path: root/ChangeLog (follow)
* 2003-09-26 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-261-0/+3
| | | | * README.configure, aclocal/rtems-cpu-subdirs.m4: Removing HPPA port.
* 2003-08-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-221-0/+7
| | | | | | | * aclocal/enable-rtems-debug.m4: New (Missed in yesterday's patches). * aclocal/enable-tests.m4: Change to support --enable-tests=no|yes|samples, default is samples.
* 2003-08-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-211-0/+4
| | | | * Makefile.am: Correct bogus ACLOCAL_FILES.
* 2003-08-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-211-0/+21
| | | | | | | | | | | | | | | | | | | | | * aclocal/bsp-arg-enable.m4, aclocal/bsp-configure.m4, aclocal/bspopts.m4, aclocal/canonicalize-tools.m4, aclocal/check-bsp-cache.m4, aclocal/check-cxx.m4, aclocal/check-itron.m4, aclocal/check-multiprocessing.m4, aclocal/check-networking.m4, aclocal/check-newlib.m4, aclocal/check-posix.m4, aclocal/check-rdbg.m4, aclocal/check-tool.m4, aclocal/env-rtemsbsp.m4, aclocal/gcc-isystem.m4, aclocal/gcc-pipe.m4, aclocal/gcc-specs.m4, aclocal/i386-gas-code16.m4, aclocal/path-perl.m4, aclocal/ppc.m4, aclocal/prog-cc.m4, aclocal/prog-ccas.m4, aclocal/prog-cxx.m4, aclocal/prog-gnat.m4, aclocal/rtems-debug.m4, aclocal/rtems-flags.m4, aclocal/rtems-test-no-pause.m4, aclocal/target.m4: Remove (Unused). * automake/leaf.am, automake/force-preinstall.am: Remove (Unused). * Makefile.am: Reflect changes above.
* 2003-08-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-181-0/+4
| | | | * automake/local.am, automake/host.am: Remove "debug".
* 2003-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-111-0/+4
| | | | * configure.ac: Use rtems-bugs@rtems.com as bug report email address.
* 2003-07-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-07-151-0/+11
| | | | | * config-ml.in: Partial sync with gcc-3.4's config-ml.in. Add "autoconf-2.5x unquoting" hack.
* 2003-07-03 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-07-071-0/+4
| | | | * SUPPORT: Fix Mark Johannes' email address.
* 2003-07-03 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-07-031-0/+4
| | | | * VERSION: Updated to rtems-ss-20030703.
| | | | * aclocal/version.m4: Updated to rtems-ss-20030703.
* 2003-06-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-06-181-0/+1
| | | | * bootstrap: Reflect having added config.sub.
* 2003-06-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-06-181-0/+4
| | | | * config.sub: New from subversions to accomodate c4x/tic4x.
* Changed format so script will see PR number.Joel Sherrill2003-06-131-2/+2
* 2003-06-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-06-121-0/+10
| | | | | | | | | | * configure.ac: Remove "BLEEDING EDGE" warning. Put docs into RTEMS_BUILD_CONFIG_SUBDIRS. * acinclude.m4: Add AC_PREREQ(2.57). Major overhaul (PR 412). * aclocal/prog-cc.m4: Add RTEMS_GCC_ISYSTEM. * aclocal/gcc-isystem.m4: New. * Makefile.am: Add aclocal/gcc-isystem.m4.
* 2003-06-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-06-061-0/+4
| | | | * automake/local.am: Remove $(ARCH), clean-local.
* 2003-05-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-05-271-0/+9
| | | | | | | | | PR 321: * aclocal/check-bsp-cache.m4: Remove support for profile-variant. * aclocal/env-rtemsbsp.m4 * automake/compile.am * automake/host.am * automake/local.am
* 2003-05-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-05-161-0/+6
| | | | | | * aclocal/check-cxx.m4: Remove LIBSUFFIX_VA. * automake/compile.am: Remove LIBSUFFIX_VA. Merger from rtems-4-6-branch.
* 2003-04-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-04-171-0/+4
| | | | * VERSION: Updated to rtems-ss-20030417.
| | | | * aclocal/version.m4: Updated to rtems-ss-20030417.
* 2003-04-11 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-04-111-0/+4
| | | | * VERSION: Updated to rtems-ss-20030411.
| | | | * aclocal/version.m4: Updated to rtems-ss-20030411.
| | | | * VERSION: Updated to rtems-ss-20020411.
| | | | * aclocal/version.m4: Updated to rtems-ss-20020411.
