path: root/ChangeLog (unfollow)
2002-01-062002-02-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+12
* aclocal/check-newlib.m4: Apply AS_IF. * aclocal/config-subdirs.m4: Remove _RTEMS_PUSH_BUILDDIR, _RTEMS_POP_BUILDDIR, _RTEMS_GIVEN_INSTALL, _RTEMS_SUB_SRCDIR. * aclocal/subdirs.m4: Fix comments, apply AS_IF. * aclocal/sysv-ipc.m4: Reflect autoconf-2.5x canonicalization changes. * aclocal/target.m4: Add _RTEMS_PUSH_BUILDDIR, _RTEMS_POP_BUILDDIR, _RTEMS_GIVEN_INSTALL, _RTEMS_SUB_SRCDIR. * automake/compile.am: Remove librtemsall from LINK_FILES.
2001-12-202001-12-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+20
* configure.ac: Reworked for multilibs, reflect changes to aclocal/*.m4. * aclocal/subdirs.m4: New file. * aclocal/multi.m4: New file, adopted from autoconf-2.52 w/ modifications. * aclocal/check-posix.m4: Apply AS_IF. * aclocal/config-subdirs.m4: Reflect changes to other m4-macros. * aclocal/env-rtemsbsp.m4: Add PROJECT_INCLUDE, PROJECT_RELEASE. Add AM_CONDITIONAL(MULTILIB). Adapt GCC_SPECS to multilibs. * aclocal/env-rtemscpu.m4: Remove RTEMS_BSP. Add support for MULTIBUILDTOP, MULTISUBDIR. Adapt GCC_SPECS to multilibs. Add PROJECT_INCLUDE, PROJECT_RELEASE, includedir, libdir. * aclocal/multilib.m4: Fix m4-quoting, adopt automake-1.5's OUTPUT_COMMANDS. * aclocal/project-root.m4: Remove PROJECT_INCLUDE, PROJECT_RELEASE. * aclocal/rtems-debug.m4: Minor cleanups. * aclocal/rtems-top.m4: Minor cleanups. * automake/compile.am: Further steps towards automake's rules.
2001-12-182001-12-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+5
* automake/multilib.am: include @RTEMS_BSP@.cfg, cleanup. * automake/lib.am: Add MULTISUBDIR.
2001-12-072001-12-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+5
* bootstrap: Run autoheader when configure.ac contains RTEMS_BSP_CONFIGURE. Remove bspopts.h* files.
2001-12-032001-11-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+5
* aclocal/bsp-configure.m4: New file. * Makefile.am: Add aclocal/bsp-configure.m4.
2001-11-272001-11-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+5
* Makefile.am: Add automake/force-preinstall.am, aclocal/ppc.am, remove ACLOCAL_M4.
2001-11-212001-11-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+7
* aclocal/bsp-alias.m4: Remove score603e_g1. * aclocal/check-bsps.m4: Remove score603e_g1. * aclocal/prog-cc.m4: Apply m4_if.
2001-11-202001-11-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+5
* automake/force-preinstall.am: New file. * aclocal/ppc.m4: New file.
2001-11-152001-11-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+5
* aclocal/check-bsps.m4: Reworked. * aclocal/bsp-alias.m4: Add score603e_g1, apply m4sugar.
2001-11-142001-11-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+4
* aclocal/bspopts.m4: New file.
2001-11-142001-11-13 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-0/+4
* COPYING: Test of $Id$ -> $RTEMS$.
2001-11-082001-11-08 Dennis Ehlin (ECS) <Dennis.Ehlin@ecs.ericsson.se>Joel Sherrill1-0/+9
This modification is part of the submitted modifications necessary to support the IBM PPC405 family. This submission was reviewed by Thomas Doerfler <Thomas.Doerfler@imd-systems.de> who ensured it did not negatively impact the ppc403 BSPs. The submission and tracking process was captured as PR50. * README.configure: Added gen405 BSP.
