path: root/ChangeLog (follow)
* 2000-11-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-271-0/+6
| | | | | | * config.guess, config.sub: Update from CVS-autoconf to pick up new features (e.g. CC_FOR_BUILD in config.guess) but is necessary anyway to use autoconf-versions > 2.13.
* 2000-11-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-151-0/+8
| | | | | | | | * aclocal/canonical-host.m4: Abandon changequotes (autoconf-2.49b). * aclocal/check-newlib.m4: Let check message refer to RTEMS newlib. * aclocal/rtems-debug.m4: Fix formating and contents of the check's help string. * aclocal/rtems-top.m4: Remove AC_ARG_WITH(target-subdir).
* 2000-11-13 Jiri Gaisler <jgais@ws.estec.esa.nl>Joel Sherrill2000-11-131-0/+6
| | | | | | * README.configure, aclocal/bsp-alias.m4, aclocal/check-bsps.m4: Modified to reflect addition of LEON BSPs as well as the no-FP ERC32 variant.
* 2000-11-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-091-0/+11
| | | | | | | | | | | * aclocal/gcc-pipe.m4: Use $GCC instead of ac_cv_prog_gcc (autoconf standard). * aclocal/gcc-specs.m4: Use $GCC instead of ac_cv_prog_gcc (autoconf standard). * aclocal/multilib.m4: Fix m4-quoting (BUG-FIX). * aclocal/check-bsp-cache.m4: Fix m4-quoting (autoconf-2.49b). * aclocal/prog-cc.m4: Use $GCC instead of ac_cv_prog_gcc (autoconf standard), replace CC_FOR_TARGET with CC (BUG-FIX).
* 2000-11-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-091-0/+17
| | | | | | | | | | | | | | | | | * aclocal/enable-itron.m4: Remove changequotes (autoconf-2.49b). * aclocal/enable-posix.m4: Remove changequotes (autoconf-2.49b), use $host instead of $target (BUG-FIX). * configure.in: Use $target and $host instead of $target_alias and $host_alias (autoconf-2.49b). * aclocal/check-newlib.m4: Remove CC_FOR_TARGET (BUG-FIX) * aclocal/sysv-ipc.m4: Move AC_DEFINE outside of AC_CACHE (BUG-FIX) NOTES: * autoconf-2.49b depredicates using changequotes. * The changes to configure.in are due to cleanups in autoconf-2.49b's implemention of canonicalization. With autoconf-2.1x it wasn't always clear, when to use $xxx or $xxx_alias. Now this is clear.
* 2000-11-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-091-0/+4
* 2000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-021-0/+6
| | | | | | * aclocal/canonicalize-tools.m4, aclocal/check-tool.m4, aclocal/prog-cc.m4, aclocal/prog-cxx.m4: Replace AC_CHECK_TOOL with an RTEMS specific but more restrictive autoconf macro.
* 2000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-021-0/+4
| | | | * automake/lib.am: Add LD.
* 2000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-021-0/+5
| | | | | * aclocal/canonicalize-tools.m4: Remove RTEMS_PATH_TOOL, use AC_CHECK_TOOL instead of RTEMS_PATH_TOOL in RTEMS_CANONICALIZE_TOOLS.
* 2000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-021-0/+7
| | | | | | | * aclocal/*: Replace with contents of macros/*.m4 * macros/: Remove. * aclocal/ar-s.m4 aclocal/tool-prefix.m4: Remove. * Makefile.am: Reflect changes to aclocal/ and macros/.
* 2000-10-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-311-0/+18
| | | | | | | | | | | | | | | | | | * configure.in: New, Cygnus/GNU style configuration. * Makefile.am: Add macros/, reflect new configure.in, ACLOCAL_AMFLAGS = -I $(RTEMS_TOPdir)/macros * automake/compile.am: BSP_SPECS, remove RTEMS_CANONICALIZATION. * automake/lib.am: Remove RTEMS_CANONICALIZATION. * macros/tool-prefix.m4: Remove. * macros/target.m4: Remove RTEMS_CONFIG_SUBDIRS, RTEMS_OUTPUT_SUBDIRS. * macros/enable-rtemsbsp.m4: Add RTEMS_CONFIG_PER_BSP, add setting RTEMS_ROOT. * macros/i386-gas-code16.m4: Define NEW_GAS only for 16bit mode- * macros/multilib.m4: Various minor fixes. * macros/project-root.m4: Remove setting PROJECT_TOPdir, PROJECT_ROOT, RTEMS_ROOT. * macros/rtems-top.m4: Remove RTEMS_CANONICALIZATION, TARGET_SUBDIRS; Add with_target_subdirs, PROJECT_TOPdir, PROJECT_ROOT.
* 2000-10-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-271-0/+6
| | | | | | * automake/multilib.am: New file. * Makefile.am: Update AUTOMAKE_FILES to reflect the contents of the automake/ directory.
