path: root/INSTALL (follow)
* Remove CVS Id Strings (manual edits after script)Joel Sherrill2012-05-111-4/+0
| | | | | | These modifications were required by hand after running the script. In some cases, the file names did not match patterns. In others, the format of the file did not match any common patterns.
* Updated.Joel Sherrill2000-02-081-2/+1
* Fixed code for --disable-rtems-inlines so that it would completeJoel Sherrill1998-01-151-1/+1
| | | | | | | configuration successfully. Added code to detect configuring macros and POSIX API at the same time. There is no macro implementation for the POSIX API.
* Updated to point to README.configure for build instructions.Joel Sherrill1997-04-251-8/+4
* Initial revisionJoel Sherrill1995-05-111-0/+56