2001-10-292001-10-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+10
* Adopt more automake rules: * automake/compile.am: Add LINK, CXXLINK, AS, ASCOMPILE; Remove ARFLAGS, LINK.c, COMPILE.S, LINK.cc; Add CPU_CFLAGS to CXXFLAGS, CFLAGS, ASFLAGS; * automake/leaf.am: Add CXXLINK_APP, LINK_APP, make-exe, apply CXXLINK_APP in make-cxx-exe. * automake/lib.am: Add ARFLAGS.
2001-10-172001-10-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+5
* aclocal/check-rdbg.m4: Fix latent bug exposed by removal of config.cache's which prevented powerpc targets librdbg from building.
2001-10-172001-10-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+8
* aclocal/rtems-cpu-subdirs.m4: Add PREFIX arg to RTEMS_CPU_SUBDIRS, add 2nd arg to _RTEMS_CPU_SUBDIR. * aclocal/target.m4: Replace ac_configure_args with rtems_configure_args, add rtems_configure_args to INIT-CMDS. * Makefile.am: Require automake-1.5.
2001-10-112001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+6
* .cvsignore: Add autom4te.cache for autoconf > 2.52. * configure.in: Remove. * configure.ac: New file, generated from configure.in by autoupdate.
2001-10-102001-10-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+4
* aclocal/rtems-cpu-subdirs.m4: New file.
2001-10-102001-10-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+5
* automake/compile.am: Fundamentally reworked compilation rules for closer adaptation to automake's behavior.
2001-09-272001-09-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+6
* automake/lib.am: Comment out LD. * Makefile.am: Use ACLOCAL_FILES = to make automake-1.5 happy; Add automake/leaf.am to AUTOMAKE_FILES.
2001-09-272001-09-27 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-0/+4
* config.guess: No longer in CVS since installed by bootstrap.
2001-09-212001-09-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+5
* bootstrap: remove/add automake added files. * .cvsignore: reflect changes to bootstrap.
2001-09-192001-09-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+4
* automake/leaf.am: New file.
2001-09-142001-09-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+10
* aclocal/canonical-target-name.m4: Use AC_CANONICAL_TARGET instead of AC_CANONICAL_SYSTEM. * aclocal/config-subdirs.m4: Use AS_MKDIR_P instead of mkinstalldirs and mkdir. * aclocal/target.m4: Obsolete RTEMS_OUTPUT_BUILD_SUBDIRS, hack RTEMS_CONFIG_BUILD_SUBDIRS, introduce _RTEMS_OUTPUT_BUILD_SUBDIRS.
2001-09-132001-09-13 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-0/+4
* missing: Updated to latest version.
2001-09-132001-07-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+24
* configure.in: autoupdate to autoconf-2.52. * bootstrap: Add handling for configure.ac, make autoheader verbose, fix auto*tool invocation order. * aclocal/rtems-test-no-pause.m4: Introduce AC_HELP_STRING. * aclocal/enable-bare.m4: Introduce AC_HELP_STRING. * aclocal/enable-cxx.m4: Introduce AC_HELP_STRING. * aclocal/enable-gcc28: Introduce AC_HELP_STRING. * aclocal/enable-inlines.m4: Introduce AC_HELP_STRING. * aclocal/enable-itron.m4: Introduce AC_HELP_STRING. * aclocal/enable-libcdir.m4: Introduce AC_HELP_STRING. * aclocal/enable-multiprocessing.m4: Introduce AC_HELP_STRING. * aclocal/enable-networking.m4: Introduce AC_HELP_STRING. * aclocal/enable-posix.m4: Introduce AC_HELP_STRING. * aclocal/enable-rdbg.m4: Introduce AC_HELP_STRING. * aclocal/enable-rtemsbsp.m4: Introduce AC_HELP_STRING. * aclocal/enable-tests.m4: Introduce AC_HELP_STRING. * aclocal/env-rtemsbsp.m4: Add AC_ARC_VAR(RTEMS_BSP), apply true in RTEMS_CONFIG_PER_BSP conditional. * aclocal/multilib.m4: Introduce AC_HELP_STRING. * aclocal/rtems-debug.m4: Introduce AC_HELP_STRING. * aclocal/rtems-top.m4: Add AC_PREFIX_DEFAULT(/opt/rtems).