* 2000-10-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-241-0/+6
| | | | | | * macros/enable-hwapi.m4: Removed. * aclocal/rtems-top.m4, automake/compile.am, automake/lib.am: A small cleanup step towards gnu-canonicalization.
* 2000-09-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-181-0/+46
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * macros: New directory. * macros/bsp-alias.m4: new file. * macros/canonical-host.m4: new file. * macros/canonical-target-name.m4: new file. * macros/canonicalize-tools.m4: new file. * macros/check-bsp-cache.m4: new file. * macros/check-bsps.m4: new file. * macros/check-cpu.m4: new file. * macros/rtems-debug.m4: new file. * macros/check-cxx.m4: new file. * macros/check-itron.m4: new file. * macros/check-multiprocessing.m4: new file. * macros/check-networking.m4: new file. * macros/check-newlib.m4: new file. * macros/check-posix.m4: new file. * macros/check-rdbg.m4: new file. * macros/enable-bare.m4: new file. * macros/enable-cxx.m4: new file. * macros/enable-gcc28.m4: new file. * macros/enable-inlines.m4: new file. * macros/enable-itron.m4: new file. * macros/enable-libcdir.m4: new file. * macros/enable-multiprocessing.m4: new file. * macros/enable-networking.m4: new file. * macros/enable-posix.m4: new file. * macros/enable-rdbg.m4: new file. * macros/enable-rtemsbsp.m4: new file. * macros/enable-tests.m4: new file. * macros/gcc-pipe.m4: new file. * macros/gcc-specs.m4: new file. * macros/i386-gas-code16.m4: new file. * macros/path-ksh.m4: new file. * macros/path-perl.m4: new file. * macros/prog-cc.m4: new file. * macros/prog-cxx.m4: new file. * macros/project-root.m4: new file. * macros/rtems-top.m4: new file. * macros/sysv-ipc.m4: new file. * macros/target.m4: new file. * macros/rtems-test-no-pause.m4: new file. * macros/multilib.m4: new file. * macros/tool-paths.m4: new file. * macros/tool-prefix.m4: new file.
* 2000-09-14 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-151-0/+4
| | | | * Makefile.am: Referenceed aclocal/enable-hwapi.m4 that was removed.
* 2000-09-14 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-141-0/+4
| | | | * aclocal/enable-hwapi.m4: Now longer used and removed.
* 2000-09-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-141-0/+4
| | | | * automake/lib.am: Remove leaf.cfg.
* 2000-09-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-131-0/+5
| | | | | * aclocal/rtems-top.m4: Add ENDIF-hack. * automake/compile.am: Add include $(DEPENDS) + ENDIF-hack.
* 2000-09-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-121-0/+8
| | | | | | | | * aclocal/check-cxx.m4: Add AC_SUBST(CPLUS_LD_LIBS) * aclocal/prog-cc.m4: Cleanup comments, require RTEMS_ENABLE_GCC28, add automake conditionals RTEMS_USE_GCC, RTEMS_USE_GCC272. * automake/compile.am: Replaced. * automake/local.am: Remove building variant handling.
| | | | | | | | * aclocal/enable-rtemsbsp.m4: Add RTEMS_ENABLE_BARE, AC_SUBST(BARE_CPU_MODEL),AC_SUBST(BARE_CPU_CFLAGS). * aclocal/i386-gas-code16.m4: AC_DEFINE NEW_GAS. * aclocal/target.m4: Cleanup comments * Automake/compile.am: Add DEFS support to keep building happy.
* 2000-09-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-061-0/+4
| | | | * aclocal/project-root.m4: Introduce PROJECT_TOPdir, add comments.
* 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-051-2/+7
| | | | | * automake/compile.am: New file * ChangeLog: Fix email addresses
* 2000-08-31 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-011-0/+4
| | | | * LICENSE.NET, README, README.configure: Spelling corrections.
| | | | * aclocal/check-bsps.m4: Fix c4* and sim68000 entries
* 2000-08-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-08-301-0/+4
| | | | * LICENSE.NET, LICENSE.RPCXDR, LICENSE.WEBSERVER: New files.
* 2000-08-25 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2000-08-251-5/+4
| | | | * ChangeLog: Moved incorrect entries to make/ChangeLog.
* 2000-08-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-08-251-0/+12
| | | | | | | | | | | | * make/custom/pck6.cfg: New file * make/custom/pc486.cfg: Use -m486 * make/custom/pc586.cfg: Use -mpentium * make/custom/pc686.cfg: Use -mmpentiumpro * make/custom/i386ex.cfg: Use -msoft-float * aclocal/check-bsps.h: - Add pck6-BSP - Exclude ChangeLog from being picked up as BSP * aclocal/bsp-alias.m4: Add pck6-BSP
