path: root/Makefile.in (follow)
* New autoconf feature from Ralf Corsepius:Joel Sherrill1998-02-041-0/+22
| | | | | | | | | | | | | | | | | | | | It adds make rules for reconfiguring build-trees ("make Makefile") and adds dependency rules for configure and friends (i.e. calls autoconf). Most of this code has been "borrowed" from automake and was adapted to rtems. Addionally, I added automatic generation of the "aclocal.m4"-file by "aclocal" (from the automake package). Therefore I splitted aclocal.m4 into several separate files (attached to this mail), each containing one of rtems customized autoconf/m4-macros and have put them into a new subdirectory "aclocal". Normal users won't be influenced and won't even need this, unless they try to modify configure.in. The main advantage of this is: these aclocal/m4-macros become reusable and easier to administer. As a disadvantage, rtems becomes dependent of having aclocal/automake installed. To keep building rtems functional if autoconf or aclocal isn't installed, the related Makefile commands are prefixed by "-" -- only an error message should be issued by "make".
* Big patch form Ralf Corsepius described in this email:Joel Sherrill1998-01-301-7/+1
* Removed some stanzas per Ralf Corsepius:Joel Sherrill1998-01-271-18/+2
| | | | | | | > 4) The toplevel Makefile.in contains rules named make_subdir and > clean_modules, which probably can be deleted, IMO. > At least make_subdir doesn't give any sense anymore. (I had removed it > im my original patch).
* Solaris port updates from Chris JohnsJoel Sherrill1998-01-231-0/+2
* Ralf Corsepius reported a number of missing CVS Id's:Joel Sherrill1998-01-161-0/+2
| | | | | | | | | | > RTEMS is under CVS control and has been since rtems 3.1.16 which was > around May 1995. So I just to add the $Id$. If you notice other files > with missing $Id$'s let me know. I try to keep w\up with it. Now that you have asked -- I'll attach a list of files lacking an RCS-Id to this mail. This list has been generated by a little sh-script I'll also enclose.
* Ralf Corsepius <corsepiu@faw.uni-ulm.de> suggested removing theseJoel Sherrill1998-01-151-2/+0
| | | | | lines so setting RTEMS_BSP in an environment variable works even from the top level directory.
* Switched command line override variable RTEMSBSP to RTEMS_BSPJoel Sherrill1997-12-161-3/+3
| | | | | and internally generated list of BSPs to RTEMS_BSP_LIST to make BSP override from the top level directory consistent.
* Modified a lot of files to take a first cut at supporting building fromJoel Sherrill1997-12-101-52/+8
* Serious cleanup to reduce the number of explicitly listed Makefiles,Joel Sherrill1997-11-301-8/+4
| | | | | eliminated autoconf looking for commands which are unused, and reduce the number of Makefiles generated.
* Changes from Ralf Corsepius (corsepiu@faw.uni-ulm.de) to automaticallyJoel Sherrill1997-11-291-2/+4
| | | | generate the list of Makefiles in the configure script.
* Renamed mlink to make_subdir.Joel Sherrill1997-10-081-4/+3
| | | | Removed a junk line.
* Reworked building of make subdirectory and contents in the objectJoel Sherrill1997-10-081-1/+11
| | | | tree.
* Removed duplicate listing of install in MTARGETS.Joel Sherrill1997-09-211-2/+2
| | | | Add monitor test.
* Added support for TARGET_VARIANTS.Joel Sherrill1997-08-261-2/+3
* Merged very large and much appreciated patch from Chris JohnsJoel Sherrill1997-07-311-0/+4
| | | | | <cjohns@plessey.com.au>. This patch includes the ods68302 bsp, the RTEMS++ class library, and the rtems++ test.
* added ka9q stackJoel Sherrill1997-05-271-0/+2
* KA9Q stack removed prior to testing for 4.0.0 public release.Joel Sherrill1997-05-231-2/+0
* Updated to point to README.configure for build instructions.Joel Sherrill1997-04-251-1/+1
* Modifications to add --enable-libcdir and --enable-gcc28. TheseJoel Sherrill1997-04-181-0/+4
| | | | | trip options which allow the RTEMS makefile structure to support both gcc 2.7.2.2 and gcc 2.8 whenever that is released.
* blank lines deletedJoel Sherrill1997-04-091-2/+0
* Added ka9q tcpip stack and network driver for the gen68360. This effortJoel Sherrill1997-04-091-0/+2
| | | | | | | | | | | | | was done based on the 3.6.0 release and had to be autoconf'ed locally. It is turned on is the bsp enables it and it is not explicitly disabled via the configure option --disable-tcpip. As many warnings as possible were removed locally after the code was merged. Only the gen68360 and mvme136 bsps were compiled this way. The ka9q port and network driver were submitted by Eric Norum (eric@skatter.USask.Ca). The network demo programs are not included in the tree at this point.
* This set of changes is the build of what was required to convert toJoel Sherrill1997-04-011-0/+99
