path: root/ChangeLog (follow)
* 2011-12-13 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-12-131-0/+5
| | | | | * compile, depcomp, mdate-sh, texinfo.tex: Update from automake-1.11.1b.
* 2011-11-09 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-11-091-0/+4
| | | | * MAINTAINERS: Rewrite and update.
* 2011-11-08 Gedare Bloom <gedare@rtems.org>Gedare Bloom2011-11-081-0/+4
| | | | * MAINTAINERS: Revert adding myself as a maintainer.
* 2011-11-06 Gedare Bloom <gedare@rtems.org>Gedare Bloom2011-11-061-2/+6
| | | | * ChangeLog: Fix ChangeLog with name and email address
* 2011-11-06 gedare@rtems.orgGedare Bloom2011-11-061-0/+4
| | | | * MAINTAINERS: Fix whitespace.
* 2011-11-04 gedare@rtems.orgGedare Bloom2011-11-041-0/+4
| | | | * MAINTAINERS: Add myself as maintainer
* 2011-10-20 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-10-201-0/+4
| | | | * MAINTAINERS: Remove references to c4x, or32 (abandoned).
* 2011-10-03 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-10-031-0/+6
| | | | | | * depcomp, compile, texinfo.tex, mdate-sh: New. * bootstrap (-c): Don't remove depcomp, compile, texinfo.tex, mdate-sh.
* 2011-05-24 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-06-281-0/+5
| | | | | PR 1810/misc * ChangeLog: Fix previous damage.
* 2011-06-17 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-06-171-0/+4
| | | | * Makefile.am: Remove make/host.cfg.in.
* 2011-05-24 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-05-241-0/+8
* * tools/build/.cvsignore, tools/build/ChangeLog,Joel Sherrill2011-05-171-0/+27
| | | | | | | | | | | | | | | | | | | | | | | | | | | | tools/build/Makefile.am, tools/build/README, tools/build/binpatch.c, tools/build/cklength.c, tools/build/config.h.in, tools/build/configure.ac, tools/build/cvsignore-add.sh, tools/build/doxy-filter, tools/build/eolstrip.c, tools/build/install-if-change.in, tools/build/multigen, tools/build/packhex.c, tools/build/rtems-bin2c.c, tools/build/search-id.sh, tools/build/unhex.c, tools/cpu/.cvsignore, tools/cpu/ChangeLog, tools/cpu/Makefile.am, tools/cpu/configure.ac, tools/cpu/generic/.cvsignore, tools/cpu/generic/ChangeLog, tools/cpu/generic/Makefile.am, tools/cpu/generic/configure.ac, tools/cpu/generic/size_rtems.in, tools/cpu/nios2/.cvsignore, tools/cpu/nios2/ChangeLog, tools/cpu/nios2/Makefile.am, tools/cpu/nios2/README, tools/cpu/nios2/bridges.c, tools/cpu/nios2/bridges.h, tools/cpu/nios2/clocks.c, tools/cpu/nios2/clocks.h, tools/cpu/nios2/configure.ac, tools/cpu/nios2/devices.c, tools/cpu/nios2/devices.h, tools/cpu/nios2/linkcmds.c, tools/cpu/nios2/linkcmds.h, tools/cpu/nios2/memory.c, tools/cpu/nios2/memory.h, tools/cpu/nios2/nios2gen.c, tools/cpu/nios2/output.c, tools/cpu/nios2/output.h, tools/cpu/nios2/ptf.c, tools/cpu/nios2/ptf.h, tools/cpu/nios2/sample.ptf, tools/cpu/sh/.cvsignore, tools/cpu/sh/AUTHORS, tools/cpu/sh/COPYING, tools/cpu/sh/ChangeLog, tools/cpu/sh/Makefile.am, tools/cpu/sh/TODO, tools/cpu/sh/configure.ac, tools/cpu/sh/sci.c, tools/cpu/sh/sci.h, tools/cpu/sh/shgen.c: New files.
