path: root/Doxyfile (follow)
* TFTPFS: Add testsFrank Kühndel2022-06-211-1/+4
| | | | Update #4666.
* nfsclient: Remove from Doxygen outputSebastian Huber2020-12-021-1/+1
| | | | | | | The libnetworking is excluded from the Doxygen output. Exclude also the nfsclient source code, otherwise there are some orphaned Doxygen groups. Update #3706.
* validation: Add general purpose test suiteSebastian Huber2020-09-171-1/+1
| | | | | | | | | Add a general purpose test suite for validation tests. This is the first test suite generated from a specification item in the rtems-central repository. Update #3959.
* Doxyfile: Change version to 6.0.0Sebastian Huber2020-08-101-1/+1
| | | | Update #4020.
* Update Doxyfile to Doxygen 1.8.15Sebastian Huber2019-03-041-0/+2535
Generate Doxygen output in doc and ignore this directory in Git. Add RTEMS logo. The Doxygen documentation is now built using the source tree. Just invoke "doxygen" in the top-level source directory. The Doxyfile works also with at least Doxygen 1.8.13 and Doxygen 1.8.14. Update #3705.
