Add RTEMS Scheduler Simulator.
* configure.ac: Add tools/schedsim.
* SUPPORT: Update address.
* README.configure: Further cleanup.
* README.configure: Remove the most obsolete parts.
PR 1532/testing
* aclocal/project-root.m4: Add initial tests for untar capabilities.
* configure.ac: autoconf >= 2.65, automake >= 1.11.
* Makefile.maint, README.configure: Remove more ITRON references.
* aclocal/enable-itron.m4: Remove.
* configure.ac: Remove itron.
* aclocal/version.m4: Bump RTEMS_API to 4.11.
Bump _RTEMS_VERSION to 4.10.99.0.
* aclocal/bsp-alias.m4: Change quoting to work-round
http://www.freebsd.org/cgi/query-pr.cgi?pr=146378.
* aclocal/check-custom-bsp.m4: Be less verbose.
* aclocal/bsp-alias.m4: Fix quoting bug.
Remove "${srcdir}/${RTEMS_TOPdir}/make/custom/$1".
* aclocal/check-bsps.m4: Remove "blacklist".
* aclocal/bsp-alias.m4: Remove bare BSP (Abandoned).
* aclocal/bsp-alias.m4: Pickup bsps from
c/src/lib/libbsp/<cpu>/<bsp_family>/make/custom*.cfg.
* aclocal/check-bsps.m4: Pickup bsps from
* aclocal/check-custom-bsp.m4: Let _RTEMS_CHECK_CUSTOM_BSP look for
*.cfg into c/src/lib/libbsp/<cpu>/<bsp_family>/make/custom.
* aclocal/canonical-target-name.m4, aclocal/enable-posix.m4:
Remove posix/unix simulator.
* aclocal/bsp-alias.m4: Add BSP for GDB ARM simulator so we can easily
experiment with and debug different ARM architectural variations.
* aclocal/check-bsps.m4: Add csb337 bsp family.
* aclocal/enable-itron.m4: Default to not building itron.
* aclocal/bsp-alias.m4: Add csb637 as variant of csb337.
* Makefile.am, configure.ac, preinstall.am: Added BSP variants.
* console/console-config.c, clock/clock-config.c, ssp/ssp.c: Fixed
register settings. Cleanup.
* include/bsp.h: Added network defines and functions.
* include/lpc24xx.h: Added AHB and EMC defines. Fixed Ethernet status
sizes.
* include/system-clocks.h, misc/system-clocks.c: Added micro seconds
delay function that uses Timer 1. Changed PLL setup.
* network/network.c, startup/bspreset.c, startup/linkcmds.lpc2478,
startup/linkcmds.lpc2478_ncs, startup/linkcmds.lpc2478_ncs_ram: New
files.
* startup/bspstart.c: Added EMC initialization. Changes for ROM boot.
* aclocal/bsp-alias.m4: Add simsh2e.
* Makefile.maint: rtems_api=4.10.
* Makefile.maint: Dump stuff hanging around for much too long.
* aclocal/canonical-target-name.m4:
Remove comment referring to HPUX9.
* aclocal/bsp-alias.m4, aclocal/check-bsps.m4: Remove pck6 BSP.
* config-ml.in: Comment out arm/thumb exception (Add arm/thumb
multilib).
* aclocal/check-bsps.m4: remove stray ")" from rtl22xx_t alias.
* aclocal/canonical-target-name.m4: Remove tic4x.
* README.configure: Add Lattice Mico32 support.
* aclocal/bsp-alias.m4, aclocal/check-bsps.m4: Add h8sxsim as variant
of h8sim.
* README.configure: Add new M32R port. It is just a beginning but the
BSP is functional enough to initialize and shutdown RTEMS.
* README.configure, aclocal/bsp-alias.m4, aclocal/check-bsps.m4: Add
M32C port and m32csim BSP.
* VERSION: Bump version to 4.9.99.0
PR 1324/bsps
* aclocal/check-bsps.m4: Revert Joel's icecube patch.
* MAINTAINERS: Remove myself from avr.
Recognize the the GDB SuperH simulator is just an architectural
simulator and does not include devices. Rename existing simulator BSP
configurations to simsh1 and simsh2 and add simsh4.
PR 1324/bsps
* aclocal/check-bsps.m4: Add missing icecube.
* aclocal/version.m4: Bump RTEMS_API to 4.10.
Bump _RTEMS_VERSION to 4.9.99.0.
* README.configure: Updated list of BSPs.
* src/lib/libbsp/mips/jmr3904/tools/runtest: Add bf537Stamp.
* acinclude.m4 (_RTEMS_OUTPUT_SUBDIRS): Allow empty configdirs.
* aclocal/bsp-alias.m4, aclocal/check-bsps.m4: Remove doxygen
comments.
* aclocal/rtems-top.m4: Require AC_DISABLE_OPTION_CHECKING.
AC_PREREQ(2.62).
updated haleakala BSP
added MPC55xx BSP
