* | Fix stupid typo | Ralf Corsepius | 2007-02-22 | 1 | -1/+1 |
* | use cvs -q | Ralf Corsepius | 2007-02-22 | 1 | -3/+3 |
* | Don't redirect output of make tag | Ralf Corsepius | 2007-02-22 | 1 | -1/+1 |
* | Sync with rtems-4-7-branch. | Ralf Corsepius | 2007-02-22 | 1 | -6/+6 |
* | Eliminate hard-coded PATHs. | Ralf Corsepius | 2007-02-22 | 1 | -4/+6 |
| | | | | | Add rtems_api. Sort TOOL_VERSIONS. | ||||
* | Rename TEST_TAG into TAG_SUFFIX. | Ralf Corsepius | 2007-02-22 | 1 | -5/+6 |
* | Move TOOL_VERSIONS into tarball. | Ralf Corsepius | 2007-02-22 | 1 | -3/+5 |
* | Preps for testing. | Ralf Corsepius | 2007-02-22 | 1 | -1/+1 |
* | Simplify rpm -qa call | Ralf Corsepius | 2007-02-22 | 1 | -1/+1 |
* | 2007-02-21 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2007-02-21 | 1 | -1/+18 |
| | | | | * Makefile.maint: Added TOOL_VERSIONS stanza and fixed typo. | ||||
* | Misc. hacks | Ralf Corsepius | 2007-02-21 | 1 | -1/+1 |
* | Misc. hacks | Ralf Corsepius | 2007-02-21 | 1 | -0/+1 |
* | Misc. hacks | Ralf Corsepius | 2007-02-21 | 1 | -1/+4 |
* | 2007-02-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-02-15 | 1 | -4/+6 |
| | | | | * Makefile.maint: Use VERSION as master source for version.m4's. | ||||
* | 2007-01-28 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-01-28 | 1 | -9/+9 |
| | | | | | | * Makefile.maint: Sync nomenclature with that being used in cpukit/score/include/rtems/system.h (major->minor, minor->revision). | ||||
* | 2007-01-27 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-01-27 | 1 | -19/+3 |
| | | | | | * Makefile.maint: Remove references to cpukit/score/include/rtems/system.h. | ||||
* | Add CVS_RUN. | Ralf Corsepius | 2007-01-27 | 1 | -2/+4 |
* | Misc. updates. | Ralf Corsepius | 2007-01-26 | 1 | -3/+13 |
* | New. | Ralf Corsepius | 2007-01-26 | 1 | -0/+111 |
