2011-03-14 | 2011-03-14 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 1 | -2/+1 | |
* Makefile.maint: Remove started_ada. | |||||
2011-03-04 | 2011-03-04 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -1/+1 | |
* Makefile.maint, aclocal/rpm.m4, aclocal/rtems-top.m4, aclocal/version.m4: Rename RTEMS_API into _RTEMS_API. | |||||
2010-06-21 | 2010-06-21 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 1 | -5/+6 | |
* Makefile.maint, README.configure: Remove more ITRON references. | |||||
2009-02-06 | 2009-02-06 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -2/+2 | |
* Makefile.maint: rtems_api=4.10. | |||||
2009-02-06 | 2009-02-06 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+17 | |
* Makefile.maint: Dump stuff hanging around for much too long. | |||||
2007-09-04 | 2007-09-04 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 1 | -8/+9 | |
* Makefile.maint: touch all documentation master files so the date on the manual reflects the release date of the software. | |||||
2007-08-07 | 2007-08-07 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 1 | -0/+10 | |
* Makefile.maint: Add touching master files for various manuals so the date on the cover page will reflect the date a tarball is cut. | |||||
2007-08-02 | 2007-08-02 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 1 | -1/+0 | |
* Makefile.maint, configure.ac, release_support: Remove RDBG. * aclocal/enable-rdbg.m4: Removed. | |||||
2007-02-22 | Fix stupid typo | Ralf Corsepius | 1 | -1/+1 | |
2007-02-22 | use cvs -q | Ralf Corsepius | 1 | -3/+3 | |
2007-02-22 | Don't redirect output of make tag | Ralf Corsepius | 1 | -1/+1 | |
2007-02-22 | Sync with rtems-4-7-branch. | Ralf Corsepius | 1 | -6/+6 | |
2007-02-22 | Eliminate hard-coded PATHs. | Ralf Corsepius | 1 | -4/+6 | |
Add rtems_api. Sort TOOL_VERSIONS. | |||||
2007-02-22 | Rename TEST_TAG into TAG_SUFFIX. | Ralf Corsepius | 1 | -5/+6 | |
2007-02-22 | Move TOOL_VERSIONS into tarball. | Ralf Corsepius | 1 | -3/+5 | |
2007-02-22 | Preps for testing. | Ralf Corsepius | 1 | -1/+1 | |
2007-02-22 | Simplify rpm -qa call | Ralf Corsepius | 1 | -1/+1 | |
2007-02-21 | 2007-02-21 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -1/+18 | |
* Makefile.maint: Added TOOL_VERSIONS stanza and fixed typo. | |||||
2007-02-21 | Misc. hacks | Ralf Corsepius | 1 | -1/+1 | |
2007-02-21 | Misc. hacks | Ralf Corsepius | 1 | -0/+1 | |
2007-02-21 | Misc. hacks | Ralf Corsepius | 1 | -1/+4 | |
2007-02-15 | 2007-02-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -4/+6 | |
* Makefile.maint: Use VERSION as master source for version.m4's. | |||||
2007-01-28 | 2007-01-28 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -9/+9 | |
* Makefile.maint: Sync nomenclature with that being used in cpukit/score/include/rtems/system.h (major->minor, minor->revision). | |||||
2007-01-27 | 2007-01-27 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -19/+3 | |
* Makefile.maint: Remove references to cpukit/score/include/rtems/system.h. | |||||
2007-01-27 | Add CVS_RUN. | Ralf Corsepius | 1 | -2/+4 | |
2007-01-26 | Misc. updates. | Ralf Corsepius | 1 | -3/+13 | |
2007-01-26 | New. | Ralf Corsepius | 1 | -0/+111 | |