* Merger from rtems-4-6-branch.Ralf Corsepius2003-03-251-0/+55
* 2003-02-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-02-151-0/+5
| | | | | * Makefile.am: Remove references to obsoleted files aclocal/enable-gcc28.m4, aclocal/enable-libcdir.m4.
* 2003-02-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-02-151-6/+0
| | | | * ChangeLog: Take out bogus ppc changelog entry.
* 2003-02-14 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-02-141-0/+5
| | | | | * README.configure, aclocal/rtems-cpu-subdirs.m4: Remove a29k references.
* 2003-02-14 Till Straumann <strauman@slac.stanford.edu>Joel Sherrill2003-02-141-0/+6
| | | | | | PR 347/rtems * rtems/powerpc/registers.h (PPC_Set_decrementer): Correct inline assembly so it correctly generates on newer gcc's.
* Fix ChangeLog.Ralf Corsepius2003-02-141-8/+0
* Merger from rtems-4-6-branch.Ralf Corsepius2003-02-141-0/+12
* 2003-02-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-02-111-0/+6
| | | | | * bootstrap: Remove attempts to detect autoconf and automake using "which" (PR 325).
* 2003-02-06 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-02-071-0/+4
| | | | | * README.configure: Updated to reflect new BSPs and deprecated targets.
* 2003-01-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-01-281-0/+4
| | | | * VERSION: Updated to rtems-ss-20030128.
| | | | * aclocal/version.m4: Updated to rtems-ss-20030128.
* 2003-01-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-01-211-0/+5
| | | | | * automake/compile.am: Remove CLEAN_DEPEND (Unused). Remove CLOBBER_DEPEND (Unused).
* 2003-01-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-01-201-0/+4
| | | | * automake/local.am: Remove distclean-local.
* 2001-01-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-01-161-0/+5
| | | | | * aclocal/rtems-cpu-subdirs.m4: Print out RTEMS_CPU in error message. * aclocal/enable-cxx.m4: Use $enable_cxx instead of $enableval.
* 2002-12-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-12-191-0/+5
| | | | | * aclocal/prog-cxx.m4: Remove RTEMS_PROG_CXX. Rework RTEMS_PROG_CXX_FOR_TARGET.
* 2002-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-12-121-0/+4
| | | | * automake/compile.am: Remove creating $(ARCH) in compilation rules.
| | | | * configure.ac: Require autoconf >= 2.57 and automake-1.7.2.
* 2002-12-10 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-12-101-0/+4
| | | | * aclocal/prog-cxx.m4: Swap RTEMS_CHECK_TOOL/AC_PROG_CXX.
* 2002-12-07 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-12-091-0/+5
| | | | | * bootstrap: Require autoconf 2.54 or 2.57. Require automake-1.7.2.
* 2002-12-07 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-12-071-0/+6
| | | | | | * aclocal/bsp-configure.m4: Remove RTEMS_CHECK_BSP_CACHE. * aclocal/env-rtemsbsp.m4: Add comments to AC_ARG_VARs. Add AC_ARG_VAR(RTEMS_CPU_MODEL).
* 2002-12-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-12-061-0/+4
| | | | * automake/compile.am: Rework *FLAGS, AM_*FLAGS handling.
* 2002-12-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-12-061-0/+7
| | | | | | | * automake/compile.am: Remove hard-coded *_PROFILE_V. Add autoconf-supplied CPU_CFLAGS, CFLAGS_OPTIMIZE_V, CFLAGS_DEBUG_V, CFLAGS_PROFILE_V. Remove CPPFLAGS_GCC.
| | | | | | | * aclocal/env-rtemsbsp.m4: Add AC_ARG_VAR for CPU_CFLAGS, CFLAGS_OPTIMIZE_V, CFLAGS_DEBUG_V, CFLAGS_PROFILE_V, RTEMS_BSP_FAMILY. * aclocal/prog-cc.m4: Reworked CFLAGS handling. * aclocal/prog-cxx.m4: Reworked CXXFLAGS handling.
| | | | * aclocal/rtems-flags.m4: New.
* 2002-12-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-12-041-0/+4
| | | | * bootstrap: Allow autoconf-2.57.
* 2002-12-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-12-011-0/+4
| | | | * aclocal/prog-cc.m4: Remove GCCSED.
* 2002-12-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-12-011-0/+9
| | | | | | | | | * automake/compile.am: Remove LDFLAGS_INCOMPLETE. Remove LDFLAGS. Add CCAS, CCASCOMPILE. Remove compilation rules for *.cpp, *.cxx, *.C. Use CCASCOMPILE to compile *.S. Add -pg to RTEMS_CFLAGS_PROFILE_V.