2001-05-252001-05-25 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-0/+6
* README.configure: Corrected the name of the MRM332 BSP. Strengthened the distinction between what the target and the BSP each select. Added more targets to list.
2001-05-252001-05-25 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-0/+4
* README.configure: Updated the list of BSPs.
2001-05-242001-05-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+6
* canonical-target-name.m4: Fix m4-quoting for autoconf-2.49f. * aclocal/config-subdirs.m: Fix m4-quoting for autoconf-2.49f, Add support for DOS-drive-letters.
2001-05-072001-04-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+5
* aclocal/prog-cc.m4: Add CPPFLAGS and CFLAGS handling to RTEMS_PROG_CC_FOR_TARGET.
2001-04-262001-04-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+6
* README.cdn-X: Update. * automake/compile.am: Remove -ansi -fasm from CFLAGS_DEFAULT, add @CPPFLAGS@ to CPPFLAGS.
2001-04-202001-04-20 Eric Valette <valette@crf.canon.fr>Joel Sherrill1-0/+6
* aclocal/check-rdbg.m4: Added check to determine which PowerPC BSPs support the new exception processing model and consequently, librdbg.
2001-03-012001-02-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+8
* configure.in: Reworked for Canadian Cross support. * Makefile.am: Reflect changes to configure.in. * config.guess, config.sub: Update from subversions.gnu.org. * README.cdn-X: New file. * tools/Makefile.am: Remove build, tools from SUBDIRS.
2001-02-212001-02-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+7
* aclocal/config-subdirs.m4: Let CC default to $host_alias-gcc in TARGET_CONFIG_SUBDIRS. * aclocal/enable-bsp.m4: fix quoting. * aclocal/check-bsps.m4, aclocal/bsp-alias.m4: Add pc386dx.
2001-02-122001-02-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-1/+6
* aclocal/config-subdirs.m4: New file. * aclocal/target.m4: Use macros from config-subdirs.m4.
2001-02-022001-02-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+5
2001-02-022001-02-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+7
* configre.in: Fix AM_INIT_AUTOMAKE. * aclocal/bsp-arg-enable.m4: Extend comments. * aclocal/check-bsps.m4: Remove extraneous comments, add test -d in the default clause.
2001-01-292001-01-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+13
* aclocal/enable-rtemsbsp.m4: Split out RTEMS_ENV_RTEMSBSP, RTEMS_ENV_RTEMSCPU. * aclocal/env-rtemsbsp.m4: New file for RTEMS_ENV_RTEMSBSP, add special treatment for GCC_SPECS. * aclocal/env-rtemscpu.m4: New file for RTEMS_ENV_RTEMSCPU, add special treatment for GCC_SPECS. * aclocal/bsp-enable-arg.m4: New file, introduce RTEMS_BSP_ARG_ENABLE. * aclocal/prog-cc.m4: Add AC_PROG_CPP, use build_os in GCCSED hack. * automake/compile.am: New treatment of CPP, GCCSPECS, use `..` instead of $(shell ..) for LIBC_LIB*.
2001-01-222001-01-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+5
* aclocal/bsp-alias.m4, aclocal/check-bsps.m4: Add simsh7032 and simsh7045.
2001-01-032001-01-03 Emmanuel Raguet <raguet@crf.canon.fr>Joel Sherrill1-0/+4
* automake/compile.am: Add LD.
2000-11-272000-11-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+6
* config.guess, config.sub: Update from CVS-autoconf to pick up new features (e.g. CC_FOR_BUILD in config.guess) but is necessary anyway to use autoconf-versions > 2.13.