* 2011-05-17 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-05-171-0/+91
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * tools/build/.cvsignore, tools/build/ChangeLog, tools/build/Makefile.am, tools/build/README, tools/build/binpatch.c, tools/build/cklength.c, tools/build/configure.ac, tools/build/cvsignore-add.sh, tools/build/doxy-filter, tools/build/eolstrip.c, tools/build/install-if-change.in, tools/build/multigen, tools/build/packhex.c, tools/build/rtems-bin2c.c, tools/build/search-id.sh, tools/build/unhex.c, tools/cpu/.cvsignore, tools/cpu/ChangeLog, tools/cpu/Makefile.am, tools/cpu/configure.ac, tools/cpu/generic/.cvsignore, tools/cpu/generic/ChangeLog, tools/cpu/generic/Makefile.am, tools/cpu/generic/configure.ac, tools/cpu/generic/size_rtems.in, tools/cpu/nios2/.cvsignore, tools/cpu/nios2/ChangeLog, tools/cpu/nios2/Makefile.am, tools/cpu/nios2/README, tools/cpu/nios2/bridges.c, tools/cpu/nios2/bridges.h, tools/cpu/nios2/clocks.c, tools/cpu/nios2/clocks.h, tools/cpu/nios2/configure.ac, tools/cpu/nios2/devices.c, tools/cpu/nios2/devices.h, tools/cpu/nios2/linkcmds.c, tools/cpu/nios2/linkcmds.h, tools/cpu/nios2/memory.c, tools/cpu/nios2/memory.h, tools/cpu/nios2/nios2gen.c, tools/cpu/nios2/output.c, tools/cpu/nios2/output.h, tools/cpu/nios2/ptf.c, tools/cpu/nios2/ptf.h, tools/cpu/nios2/sample.ptf, tools/cpu/sh/.cvsignore, tools/cpu/sh/AUTHORS, tools/cpu/sh/COPYING, tools/cpu/sh/ChangeLog, tools/cpu/sh/Makefile.am, tools/cpu/sh/TODO, tools/cpu/sh/configure.ac, tools/cpu/sh/sci.c, tools/cpu/sh/sci.h, tools/cpu/sh/shgen.c, tools/schedsim/.cvsignore, tools/schedsim/ChangeLog, tools/schedsim/Makefile.am, tools/schedsim/README, tools/schedsim/configure.ac, tools/schedsim/rtems/.cvsignore, tools/schedsim/rtems/ChangeLog, tools/schedsim/rtems/Makefile.am, tools/schedsim/rtems/interr.c, tools/schedsim/rtems/rtems_init.c, tools/schedsim/rtems/rtems_sched.h, tools/schedsim/rtems/wkspace.c, tools/schedsim/rtems/sched_cpu/cpu.c, tools/schedsim/rtems/sched_cpu/cpu_asm.c, tools/schedsim/rtems/sched_cpu/rtems/asm.h, tools/schedsim/rtems/sched_cpu/rtems/stringto.h, tools/schedsim/rtems/sched_cpu/rtems/score/cpu.h, tools/schedsim/rtems/sched_cpu/rtems/score/cpu_asm.h, tools/schedsim/rtems/sched_cpu/rtems/score/cpuopts.h, tools/schedsim/rtems/sched_cpu/rtems/score/no_cpu.h, tools/schedsim/rtems/sched_cpu/rtems/score/types.h, tools/schedsim/shell/.cvsignore, tools/schedsim/shell/ChangeLog, tools/schedsim/shell/Makefile.am, tools/schedsim/shell/schedsim_priority/.cvsignore, tools/schedsim/shell/schedsim_priority/Makefile.am, tools/schedsim/shell/schedsim_priority/config.c, tools/schedsim/shell/schedsim_priority/printheir_executing.c, tools/schedsim/shell/schedsim_priority/schedsim.cc, tools/schedsim/shell/schedsim_priority/wrap_thread_dispatch.c, tools/schedsim/shell/scripts/script01, tools/schedsim/shell/scripts/script02, tools/schedsim/shell/scripts/script03, tools/schedsim/shell/scripts/script04, tools/schedsim/shell/scripts/script05, tools/schedsim/shell/scripts/script06, tools/schedsim/shell/shared/.cvsignore, tools/schedsim/shell/shared/Makefile.am, tools/schedsim/shell/shared/commands.c, tools/schedsim/shell/shared/getopt.c, tools/schedsim/shell/shared/lookup_semaphore.c, tools/schedsim/shell/shared/lookup_task.c, tools/schedsim/shell/shared/main_clocktick.c, tools/schedsim/shell/shared/main_echo.c, tools/schedsim