too long.
* 2007-09-04 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2007-09-041-8/+9
| | | | | * Makefile.maint: touch all documentation master files so the date on the manual reflects the release date of the software.
* 2007-08-07 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2007-08-071-0/+10
| | | | | * Makefile.maint: Add touching master files for various manuals so the date on the cover page will reflect the date a tarball is cut.
* 2007-08-02 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2007-08-021-1/+0
| | | | | * Makefile.maint, configure.ac, release_support: Remove RDBG. * aclocal/enable-rdbg.m4: Removed.
* Fix stupid typoRalf Corsepius2007-02-221-1/+1
* use cvs -qRalf Corsepius2007-02-221-3/+3
* Don't redirect output of make tagRalf Corsepius2007-02-221-1/+1
* Sync with rtems-4-7-branch.Ralf Corsepius2007-02-221-6/+6
* Eliminate hard-coded PATHs.Ralf Corsepius2007-02-221-4/+6
| | | | | Add rtems_api. Sort TOOL_VERSIONS.
* Rename TEST_TAG into TAG_SUFFIX.Ralf Corsepius2007-02-221-5/+6
* Move TOOL_VERSIONS into tarball.Ralf Corsepius2007-02-221-3/+5
* Preps for testing.Ralf Corsepius2007-02-221-1/+1
* Simplify rpm -qa callRalf Corsepius2007-02-221-1/+1
* 2007-02-21 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2007-02-211-1/+18
| | | | * Makefile.maint: Added TOOL_VERSIONS stanza and fixed typo.
* Misc. hacksRalf Corsepius2007-02-211-1/+1
* Misc. hacksRalf Corsepius2007-02-211-0/+1
* Misc. hacksRalf Corsepius2007-02-211-1/+4
* 2007-02-15 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2007-02-151-4/+6
| | | | * Makefile.maint: Use VERSION as master source for version.m4's.
* 2007-01-28 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2007-01-281-9/+9
| | | | | | * Makefile.maint: Sync nomenclature with that being used in cpukit/score/include/rtems/system.h (major->minor, minor->revision).
* 2007-01-27 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2007-01-271-19/+3
| | | | | * Makefile.maint: Remove references to cpukit/score/include/rtems/system.h.
* Add CVS_RUN.Ralf Corsepius2007-01-271-2/+4
* Misc. updates.Ralf Corsepius2007-01-261-3/+13
* New.Ralf Corsepius2007-01-261-0/+111