2000-11-152000-11-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+8
* aclocal/canonical-host.m4: Abandon changequotes (autoconf-2.49b). * aclocal/check-newlib.m4: Let check message refer to RTEMS newlib. * aclocal/rtems-debug.m4: Fix formating and contents of the check's help string. * aclocal/rtems-top.m4: Remove AC_ARG_WITH(target-subdir).
2000-11-132000-11-13 Jiri Gaisler <jgais@ws.estec.esa.nl>Joel Sherrill1-0/+6
* README.configure, aclocal/bsp-alias.m4, aclocal/check-bsps.m4: Modified to reflect addition of LEON BSPs as well as the no-FP ERC32 variant.
2000-11-092000-11-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+11
* aclocal/gcc-pipe.m4: Use $GCC instead of ac_cv_prog_gcc (autoconf standard). * aclocal/gcc-specs.m4: Use $GCC instead of ac_cv_prog_gcc (autoconf standard). * aclocal/multilib.m4: Fix m4-quoting (BUG-FIX). * aclocal/check-bsp-cache.m4: Fix m4-quoting (autoconf-2.49b). * aclocal/prog-cc.m4: Use $GCC instead of ac_cv_prog_gcc (autoconf standard), replace CC_FOR_TARGET with CC (BUG-FIX).
2000-11-092000-11-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+17
* aclocal/enable-itron.m4: Remove changequotes (autoconf-2.49b). * aclocal/enable-posix.m4: Remove changequotes (autoconf-2.49b), use $host instead of $target (BUG-FIX). * configure.in: Use $target and $host instead of $target_alias and $host_alias (autoconf-2.49b). * aclocal/check-newlib.m4: Remove CC_FOR_TARGET (BUG-FIX) * aclocal/sysv-ipc.m4: Move AC_DEFINE outside of AC_CACHE (BUG-FIX) NOTES: * autoconf-2.49b depredicates using changequotes. * The changes to configure.in are due to cleanups in autoconf-2.49b's implemention of canonicalization. With autoconf-2.1x it wasn't always clear, when to use $xxx or $xxx_alias. Now this is clear.
2000-11-092000-11-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+4
2000-11-022000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+6
* aclocal/canonicalize-tools.m4, aclocal/check-tool.m4, aclocal/prog-cc.m4, aclocal/prog-cxx.m4: Replace AC_CHECK_TOOL with an RTEMS specific but more restrictive autoconf macro.
2000-11-022000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+4
* automake/lib.am: Add LD.
2000-11-022000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+5
* aclocal/canonicalize-tools.m4: Remove RTEMS_PATH_TOOL, use AC_CHECK_TOOL instead of RTEMS_PATH_TOOL in RTEMS_CANONICALIZE_TOOLS.
2000-11-022000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+7
* aclocal/*: Replace with contents of macros/*.m4 * macros/: Remove. * aclocal/ar-s.m4 aclocal/tool-prefix.m4: Remove. * Makefile.am: Reflect changes to aclocal/ and macros/.
2000-10-312000-10-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+18
* configure.in: New, Cygnus/GNU style configuration. * Makefile.am: Add macros/, reflect new configure.in, ACLOCAL_AMFLAGS = -I $(RTEMS_TOPdir)/macros * automake/compile.am: BSP_SPECS, remove RTEMS_CANONICALIZATION. * automake/lib.am: Remove RTEMS_CANONICALIZATION. * macros/tool-prefix.m4: Remove. * macros/target.m4: Remove RTEMS_CONFIG_SUBDIRS, RTEMS_OUTPUT_SUBDIRS. * macros/enable-rtemsbsp.m4: Add RTEMS_CONFIG_PER_BSP, add setting RTEMS_ROOT. * macros/i386-gas-code16.m4: Define NEW_GAS only for 16bit mode- * macros/multilib.m4: Various minor fixes. * macros/project-root.m4: Remove setting PROJECT_TOPdir, PROJECT_ROOT, RTEMS_ROOT. * macros/rtems-top.m4: Remove RTEMS_CANONICALIZATION, TARGET_SUBDIRS; Add with_target_subdirs, PROJECT_TOPdir, PROJECT_ROOT.
