* | 2007-01-28 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-01-28 | 1 | -0/+6 | |
| | | | | | | * Makefile.maint: Sync nomenclature with that being used in cpukit/score/include/rtems/system.h (major->minor, minor->revision). | |||||
* | 2007-01-27 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-01-27 | 1 | -0/+2 | |
| | | | | | * Makefile.maint: Remove references to cpukit/score/include/rtems/system.h. | |||||
* | 2007-01-27 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-01-27 | 1 | -0/+4 | |
| | | | | * Makefile.maint: Add CVS_RUN. | |||||
* | 2007-01-26 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-01-26 | 1 | -0/+4 | |
| | | | | * Makefile.maint: New. | |||||
* | 2007-01-08 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-01-08 | 1 | -0/+4 | |
| | | | | * acinclude.m4: AC_PREREQ(2.60). | |||||
| | | | | * ampolish3: Use MKDIR_P instead of mkdir_p. | |||||
| | | | | * Makefile.am: Remove scripts/. | |||||
* | Remove duplicate entry. | Ralf Corsepius | 2006-12-02 | 1 | -4/+0 | |
* | 2006-12-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-12-02 | 1 | -0/+8 | |
| | | | | * configure.ac: New BUG-REPORT address. | |||||
* | 2006-11-20 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-11-20 | 1 | -0/+4 | |
| | | | | * Makefile.am: Add ampolish3. | |||||
* | 2006-11-18 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-11-18 | 1 | -0/+4 | |
| | | | | * bootstrap: Add -r (autoreconf). | |||||
| | | | | * bootstrap: Add -p (regenerate preinstall.ams). | |||||
* | 2006-11-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-11-15 | 1 | -0/+4 | |
| | | | | * ampolish3: New. | |||||
* | 2006-10-19 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-10-19 | 1 | -0/+7 | |
| | | | | | | | * configure.ac: Remove all macro implementations and use only the static inline. Static inline functions are now well supported so there is no reason for duplicate maintenance. * aclocal/enable-inlines.m4: Removed. | |||||
* | 2006-10-18 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-10-18 | 1 | -0/+5 | |
| | | | | | * aclocal/rtems-top.m4: Remove RTEMS_API. * aclocal/version.m4: Add RTEMS_API. Bump RTEMS_API to 4.8. | |||||
* | 2006-10-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-10-17 | 1 | -0/+4 | |
| | | | | * aclocal/version.m4: Bump version to 4.7.99.0. | |||||
* | changes | Ralf Corsepius | 2006-10-17 | 1 | -0/+4 | |
* | 2006-08-09 Kolja Waschk <waschk@telos.de> | Joel Sherrill | 2006-08-09 | 1 | -0/+4 | |
| | | | | * config-ml.in: New port to Altera NIOS II. | |||||
* | added ChangeLog entries for PR1117/1118/1119/1120 | Thomas Doerfler | 2006-07-14 | 1 | -0/+5 | |
* | 2006-06-23 Worth Burruss <worth@motioncontrol.org> | Joel Sherrill | 2006-06-23 | 1 | -0/+4 | |
| | | | | * README.configure: Add mcf5235. | |||||
* | 2006-04-18 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-04-19 | 1 | -0/+4 | |
| | | | | * VERSION: Updated to rtems-4.6.99.3. | |||||
| | | | | * aclocal/version.m4: Updated to rtems-4.6.99.3. | |||||
* | 2006-04-18 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-04-19 | 1 | -3/+3 | |
| | | | | * release_support: Fix typos. | |||||
* | 2006-04-18 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-04-19 | 1 | -4/+0 | |
* | 2006-04-18 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-04-18 | 1 | -0/+4 | |
* | 2006-03-09 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-03-09 | 1 | -0/+4 | |
| | | | | * acinclude.m4: Requires autoconf-2.59. | |||||
* | 2006-03-07 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-03-07 | 1 | -0/+5 | |
| | | | | | PR 694/rtems * release_support: Do not include .cvsignore files in release tarballs. | |||||
* | 2006-02-01 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-02-01 | 1 | -0/+5 | |
| | | | | | PR 882/make_build * bootstrap: Only remove bspopts.h.in instead of bspopts.h*. | |||||
* | 2006-01-12 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-12 | 1 | -0/+2 | |
| | | | | | * aclocal/bsp-alias.m4: Revert Joel's 2006-01-10 change. Alpha-sort the aliases list. | |||||
* | 2006-01-12 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-12 | 1 | -0/+5 | |
| | | | | | * automake/host.am, automake/local.am, automake/subdirs.am: Remove depend-am, depend-recursive. | |||||
* | 2006-01-10 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-01-10 | 1 | -0/+4 | |
| | | | | * aclocal/bsp-alias.m4: Add sis as alias of erc32. | |||||
* | 2006-01-09 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-09 | 1 | -0/+7 | |
| | | | | | | | * aclocal/bsp-alias.m4: Remove brs5l. Remove leon2. Alias leon1 to leon2. Add sis. * aclocal/check_bsps.m4: Remove brs5l. Remove leon. Add leon2. Add sis to erc32 family. | |||||
* | 2005-11-31 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-12-31 | 1 | -0/+6 | |
| | | | | | | PR 851/bsps * aclocal/bsp-alias.m4, aclocal/check-bsps.m4: Add gen5200 BSP family. | |||||
* | Fixed formatting | Joel Sherrill | 2005-11-07 | 1 | -2/+2 | |
* | 2005-11-03 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-03 | 1 | -0/+4 | |
| | | | | * aclocal/check-bsps.m4: Add the plethora of mbx* BSP. | |||||
* | 2005-09-02 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-09-02 | 1 | -0/+4 | |
| | | | | * VERSION: Updated to rtems-4.6.99.2. | |||||
* | 2005-09-02 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-09-02 | 1 | -8/+0 | |
| | | | | * aclocal/version.m4: Updated to rtems-4.6.99.2. | |||||
* | 2005-09-02 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-09-02 | 1 | -2/+2 | |
* | 2005-07-06 Philippe Simons | Philippe Simons | 2005-07-07 | 1 | -0/+4 | |
| | | | | * MAINTAINERS: Added me as arm/gp32 bsp maintainer. | |||||
* | 2005-04-28 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-04-28 | 1 | -0/+5 | |
| | | | | | * README.configure: Updated to account for removal of dmv177 and ppcn_60x as well as other additions and deletions. | |||||
* | 2005-02-04 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-04 | 1 | -0/+4 | |
| | | | | * aclocal/enable-itron.m4: Allow unix. | |||||
* | 2005-01-02 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-01-02 | 1 | -0/+4 | |
| | | | | * Makefile.am: Remove ACLOCAL_FILES. | |||||
* | 2004-11-16 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-11-16 | 1 | -0/+5 | |
| | | | | | * aclocal/check-bsps.m4: Use ls instead of globs to pickup bsp_specs. | |||||
* | 2004-11-12 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-11-12 | 1 | -0/+5 | |
| | | | | | * aclocal/check-bsps.m4: Add MVME2100 BSP as alias of motorola_shared. | |||||
* | 2004-11-10 Joel Sherrill <joel@oarcorp.com> | Joel Sherrill | 2004-11-10 | 1 | -0/+4 | |
| | | | | * aclocal/bsp-alias.m4: Add MVME2100 BSP as alias of motorola_shared. |
