* Makefile.am: Reflect having removed aclocal/sysv-ipc.m4.
* automake/multilib.am: Remove.
* Makefile.am: Reflect change above.
* tools/Makefile.am: Remove AUTOMAKE_OPTIONS.
* configure.ac: Add --enable-docs support. Add
RTEMS_HOST_CONFIG_SUBDIRS(doc). Remove doc/Makefile.
* Makefile.am: Add HOST_SUBDIRS to SUBDIRS. Remove doc from
hard-coded SUBDIRS.
* README.configure: Added a bit of information on this new option.
* aclocal/bsp-configure.m4: New file.
* Makefile.am: Add aclocal/bsp-configure.m4.
* Makefile.am: Add automake/force-preinstall.am,
aclocal/ppc.am, remove ACLOCAL_M4.
* aclocal/rtems-cpu-subdirs.m4: Add PREFIX arg to RTEMS_CPU_SUBDIRS,
add 2nd arg to _RTEMS_CPU_SUBDIR.
* aclocal/target.m4: Replace ac_configure_args with
rtems_configure_args, add rtems_configure_args to INIT-CMDS.
* automake/lib.am: Comment out LD.
* Makefile.am: Use ACLOCAL_FILES = to make automake-1.5 happy; Add
automake/leaf.am to AUTOMAKE_FILES.
* configure.in: Reworked for Canadian Cross support.
* config.guess, config.sub: Update from subversions.gnu.org.
* README.cdn-X: New file.
* tools/Makefile.am: Remove build, tools from SUBDIRS.
* aclocal/*: Replace with contents of macros/*.m4
* macros/: Remove.
* aclocal/ar-s.m4 aclocal/tool-prefix.m4: Remove.
* Makefile.am: Reflect changes to aclocal/ and macros/.
* configure.in: New, Cygnus/GNU style configuration.
* Makefile.am: Add macros/, reflect new configure.in,
ACLOCAL_AMFLAGS = -I $(RTEMS_TOPdir)/macros
* automake/compile.am: BSP_SPECS, remove RTEMS_CANONICALIZATION.
* automake/lib.am: Remove RTEMS_CANONICALIZATION.
* macros/tool-prefix.m4: Remove.
* macros/target.m4: Remove RTEMS_CONFIG_SUBDIRS, RTEMS_OUTPUT_SUBDIRS.
* macros/enable-rtemsbsp.m4: Add RTEMS_CONFIG_PER_BSP, add setting
RTEMS_ROOT.
* macros/i386-gas-code16.m4: Define NEW_GAS only for 16bit mode-
* macros/multilib.m4: Various minor fixes.
* macros/project-root.m4: Remove setting PROJECT_TOPdir,
PROJECT_ROOT, RTEMS_ROOT.
* macros/rtems-top.m4: Remove RTEMS_CANONICALIZATION, TARGET_SUBDIRS;
Add with_target_subdirs, PROJECT_TOPdir, PROJECT_ROOT.
* automake/multilib.am: New file.
* Makefile.am: Update AUTOMAKE_FILES to reflect the contents of
the automake/ directory.
* Makefile.am: Referenceed aclocal/enable-hwapi.m4 that was removed.
cpuopts.h.
exec/configure.in, only.
quoting bugs in autoconf).
formating changes :)
that is part of the multilib/gnu-canonicalization movement:
* New m4-macro: aclocal/multilib.am
* Suppress multiprocessing if --enable-multilib is given to
configure
For now this patch only suppresses multiprocessing if
--enable-multilib is given to configure and should not have any
other side-effects, ie. it works around a minor issue which prevents
introduction of multilibs in general.
The RTEMS_ENABLE_MULTILIB_MASTER macro is the core part to build
real multilibs, but can not be applied before other multilib related
issues with RTEMS have been solved. (e.g. sptables.h, bsp_specs,
Cygnus/Gnu canonicalization, _RTEMS_version, targopts.h, changing
the installation point/tooldir support, etc.).
<corsepiu@faw.uni-ulm.de>:
The patch below provides
before)
rtems-rc-19991123-rc-2.diff
Attention:
Addtional major bugs:
in the previous commits.
<corsepiu@faw.uni-ulm.de> which does the following:
This is the configuration cleanup patch:
Main changes:
* TARGET_ARCH removed
* target.cfg.in moved to c/make/target.cfg.in (Only configured once for
all BSPs of a target)
* BARE_XXX variables appended to bsp.cfg.in
* autogen renamed to bootstrap
* removed stray variables from make/custom/*.cfg
rm c/src/make/target.cfg.in
cp autogen bootstrap
mkdir c/make
cp make/target.cfg.in c/make/target.cfg.in
rm make/target.cfg.in
rm autogen
patch -p1 < rtems-rc-19991105-1.diff
CHANGES:
c/Makefile.am removed
still in - remove it?)
(Cygwin support)
REMARK:
inside the build-tree.
APPLYING THE PATCH
autogen
