> 4) The toplevel Makefile.in contains rules named make_subdir and
> clean_modules, which probably can be deleted, IMO.
> At least make_subdir doesn't give any sense anymore. (I had removed it
> im my original patch).
enclose.
lines so setting RTEMS_BSP in an environment variable works even
from the top level directory.
and internally generated list of BSPs to RTEMS_BSP_LIST to make
BSP override from the top level directory consistent.
eliminated autoconf looking for commands which are unused, and reduce the
number of Makefiles generated.
generate the list of Makefiles in the configure script.
Removed a junk line.
tree.
Add monitor test.
trip options which allow the RTEMS makefile structure to support
both gcc 2.7.2.2 and gcc 2.8 whenever that is released.
was done based on the 3.6.0 release and had to be autoconf'ed locally.
It is turned on is the bsp enables it and it is not explicitly disabled
via the configure option --disable-tcpip. As many warnings as possible
were removed locally after the code was merged. Only the gen68360
and mvme136 bsps were compiled this way.
The ka9q port and network driver were submitted by Eric Norum
(eric@skatter.USask.Ca).
The network demo programs are not included in the tree at this point.
be resolved.