/shell/shared/main_executing.c, tools/schedsim/shell/shared/main_heir.c, tools/schedsim/shell/shared/main_help.c, tools/schedsim/shell/shared/main_rtemsinit.c, tools/schedsim/shell/shared/main_semcreate.c, tools/schedsim/shell/shared/main_semdelete.c, tools/schedsim/shell/shared/main_semflush.c, tools/schedsim/shell/shared/main_semobtain.c, tools/schedsim/shell/shared/main_semrelease.c, tools/schedsim/shell/shared/main_taskcreate.c, tools/schedsim/shell/shared/main_taskdelete.c, tools/schedsim/shell/shared/main_taskmode.c, tools/schedsim/shell/shared/main_taskpriority.c, tools/schedsim/shell/shared/main_taskresume.c, tools/schedsim/shell/shared/main_tasksuspend.c, tools/schedsim/shell/shared/main_taskwakeafter.c, tools/schedsim/shell/shared/schedsim_shell.h, tools/schedsim/shell/shared/shell_cmdset.c, tools/schedsim/shell/shared/shell_makeargs.c, tools/schedsim/shell/shared/include/shell.h, tools/schedsim/shell/shared/include/newlib/_ansi.h, tools/schedsim/shell/shared/include/newlib/getopt.h: Removed. * configure.ac: RTEMS Scheduler Simulator is now in its own CVS module named rtems-schedsim.
* 2011-04-21 Jennifer Averett <Jennifer.Averett@OARcorp.comJennifer Averett2011-04-211-0/+6
| | | | | | PR 1777/cpukit * tools/schedsim/rtems/rtems_init.c: Consolidated access to _Thread_Dispatch_disable_level.
* 2011-03-16 Jennifer Averett <jennifer.averett@OARcorp.com>Joel Sherrill2011-03-161-0/+5
| | | | | PR 1729/cpukit * aclocal/enable-smp.m4: New file.
* 2011-03-14 Joel Sherrill <joel.sherrilL@OARcorp.com>Joel Sherrill2011-03-141-0/+4
| | | | * Makefile.maint: Remove started_ada.
* 2011-03-06 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-03-061-0/+6
| | | | | | * aclocal/rtems-top.m4: Add pkgdatadir. Override pkgdatadir to $(datadir)/rtems$_RTEMS_API. * Makefile.am: Install make/Templates to pkgdatadir.
* 2011-03-04 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-03-041-0/+5
| | | | | * Makefile.am: Merge-in make/Makefile.am. * configure.ac: Reflect change above.
| | | | | * Makefile.maint, aclocal/rpm.m4, aclocal/rtems-top.m4, aclocal/version.m4: Rename RTEMS_API into _RTEMS_API.
* Fix the date.Ralf Corsepius2011-03-031-1/+1
* 2011-02-03 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-03-031-0/+5
| | | | | * bootstrap: Add -g option. Switch default to autoreconf.
* 2011-02-02 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-02-021-0/+4
| | | | * configure.ac: Require autoconf-2.68, automake-1.11.1.
* 2011-01-26 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-01-261-0/+5
| | | | | * configure.ac: Don't build tools/schedsim by default. Add --enable-schedsim (Default: disabled).
* 2010-12-17 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2010-12-171-0/+5
| | | | | Add RTEMS Scheduler Simulator. * configure.ac: Add tools/schedsim.
* 2010-12-16 Joel Sherrill <joel.sherrilL@OARcorp.com>Joel Sherrill2010-12-161-0/+4
| | | | * SUPPORT: Update address.
* 2010-09-27 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2010-09-271-0/+4
| | | | * README.configure: Further cleanup.
* 2010-09-26 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2010-09-261-0/+4
| | | | * README.configure: Remove the most obsolete parts.
* 2010-07-27 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2010-07-271-0/+5
| | | | | PR 1532/testing * aclocal/project-root.m4: Add initial tests for untar capabilities.
