2006-01-12 | 2006-01-12 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+2 | |
* aclocal/bsp-alias.m4: Revert Joel's 2006-01-10 change. Alpha-sort the aliases list. | |||||
2006-01-12 | 2006-01-12 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+5 | |
* automake/host.am, automake/local.am, automake/subdirs.am: Remove depend-am, depend-recursive. | |||||
2006-01-10 | 2006-01-10 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -0/+4 | |
* aclocal/bsp-alias.m4: Add sis as alias of erc32. | |||||
2006-01-09 | 2006-01-09 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+7 | |
* aclocal/bsp-alias.m4: Remove brs5l. Remove leon2. Alias leon1 to leon2. Add sis. * aclocal/check_bsps.m4: Remove brs5l. Remove leon. Add leon2. Add sis to erc32 family. | |||||
2005-12-31 | 2005-11-31 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+6 | |
PR 851/bsps * aclocal/bsp-alias.m4, aclocal/check-bsps.m4: Add gen5200 BSP family. | |||||
2005-11-07 | Fixed formatting | Joel Sherrill | 1 | -2/+2 | |
2005-11-03 | 2005-11-03 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+4 | |
* aclocal/check-bsps.m4: Add the plethora of mbx* BSP. | |||||
2005-09-02 | 2005-09-02 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -0/+4 | |
* VERSION: Updated to rtems-4.6.99.2. | |||||
2005-09-02 | 2005-09-02 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -8/+0 | |
* aclocal/version.m4: Updated to rtems-4.6.99.2. | |||||
2005-09-02 | 2005-09-02 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -2/+2 | |
2005-07-07 | 2005-07-06 Philippe Simons | Philippe Simons | 1 | -0/+4 | |
* MAINTAINERS: Added me as arm/gp32 bsp maintainer. | |||||
2005-04-28 | 2005-04-28 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -0/+5 | |
* README.configure: Updated to account for removal of dmv177 and ppcn_60x as well as other additions and deletions. | |||||
2005-02-04 | 2005-02-04 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+4 | |
* aclocal/enable-itron.m4: Allow unix. | |||||
2005-01-02 | 2005-01-02 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+4 | |
* Makefile.am: Remove ACLOCAL_FILES. | |||||
2004-11-16 | 2004-11-16 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+5 | |
* aclocal/check-bsps.m4: Use ls instead of globs to pickup bsp_specs. | |||||
2004-11-12 | 2004-11-12 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+5 | |
* aclocal/check-bsps.m4: Add MVME2100 BSP as alias of motorola_shared. | |||||
2004-11-10 | 2004-11-10 Joel Sherrill <joel@oarcorp.com> | Joel Sherrill | 1 | -0/+4 | |
* aclocal/bsp-alias.m4: Add MVME2100 BSP as alias of motorola_shared. | |||||
2004-10-22 | 2004-10-22 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+4 | |
* alocal/check-custom-bsp.m4: Reflect new location of bspkit*cfg. | |||||
2004-10-18 | 2004-10-18 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+6 | |
* aclocal/check-bsps.m4: Add bspkit support. Don't check for presence of *.cfg. * aclocal/check-custom-bsp.m4: Add bspkit support. | |||||
2004-10-18 | 2004-10-18 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+4 | |
* aclocal/enable-bare.m4: Remove. | |||||
2004-09-29 | 2004-09-29 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -0/+5 | |
* MAINTAINERS, README.configure, c/ACKNOWLEDGEMENTS, c/TOOL_TARGETS: i960 obsoleted and all references removed. | |||||
2004-09-24 | 2004-09-24 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+4 | |
* configure.ac: Require automake > 1.9. | |||||
* aclocal/rtems-cpu-subdirs.m4: Remove (unused). | |||||
2004-08-18 | 2004-08-18 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+7 | |
PR 673/make_build * config-ml.in: Quote 'cd "${ml_origdir}"'. Quote 'cd "${ML_POPDIR}"'. | |||||
2004-08-18 | 2004-08-17 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 1 | -1/+5 | |
* acinclude.m4 (_RTEMS_CONFIG_SUBDIR): Quote ac_popdir uses. | |||||
2004-07-29 | Removing message from cut release trial. | Joel Sherrill | 1 | -8/+0 | |
2004-07-28 | 2004-07-28 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -0/+4 | |
* VERSION: Updated to rtems-4.6.99.1. | |||||
* aclocal/version.m4: Updated to rtems-4.6.99.1. | |||||
2004-07-28 | Back off version again. | Joel Sherrill | 1 | -12/+0 | |
* release_support: Have a user name. | |||||
2004-07-28 | Back off version. | Joel Sherrill | 1 | -8/+0 | |
2004-07-28 | 2004-07-28 | Joel Sherrill | 1 | -0/+4 | |
2004-07-15 | 2004-07-14 Jay Monkman | Jay Monkman | 1 | -0/+4 | |
* MAINTAINERS: Added Jay Monkman as ARM architecture maintainer | |||||
2004-03-31 | 2004-03-31 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+6 | |
* aclocal/rtems-top.m4: Remove ENDIF. Remove with_target_subdir defaulting to '.'. * acinclude.m4: Add --includedir to sub_configure_args. | |||||
2004-02-17 | 2004-02-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+7 | |
* Makefile.am: DIST_SUBDIRS = $(SUBDIRS). Rework dist-hook. * configure.ac: Reflect changes to RTEMS_ENABLE_RTEMSBSP. * aclocal/enable-rtemsbsp.m4: Add support for --disable-rtemsbsp. | |||||
2004-02-14 | 2004-02-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
* configure.ac: RTEMS_BUILD_CONFIG_SUBDIRS([testsuites/tools]). | |||||
2004-02-13 | 2004-02-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+9 | |
* Makefile.am: Remove AUTOMAKE_FILES. Cleanup duplicate ACLOCAL_FILES. EXTRA_DIST += config-ml.in. DIST_SUBDIRS += make. Add dist-hook. * configure.ac: Add dist-bzip2 no-dist-gzip to AUTOMAKE_OPTIONS. | |||||
2004-02-12 | 2004-02-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
* bootstrap: RTEMS_CHECK_BSPDIR(RTEMS_BSP_FAMILY). | |||||
2004-02-12 | 2004-02-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+5 | |
* VERSION: 4.6.99.0. * aclocal/version.m4: 4.6.99.0. | |||||
2004-02-06 | 2004-02-06 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -0/+5 | |
* aclocal/bsp-alias.m4: Readd aliases for p4600 and p4650 which were accidentally removed when purging the mips64orion. | |||||
2004-02-03 | 2004-02-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -1/+7 | |
* aclocal/rpm.m4: Make osversions the default. * aclocal/rtems-top.m4: Remove check for version.m4 (Breaks make distcheck). | |||||
2004-02-01 | 2004-02-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
* aclocal/rpms.m4: New (extracted from scripts/configure.ac). | |||||
2004-01-16 | 2004-01-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+5 | |
* configure.ac: Require automake >= 1.8.2. * aclocal/check-bsps.m4: Also test for make/custom/*.cfg. | |||||
2004-01-12 | 2004-01-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
* configure.ac: Requires automake >= 1.8.1. |