* 2010-06-23 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2010-06-231-0/+4
| | | | * configure.ac: autoconf >= 2.65, automake >= 1.11.
* 2010-06-21 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2010-06-211-0/+4
| | | | * Makefile.maint, README.configure: Remove more ITRON references.
* 2010-06-17 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2010-06-171-0/+5
| | | | | * aclocal/enable-itron.m4: Remove. * configure.ac: Remove itron.
* 2010-06-07 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2010-06-071-0/+5
| | | | | * aclocal/version.m4: Bump RTEMS_API to 4.11. Bump _RTEMS_VERSION to 4.10.99.0.
* 2010-05-11 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2010-05-111-0/+5
| | | | | * aclocal/bsp-alias.m4: Change quoting to work-round http://www.freebsd.org/cgi/query-pr.cgi?pr=146378.
* 2009-10-23 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-10-231-0/+4
| | | | * aclocal/check-custom-bsp.m4: Be less verbose.
* 2009-10-21 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-10-211-0/+4
| | | | * aclocal/bsp-alias.m4: Fix quoting bug.
* 2009-10-17 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-10-171-0/+6
| | | | | | * aclocal/check-custom-bsp.m4: Remove "${srcdir}/${RTEMS_TOPdir}/make/custom/$1". * aclocal/check-bsps.m4: Remove "blacklist".
* 2009-10-16 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-10-161-0/+4
| | | | * aclocal/bsp-alias.m4: Remove bare BSP (Abandoned).
* added COBRA5475 BSPThomas Doerfler2009-10-161-0/+9
* 2009-10-16 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-10-161-0/+5
| | | | | * aclocal/bsp-alias.m4: Pickup bsps from c/src/lib/libbsp/<cpu>/<bsp_family>/make/custom*.cfg.
* 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-10-151-0/+5
| | | | | * aclocal/check-bsps.m4: Pickup bsps from c/src/lib/libbsp/<cpu>/<bsp_family>/make/custom*.cfg.
| | | | | * aclocal/check-custom-bsp.m4: Let _RTEMS_CHECK_CUSTOM_BSP look for *.cfg into c/src/lib/libbsp/<cpu>/<bsp_family>/make/custom.
* 2009-10-14 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2009-10-141-0/+5
| | | | | * aclocal/canonical-target-name.m4, aclocal/enable-posix.m4: Remove posix/unix simulator.
* 2009-10-01 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-10-011-0/+5
| | | | | * aclocal/bsp-alias.m4: Add BSP for GDB ARM simulator so we can easily experiment with and debug different ARM architectural variations.
* 2009-09-14 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2009-09-141-0/+4
| | | | * aclocal/check-bsps.m4: Add csb337 bsp family.
* 2009-07-23 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2009-07-231-0/+4
| | | | * aclocal/enable-itron.m4: Default to not building itron.
* 2009-05-28 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2009-05-281-0/+4
| | | | * aclocal/bsp-alias.m4: Add csb637 as variant of csb337.
* * README: Added NCS.Thomas Doerfler2009-02-271-0/+5
| | | | | | | | | | | | | | | * Makefile.am, configure.ac, preinstall.am: Added BSP variants. * console/console-config.c, clock/clock-config.c, ssp/ssp.c: Fixed register settings. Cleanup. * include/bsp.h: Added network defines and functions. * include/lpc24xx.h: Added AHB and EMC defines. Fixed Ethernet status sizes. * include/system-clocks.h, misc/system-clocks.c: Added micro seconds delay function that uses Timer 1. Changed PLL setup. * network/network.c, startup/bspreset.c, startup/linkcmds.lpc2478, startup/linkcmds.lpc2478_ncs, startup/linkcmds.lpc2478_ncs_ram: New files. * startup/bspstart.c: Added EMC initialization. Changes for ROM boot.
* 2009-02-19 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-02-191-0/+4
| | | | * aclocal/bsp-alias.m4: Add simsh2e.
* 2009-02-06 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-02-061-0/+1
| | | | * Makefile.maint: rtems_api=4.10.
* 2009-02-06 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-02-061-0/+4
| | | | * Makefile.maint: Dump stuff hanging around for much too long.
